The simplest and easiest LiFePO battery conversion for all Ryobi 48 volt lead-acid battery mowers
Discussion in 'Fred's House of Pancakes' started by Georgina Rudkus, May 1, 2026.
  1. bisco
    52,578
    he starts the mods at 5:50
  2. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,541
    2,575
    Taylors, SC
    I now remember seeing that video.
    I would still get rid of the charging lock out and the charging receptacle and simply use the P3648 charger.
  3. bisco
    52,578
    the dc house and eco worthy are exactly the same size. must be the same mfg, or they are made to the same spec.
    dc house is listed as a bit longer because of the brackets he cuts off. one less thing to do with the eco worthy.
    Georgina Rudkus likes this.
  4. Georgina Rudkus
    3,541
    2,575
    Taylors, SC
    Exactly
  5. bisco
    52,578
    I just saw your earlier post on the company and size :cool:
    he uses reducing studs from M8 to M6 because of the eyelet size, an elegant solution
  6. ChapmanF
    18,773
    The only difference seems to be the ?start=354 at the end of bisco's link.
    Shouldn't that just be ?t=354
    If I remember right, youtube will also accept the slightly more human-readable form ?t=5m54s
  7. Georgina Rudkus
    3,541
    2,575
    Taylors, SC
    The better solution is to enlarge the hole to 8mm with a round file. The soft copper lug is easy to enlarge,
    More connections mean more chances to fail due to heating form increased resistance.
    The adapter might bottom out and also cause a loose connection.
