My 2026 Plugin Prius Buyers Regret...
Discussion in 'Gen 5 Prius Main Forum' started by Driver1, Jun 1, 2026.
  1. Driver1
    Driver1 New Member
    Georgia
    2026 Prius Plug-in
    XSE Premium
    Anyone else seriously regretting their Plug-in Prius?
    Here’s what’s driving me nuts:
    - Remote climate control is completely disabled below 30% battery. That’s ridiculous for this price point.
    - If you don’t plug it in, the engine thrashes and screams at low speeds and uphill — it’s loud and unpleasant. Toyota could’ve added a smart battery mode that uses the battery between 30-70% for smooth, silent EV driving under 35 mph, then does low-RPM recharging at higher speeds to stay quiet. It could’ve felt like a stealth hybrid that acts like an EV until you actually need the gas boost.
    Using the battery in that 30-70% range would actually be healthier for it long-term compared to sitting at very low charge all the time.
    They removed the Charge button and missed a huge opportunity for smart battery management that would work whether you plug in or not.
    So close to being a perfect car that fits real life instead of forcing you to adapt to it. Pretty disappointed.
    And yes I understand many just buy it for the 44 miles of commuter car, but thats not me, and yes I should have rechecked the 2026 features for them yanking the manual charge up while driving mode.
    Doesn't change the fact that they got the winning ingredients and fumbled the 5 star recipe.
    2 stars out of 5, would not purchase again unless they update the programming.
  2. Leadfoot J. McCoalroller
    8,266
    7,769
    Pennsylvania
    2018 Prius c
    I don't think the Prius transaxle can actually do that- that is, generate enough power to significantly charge the PHEV battery while also driving at highway speed and holding the gas engine to a low RPM all at the same time.
    Engine noise during acceleration and hill climbing was always part of the Prius experience. I don't think I would have expected that to go away when they added part-time EV capability to the PHEV model.
    Though, I can see where it's a sharper contrast in sound when the PHEV model allows more of your total driving to be done in the quiet EV mode.
    Also there's a bit of a "well there's your problem" statement to be made if you aren't regularly plugging the thing in- I don't mean that to be a cheap shot gotcha. But if you paid for that capability, why not take advantage of it?
    PrimeDan and BiomedO1 like this.
  3. KMO
    KMO Senior Member
    2,026
    750
    Finland
    2023 Prius Prime
    At highway cruise speed, the constantly-running engine is in its efficiency zone - doing more work to fill the battery to use the charge later is a net loss - charge/discharge losses mean you're burning more fuel to fill the battery than it would have cost you to use hybrid mode later.
    Battery filling by choice only makes sense efficiency-wise when you would otherwise be running the engine significantly below peak efficiency, so the efficiency gain from taking more engine power outweighs electric charge/discharge losses. .
    At low speed, a constantly-running low-loaded engine would be inefficient, so it does make sense to alternate between charging the battery and stopping the engine and using charge - that's the standard hybrid operation.
    The speeds where OP would like to use EV are the speeds where you could be slowly building up charge efficiently. With a bigger battery you could run the standard hybrid algorithm on a bigger timescale - rather than alternating once or twice a minute while in town, you could alternate every few hours of driving. But it still wouldn't make sense (efficiency-wise) to fill it up while highway cruising.
    So the car doesn't do what OP wants - the aim is to be an efficient hybrid with plug-in ability, not a fuel-powered EV.
    New regulations are the reason the Charge mode button went away in America - new CARB rules required that emission measurements are done in the most polluting user-selectable drive mode, which would have meant testing in Charge mode. Charge mode remains available outside North America.
    So elsewhere you do retain the option to spend fuel now to avoid running the engine later, but it's not generally the smartest thing to do - if you want to run EV later, you should have filled from wall charge, and be running hybrid now to save charge to run EV later.
    PrimeDan likes this.
  4. lostsoul
    lostsoul New Member
    US
    2026 Prius Plug-in
    I get some of the reason they got rid of Charge mode, but I was also mad when I noticed the feature gone. 1) I dont think there would have been much of a EPA change from 2025 to 2026. Hell under the new admin they have been cutting back on allot of the bs letting Dodge and others bring back more v8s. 2) Then you find out that Parts of Canada and Europe that have higher restrictions get that option even on 2026s which rub it in more.lol. Which also adds in the oil type difference between here and there. I have been unable to find out the exact change if its just a switch change or if there is a switch and software change and if that can be put back with Toyota tools. Service people and the main Toyota call centers dont seem to know chit. Hell the lady just read stuff off without really understanding what chg mode was. lol I understand its something that shouldn't be used much, but if others have it I feel cheated. Either way I love the car.. I just have to tuck my head down more getting in.
    ----The 2025 (formerly known as the Prius Prime) features distinct EPA ratings depending on the trim level, with the base SE model offering superior efficiency and range compared to the heavier XSE trims.
    • SE Trim: Rated for 44 miles of all-electric range, 52 MPG combined fuel economy, and 127 MPGe (miles per gallon gasoline equivalent) when operating in combined electric/hybrid mode.
    • XSE and XSE Premium Trims: Rated for 39–40 miles of all-electric range, 48 MPG combined fuel economy, and 114 MPGe
    ---The 2026 Toyota Prius Plug-in Hybrid features EPA ratings that vary by trim level, with the base SE trim offering the highest efficiency and range.
    • Electric Range: The SE trim provides an EPA-estimated 44 miles of all-electric range, while the XSE, XSE Premium, and Nightshade Edition trims are rated for 39 miles.
    • MPGe: The SE trim achieves 127 combined MPGe, whereas the higher trims earn 114 combined MPGe
  5. KMO
    KMO Senior Member
    2,026
    750
    Finland
    2023 Prius Prime
    I didn't say EPA, I said CARB.
    The new rules for 2026 added this:
  6. Hammersmith
    Hammersmith Senior Member
    2,449
    2,512
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I don't really care because I don't own a Prime/PHV(and wouldn't use charge mode even if I did), but the modifier in me is 99.9% certain you could add the charge button to new models that don't have them if you really, really wanted to. The annoying part would be adding the wiring from the center console to the Main Body ECU and/or the Hybrid ECU.
    If the Prius PHV still has charge mode in Europe(and Japan?), that means the ECUs still have the programming. You just need to add the switch. Buy a new one from Toyota or a used one from a wrecked 2023-25 Prime. Look up the wiring diagram for a 23-25 or any EU PHV and run the switch wiring to wherever it says. Boom, charge mode added.
    Trollbait likes this.
  7. KMO
    KMO Senior Member
    2,026
    750
    Finland
    2023 Prius Prime
    But it's not a separate switch, like the American Gen 2's omitted EV mode.
    You enter charge mode by long press of the HV/EV button. The button hasn't disappeared, just the "HOLD CHG" marker.
    I think that means it's almost certainly an ECU change, unless it's a very advanced button sending press length over some sort of network protocol.
  8. Trollbait
    12,800
    Sounded like an advanced button from some sources on the subject.
    If it is just a change in the ECU software, an interested tuner with figure out how to flip the 'switch'. It has happened in Sonics for E85 and flexfuel use; older GMs with Holden roots for lean burn mode, and the CARB hobbling in i3 RExs.
  9. mva
    mva Active Member
    174
    102
    B.C. Canada
    2024 Prius Prime
    SE
    The CHG mode is handy for certain conditions. I have used it to build up a charge on a road trip for car camping. It will charge the battery to just over 40 miles of EV range which is usually enough to run the climate control overnight. I have also used it when I have a long wait for a ferry coming up so that I can sit in the car without the engine coming on.
    I have checked it on long trips to run EV in city and HV/CHG on the highway and it does seem to be quite efficient and not much different than HV mode.
    Hopefully you'll find a way to enable it.
  10. Hammersmith
    2,449
    2,512
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Ahh. I thought it was a separate button. My bad.
    (does research this time)
    So it's not a separate button in any sense of the word. The whole parking brake switch assembly is one unit.
    (plummets down the rabbit hole and pays for access to US and EU tech sites)
    Still can't give a solid answer.
    Things I know:
    1. No wiring changes from 2025 to 2026
    2. There is only one wire involved (labeled EVHV)
    3. The hybrid ECU changed part numbers from MY25 to MY26
    4. US MY26(w/o charge mode) and EU MY26(w/ charge mode) still use the same hybrid ECU (so the change isn't hardwired in the ECU)
    5. The switch assembly has a new part number (but that could be just because of the printing on the switch)
    6. The new version of the switch assembly is 13% cheaper than the old version
    So there are two scenarios:
    1. The change is software-based and done when the hybrid ECU is initially programmed(why US and EU ECU's are still the same)
    2. The old switch is different internally and sends a special signal when it's been pressed and held
    It will cost someone with a 2026 US PHEV about $110 to test. They'd have to buy the old version of the switch assembly and see what happens. The install is fairly easy. The piano black portion of the center console needs to be popped up to access the four 10mm or philips screws that hold the switch assembly to the trim from below. With a small ratchet or stubby screwdriver, a person might not even have to fully remove the trim section(it includes the cup holders and storage tray). Four screws and one electrical connector and the job's done. Maybe 5-10min for a trained tech; 15-30min for a novice. For testing purposes, a person wouldn't even have to remove the old switch; just pull up the trim enough to unplug the old one and temporarily plug in the new.
    These are the three versions of the switch assembly:
    84390-47110 - HEV, 2023-onward
    84390-47110 - PHEV, 2023-2025 US, 2023-onward EU (w/ charge labeling) - $215.55 MSRP, $149.03 today, $111.78 during 25%-off sale
    84390-47140 - PHEV, 2026-onward US (w/o charge labeling)
    I'm going to guess 60/40 nothing happens if a 2026 owner swaps to the older switch. I lean toward KMO being correct and the change is in the ECU programming. But the drop in the switch price and the fact that the US and EU hybrid ECUs are still the same part number means a physical change to the switch is still in play.
    Besides a '26 owner buying(or borrowing) an old switch to test, another way to know for certain would be to attach an oscilloscope or other advanced reader to the wire* on a 2023-25 PHEV model(while everything's plugged in and the car's running) and see if there's a signal difference when the button is held for the needed amount of time. Does the button send two distinctly different signals, or is it just a single continuous signal for as long as the button is pressed?
    But I don't have the tools or the car to do the testing, so that will be up to one of you guys if you really want to know.
    *probably pin 6(blue - EVHV), but possibly pin 3(gray - EVMS - EV Mode Select)
    KMO and Trollbait like this.
  11. KMO
    KMO Senior Member
    2,026
    750
    Finland
    2023 Prius Prime
    Did you mean you paid for both? You can access the US and Japanese parts databases from the EU site - not sure about other manuals.
    There's a third scenario which is that the hybrid ECU is getting "permission" for charge mode from something else in the system - a message from another ECU, or just a line being tied high or low.
    Which could then be modified into a fourth scenario (or at least a variant of the second), which is that the button is indeed electrically different, but without being smart about timing itself. Maybe the non-charge and and charge buttons simply have different resistances when pressed.
    So maybe the new ECU will enter charge mode if it sees a 220ohm circuit closure for 2 seconds, but not if it sees a 780ohm closure for 2 seconds.
    (Or it could be a different resistance when not pressed.)
    That's far more likely than a smart button, and given the information that there's a new ECU but both EU and USA are the same, I'm going to revise up my estimate of the odds that a button change could be sufficient - could easily be Hammersmith's 40%, or higher.
    Mind you, at $200 per button, you could afford quite a lot of smarts...
    Copy and paste error on the part number - same as what you listed for the PHEV.
  12. KMO
    KMO Senior Member
    2,026
    750
    Finland
    2023 Prius Prime
    It occurred to me that the service manuals might give a clue here. The EU one says, in "Hybrid / Battery Control > Combination Switch > Inspection", that for the EV/HV Hold Charge switch, resistance should be below 50 Ohm when pressed, above 10 kOhm when released (between K22 pins 6 and 7 for LHD; 7 is earth and pin 3 mentioned above is the Auto EV/HV switch).
    There's no indication in the EU manual about the possible omission of Charge mode though - it assumes it's there.
    Maybe the same section in the US manual might indicate different resistances for the other button type.
    Wiring diagram in "Hybrid Control System (For PHEV Model) > Pattern Select Switch EV/HV Mode Circuit" reinforces that complete circuit is button <-> Hybrid Control System <-> Combination Meter Assembly.
    Do we think the Combination Meter Assembly has any part in the decision making here, or is it just displaying state? Who manages the Auto/HV switching for Predictive EV Drive (outside the US)?
    Switch assembly has 4 wires going to the hybrid control ECU, for Drive Mode +/-, HV/EV and Auto EV. The rest go to the skid control ECU.
    If it was just the button, then the permission would have to be encoded in those 4 wires somehow. Conceivably (but oddly) it could be one of the other 3 wires. Manual says the same thing for the Auto EV button - 50 Ohm pressed, 10 kOhm released. But the inspection values for the pair of Drive mode wires seems to be missing.
    An obvious test, which doesn't require actually buying a new button, would be to just short the "ECU<->EVHV" line to ground for a couple of seconds. Will that make a new US PHEV go into Charge state?
    #12 KMO, Jun 7, 2026
  13. Hammersmith
    2,449
    2,512
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The EU site gives me all the parts databases, but only the EU wiring diagrams. If I want to look at the US wiring diagrams, I need to pay for the US tech site. At least to the best of my knowledge. I really wish I knew of a site to get the JDM wiring diagrams. Every once in awhile it would be nice to compare certain things. But I'm also pretty much done with all my mods, so it's not any sort of pressing need anymore. Just idle curiosity.
    Darn it over the part number. I found the mistake and fixed it in my source notes, but that must have been after I did the copy paste. And it's been long enough that I can't edit the post anymore(not that it really matters; nobody's going to try any of this anyway).
    It's 84390-47100 for the HEV button, and 84390-47110 for the original PHEV button.
  14. Mendel Leisk
    42,251
    If it did matter, I think tidelandprius (our tireless moderator) could make the revision. (I've omitted the "@" proceeding his name, so as to not alert him; your call)
  15. Trollbait
    12,800
    Would those diagrams be in hte repair manual being offered here?
