200,000 Mile Club
Discussion in 'Gen 3 Prius Main Forum' started by Raytheeagle, Apr 10, 2019.
  1. Bill Norton
    Bill Norton Senior Member
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Read up on performing a Piston Soak.
    I have a friend with almost 1 million miles on various Gen 2 and 3 Prii.
    He claims to get a big improvement on oil consumption after doing a week long piston soak.
    But this all depends on how you deal with the current situation.
    Installing a used engine is a roll of the dice. You already have a used engine. You could repair it.
    My Gen4 is doing great at 277k miles and doesn't seem to use much oil at all between 5-7k oil changes.
  2. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    So even at OEM prices, a new sensor could be tried first, no??
    But your right, that engine has a serious problem that may be too late for a piston soak.
    Don't listen to me.
    I'm bailing on my '10 w/ 179k miles on it. The head gasket was changed (FelPro) and it runs great. Does not consume oil.
    I get the weekly or so P420 for a while now. I'll replace the sensor before selling it.
    I'm bailing before the brake booster, or something else goes bad. The pack has always been healthy.
    And thanks to The Epstein War, I suspect Prius prices should be on the rise!:(
    Also I get, off hand, 5-7 mpg higher then the Gen3 driving the same with my '19 Eco.
    Plus, it's compatible with the Comma4! Big generational jump in tech!
  3. Brian Chavez
    Brian Chavez New Member
    SoCal
    I did not go that into detail with him about it but I would be more comfortable with the engine swap. He was also trying to sell me a 2012 Lexus CT 200 with 200k miles. Looked nice but that is the same engine as my 2011 prius so I would be taking a risk on that engine also.
    Mendel Leisk and Bill Norton like this.
  4. Brian Chavez
    SoCal
    I am going to pick it up today and see what the dealer will give me for a trade in. Its time to upgrade to the Sienna but man those new price tags are creeping into the mid 50ks... ouch!
    Anyone know of an aftermarket for gently used prius hybrid batteries. My new ones have less than 50k miles on them.
  5. GustoGuy
    GustoGuy Member
    82
    57
    Well at 431,000 miles my 2010 Prius finally blew it's 2nd and last headgasket. I already bought a 2018 Prius Prime Advanced trim with 29,600 miles on it. It's fully loaded with all the safety features like Blind spot monitoring and pre collision avoidance and lane keeping assitance . I was hoping to see it make 500,000 miles but I refuse to dump any more money into it so its the end of the line now. Ironically the car still looks pretty good and a mechanically inclined person could still do a JDM engine swap but with an odometer at 431,000 miles the car is almost totally worthless because there would be very little resale value at that many miles.
    Bill Norton likes this.
  6. GustoGuy
    GustoGuy Member
    82
    57
    Funny because Toyota's are supposed to be so reliable. I used to own a 2003 Hyundai Elantra and I put on 441,000 miles on the original engine and transmission and it was the most reliable car I ever owned. Unfortunately my 2010 Prius will go down as one of my least reliable cars. Andrew from Minnesota Hybrids said he doesn't recommend buying a Gen 3 Prius and I told him that I am on my second engine and that I hope to get 500,000 miles out of it and he said you might but the headgasket issue is very real and very few Gen 3 will make 300,000 thousand miles without a headgasket failure while the Gen 2 do it regularly. I dropped too much money on maintaining this car. I will be selling my 17 inch Prius 5 wheels and Michelin tires hopefully for at least $500 dollars to recoup some of my losses. I now realize that Gen 3 Prius won't last if you drive alot like me. They are ticking time bombs which will blow once they reach 150,000+ miles
  7. GustoGuy
    GustoGuy Member
    82
    57
    Let it blow headgasket time. I am done with headgasket popping Gen 3 Prius cars. I just bought a low mileage Gen 4 Prius Prime. I even took great care of my Gen 3 Prius changed the oil every 5000 miles and it didn't burn a drop of oil yet it still blew a headgasket. I owned many high mileage cars ( 2003 Hyundai Elantra went 441,000 miles on the original engine and transmission ) and the only headgasket failures I ever had were with my Gen 3 Prius
    #227 GustoGuy, May 27, 2026
  8. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    I've been through 2 Gen3's with head gasket failures. One I sold before it got too bad. The one I still have, '10 level 5 w/ATP, I had a FelPro head gasket installed, but I don't feel confident. Did you use this gasket?
    In December I bought a '19 Gen4 Eco with 232k mi. and I just changed the oil again at 271k mi. I drive a lot. It's a courier's car... It doesn't use oil between 5-8k mi oil changes. It runs about 5-8 mpg better than the old Gen3.
    We shall see how long this Gen lasts.... It doesn't use oil between changes, that I can tell.
    If you drive for a living, I really recommend a Comma 4 so you don't have to spend your days keeping it between the lines. My hands are so happy now!
  9. GustoGuy
    GustoGuy Member
    82
    57
    I used a low mileage JDM engine swap in 2021 to repair my car. I not going to put anymore money into my Gen 3
  10. ASRDogman
    ASRDogman Senior Member
    8,067
    4,089
    When you replace parts with used parts, you don't know what you are getting.
    Everyone wants to spend less money, but a motor shouldn't be one of them.
    From what I've read on here, jdm motors aren't the best deal as them make them out to be.
    With no history, or engine number, you can't know how many miles and what year
    they are.
    Not right to blame Toyota when you put used unknown parts.
    And there does come a time when putting more money into a vehicle, no matter what brand,
    is just not worth it. And if you are paying labor for someone to do the work, it may be sooner
    than later.
    431,000 miles is quite a bit. I'll be hitting 387,000 soon.
    GustoGuy and Bill Norton like this.
  11. GustoGuy
    GustoGuy Member
    82
    57
    Ironically the Toyota Dealership recommend JDM engine. The mechanic told me it costs more to do a head gasket than to put in a low mileage Japanese Prius engine in which is usually in much better shape than the high mileage USA Prius engines. I used a JDM engine and was quite happy . It didn't use a drop of oil either even to this day. However all of a sudden about 2 weeks ago I put in a few over the road shifts about 184 miles each and it started to idle a bit rough then it got progressively worse. The Headgasket is cheap and if you have your own shop and do it yourself it can be done quite inexpensively. However paying a mechanic to do it can be very expensive and on a car that has that many miles its a fools errand. I owned about 11 cars in my life and the Prius is the only one of them which popped Headgaskets (twice) so Yes I do blame Toyota because its a known issue on Gen 3 Prius. Usually where there is smoke there is fire.
    #231 GustoGuy, May 27, 2026
  12. GustoGuy
    GustoGuy Member
    82
    57
    Does your Prius have the original headgasket?
  13. ASRDogman
    8,067
    4,089
    I changed the head 301,000 miles. Twice I had the knock, coolant was down slightly.
    No warped head, 1 valve slightly leaking, barely. I lapped all of them, replaced the guide seals.
    Cleaned off the piston, cleaned the whole egr system.
    It's been running great ever since. It was running well before also.
  14. GustoGuy
    GustoGuy Member
    82
    57
    Did you do it yourself? I do my own brakes and oil changes and spark plugs minor suspension work wheel bearing transaxel fluid changes. No major engine work for me.
  15. ASRDogman
    8,067
    4,089
    Yes, I wouldn't trust anyone else to do it correctly.
    It's just like any other engine.
  16. Mendel Leisk
    42,364
    Just editorial.
  17. GustoGuy
    GustoGuy Member
    82
    57
    I like the Prius Prime Plug-in. Nice and quiet seems to handle a little better than my 2010. The only thing I not fully used to on the Prius Prime Plug-in is that the Steering seems to be a bit over assisted especially at lower speeds. Seems a little to light to the touch when compared to my old car. Other than that it's a nice car
  18. GustoGuy
    GustoGuy Member
    82
    57
    I have a complete 2010 Prius with clean title. I am aware that a scrap yard would pay a max of $500 or so. I have a Prius 5 with the 17 inch alloy wheels JBL stereo and I not going to give the scrap yard a minimum of a $500 gift by bringing my car in with these wheels on it. I will most likely sell my Wheels on Facebook Marketplace and my 3D Max floor mats too. I also had just put in a refurbished traction battery back in January for $850 so that is an unfortunate waste. Does anyone know of a place in Minnesota that will buy Gen 3 Prius for repair? A JDM engine or a head gasket replacement and it will be good to go again. I am done fixing and have moved on and already bought another vehicle. Supposedly the 2018 Prius Prime Plug-in has 5 x114.3 bolt pattern and the Gen 3 use 5 x 100 bolt pattern
    #238 GustoGuy, Jun 2, 2026
  19. Alexikor
    Alexikor Junior Member
    Arizona
    chiming in at 222,275 miles on a 2010 owned since new.
    1) HV battery, not yet replaced, no errors or codes, but haven't checked with Dr. Prius in about 6 months
    2) 12v battery: once at 179,477 and again at 213,000
    3) Transaxle fluid: once at 193,317
    4) Brake pad replacement: at least once, the last time was at 193,317, and i am sure i did it prior to that but didn't record it
    5) Lifetime mileage: my estimate is 46-52. highly variable depending on season
    6) Oil change: every 10,000 miles until 190,000. from 190,000 to present, every 5,000 miles. at higher miles and during the 10,000-mile interval, i noticed some oil burning. in the 5,000-mile interval, i don't notice oil burning. when i changed to the 5,000-mile interval, i also changed to "Mobil 1 Extended Performance Full Synthetic 0W-20 Motor Oil" and the oil at change is dark brown, with just a hint of gold.
    7) picture: when i get a chance
    8) Oil catch can - not installed, don't think i need one yet. there was very little oil in at the bottom of the intake manifold.
    9) EGR circuit: manifold, throttle body, EGR radiator, and pipe all cleaned at 200,000 miles, very dirty. will inspect the pipe at 225,000 miles to gauge when i need to clean it again. PCV valve replaced when i cleaned the circuit.
    10) other work:
    • all recall work performed
    • spark plugs at 120,000 miles.
    • ECU was updated twice, once at 60,000 miles and again at 142,000 miles. not sure why.
    • tpms sensors started to lose connection around 195,000 miles. i ignore the blinking tire light and check the pressure at two weeks, and sometimes the blinking light doesn't show up, hopefully can diagnose more when i buy the correct obd2-connector.
    • coolant swaps every 50,000 miles.
    • tire rotations every 5,000 miles.
    • rear struts and front sway links replaced for the first time at 218,500 miles with oem parts. front struts and control arms to be replaced later this year
    • MAF, throttle body, and fuel injectors cleaned at 185,700
    • front driver-side lightbulbs replaced for first time at 175,000
  20. GustoGuy
    GustoGuy Member
    82
    57
    I have a person interested in my Gen 3. Her Husband is a mechanic and can do an engine swap and she has 2011 base with very few options with Hybrid system failures. She doesn't drive alot and only has 160K miles on her car and the engine runs great but her hybrid system had the yellow triangle is on and mine has a new reconditioned traction battery. Her car also has some front end damages too and my car is a fully loaded 5 trim with the 440 watt 8 speaker JBL stereo and nice straight clean body which interests her. If it falls through I will put my car on Facebook marketplace and most likely will sell my 17 inch alloys wheels since a Junk yard most likely won't pay any more for it with the premium wheels so I might as well make some money off those wheels
