Does the GEN4 Prius use KYB struts/shocks? Are there any aftermarket Struts?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Mavi, Feb 19, 2018.
  1. Mavi
    Mavi Active Member
    484
    285
    San Diego,ca
    2020 Prius Prime
    So I'm seeing some high mileage Prius Gen4's out there in the used market, and I'm curious is there is any aftermarket affordable struts/shocks for the GEN4? For the GEN2/3 the KYB OEM struts were much cheaper than the Toyota branded ones, and I don't see any for the GEN4 so far. Are the only struts/shocks available for the GEN4 the Toyota ones or the High performance coilovers? Is there no affordable options available as of yet? Thanks
    Note: Just saw that some are selling GEN3 struts/shocks as GEN4 ones... are they the same part numbers?
  2. Prodigyplace
    12,718
    11,850
    Central Virginia
    @sfv41901 should be able to answer these questions since his business, Hybrid Pit sells aftermarket Prius accessories.
    RCO likes this.
  3. PHEVisthefuture
    PHEVisthefuture Junior Member
    83
    25
    Illinois
    Interested in the same info. My 2017 Prime at 106k+ miles is starting to show signs of strut wear, and I'd (hopefully) want to change these with E-Z struts to avoid having to rent a spring compressor and the dangers of compressing the springs.
  4. Robert vickroy
    Robert vickroy Junior Member
    Houston
    2018 Prius Prime
    How do I know when shocks and struts need replacing? Shocks on regular cars use to be one pushed down on car and it should rebound in 1-1/2 bounces. For my 2018 Prius Primer Plus plug-in with 60K on it I push down on car front and back and it doesn't bounce at all.
