Any thoughts on the "looming" motor oil shortage?
Discussion in 'Fred's House of Pancakes' started by Stevewoods, May 19, 2026.
  1. Stevewoods
    Stevewoods Senior Member
    664
    1,252
    where I am
    Sorry.Tried to deflect this to the existing discussion, but you know..."Herding Cats..."
    Will go ahead & stash 10 qts of 0-20w.
  2. ETC(SS)
    7,501
    Trading a 'gasser' for a BEV isn't 'trading' as the word is commonly understood by normies.
    It's more like taking a further loss on a vehicle that you're probably already underwater on.
    You're at risk of paying thousands more for a car that you will save hundreds on in operating costs.
    Pass.
    I did the math on that once before.
    Glad I topped off my oil change supplies before the story broke.
    Our local Wally's motor oil shelves are starting to look like the water aisle the day before a hurricane.....
    +1. I try to buy the 12q cardboard size since my truck has a 6.2q sump but I usually have to buy 2-5q jugs and recycle.....or reuse.
    The only oil available in winebox containers is a non-synthetic.
    #22 ETC(SS), May 22, 2026
    Georgina Rudkus likes this.
  3. Mendel Leisk
    42,271
    I "was" doing a BYOB (Bring Your Own Bottle) workflow, took a 10 litre gas can the near-to-me dealership; their service department would fill and I'd pay at the counter. I had a similar 5 liter container that I topped with a large funnel, which I caught drained oil with. I would walk that bottle down to a local quick-lube place that took waste oil, pour it out in their tank.
    This made for NO oil-contam'd bottles.
    Unfortunately, the dealership kept upping the price for their bulk oil, finally refused to sell me oil. So back to buying oil in bottles (currently Costco's 2-pack of 5 quart Kirkland brand), then putting waste oil in the empties,, dropping off at aforementioned quick-lube place.
    But it irks.
    Zeppo Shanski likes this.
  4. bisco
    52,784
    worst comes to worst, don't change the oil
  5. frodoz737
    frodoz737 Top Wrench
    4,793
    2,560
    33
    The sky is falling. :ROFLMAO:
  6. Stevewoods
    664
    1,252
    where I am
    Bought 10 qts of Mobil guaranteed 25K oil. If thing really go south, that will hold for several years
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,560
    2,599
    Taylors, SC
    Any oil retained in any engine beyond 5k miles will result in sludge development.
    The only way to remove debris is to change the oil.
    The oil might last, but debris will last to to clog passages and coat moving parts.
    PrimeDan likes this.
  8. Trollbait
    12,806
    The extended life oils start with a higher load of the additives that keep the particles in suspension and forming sludge.
  9. Georgina Rudkus
    3,560
    2,599
    Taylors, SC
    Still, abrasive material in suspension wears almost all moving engine components.
    Waterjets with abrasive inn suspension can cut through even some of the hardest materials.
    Here's a video of the empty oil shelves at one Walmart.
  10. ColoradoBoo
    ColoradoBoo Senior Member
    1,338
    961
    Monument, Colorado USA
    Empty spots but not empty shelves at Walmart....looks like mine.
  11. frodoz737
    4,793
    2,560
    33
    We are not going to run out of oil in any of our lifetimes. Ya'll really need to find something else to get all spun up about.
  12. Georgina Rudkus
    3,560
    2,599
    Taylors, SC
    This video explains the sources of the components needed to make modern synthetic low viscosity oils sourced from the Middle East and why the closure Strait of Hormuz affects the supply.
  13. Hayslayer
    Hayslayer Active Member
    521
    319
    Oh my god, you were so right!!!
    I paid $24.97 for a 5 quart jug of Mobil 1 0W-30 months ago at Walmart. I just bought 2 more jugs of the same stuff today and it was............$24.97 a jug.
    The end of oil is coming soon!!
  14. Trollbait
    12,806
    Most(nearly all?) of the particles that form in oil aren't abrasive. They aren't even solids. The fluid system is more homogenized milk and cream instead of cutting fluid. Those particles are from the oil degrading. When that happens, the molecules convert into heavier molecules that aren't soluble in the base oil anymore.
    They could clump up into a more viscous liquid and even settle out to form sludge that leads to problems. Which is why we have detergents in the additive package. To keep those particles in suspension, where larger clumps can be caught by the filter.
    I've gone into Walmart to get oil, and they were sold out. Didn't need a war or oil shortage for it to happen. It is very possible this is a case of panic buying; like toilet paper during COVID.
    Winston Smith and frodoz737 like this.
  15. ChapmanF
    18,959
    I was just in an AutoZone to dump my used oil, and their oil shelves looked pretty normal.
    John321 likes this.
  16. ColoradoBoo
    1,338
    961
    They say the shortage will effect, mostly, 0W-8 and 0W-16 motor oils. But you can log into Walmart.com, right now, and buy both. (The do say "low stock" but still available.
    I got 2 jugs of Mobile One 0W-16 for our two 4-banger Toyota's that take them so I'm good for at least a year.
    Seems like much ado about nothing....too many people only change their oil every year or two, these days, anyway. (Which is why I don't buy used anymore.)
    frodoz737 likes this.
  17. Mendel Leisk
    42,271
    Noted?
  18. Zeppo Shanski
    Zeppo Shanski Active Member
    307
    189
    Chicagoland
    I just picked up all the stuff and did an oil change today. Every product I use was on sale. Lucas synthetic $12. Penzoil Premium Platinum synthetic 0-20 $6. Napa Gold oil filter (made by Wix) $4. Rislone & HyperLube 2 each @ $6 each. If there is any "shortage" I didn't see it with today's prices.
    John321 likes this.
  19. Rmay635703
    Rmay635703 Senior Member
    2,688
    1,725
    Somewhere in Wisconsin
    2013 Chevy Volt
    The newest processor coming online makes some sort of grade 2 basestocks.
    To maybe achieve SP or SQ ratings with said swill would likely result in 10w30 or heavier.
    likely fine for the hd diesel equipment markets but there is a non-zero chance that our oil capabilities will lowest denominator be eroded to mid 1980’s levels for consumer fluids.
    it’s worth noting SAE specs and certs are already being officially allowed to slip so oil can keep flowing into jugs without disruption.
    In the not so distant future,
    Unless you are important there won’t be in spec oils for the now customers of last resort.
    sales are not based on material costs but on maintaining FIFO on store shelves, which is being affected by trying to clear out bankrupt and obsolete brands
    considering we are in an acute recession many people, especially DIY aren’t buying oil and filters at expected rates, increasing materials costs have exacerbated lack of demand
    #39 Rmay635703, May 25, 2026
  20. Hayslayer
    521
    319
    You drive 2k miles a year and you're on here crying about gas prices and oil not being available? You need therapy.............you act like you drive 50k miles a year. Relax and go live life. Get T out of your head. Damn, I feel sorry for people like you who are obsessed with hating. Were you on here 16 months ago screaming about egg prices? Most likely. Have you followed up on those complaints? 18 packs for $2.00? 60 packs for $7?
    PrimeDan and John321 like this.
