Looking for guidance
Discussion in 'Newbie Forum' started by Daddywolf, Jun 2, 2026.
  1. Daddywolf
    Daddywolf New Member
    Howdy,
    I've been around cars for awhile but recently moved to California and bought a 2015 Prius 1 and a 2013 Highlander Hybrid. Both have been rolling for a few thousand miles with no issue getting close to their sticker mileage in the Sierra Nevada mountains. Until... both now have minor issues that do not seem to be affecting nikeage or performance for this post I will focus on the 2015 prius. It is throwing code p0403. Ive read this is in regards to the egr system, likely electrical. I have checked the efi#2 fuse, it is good I have checked the ohm readings on the valve motor, all read between 20.3 and 20.7 ohms.
    I appear to be gett8ng at least 11.64 volts from all the pins.
    I have park the car till I can get this resolved. Is the next step to pull the parts and prepare the brake cleaner for the egr valve, the egr tube and possibly the egr cooler?
  2. PriusCamper
    PriusCamper Senior Member
    13,420
    5,417
    Pacific Northwest, USA
  3. rjparker
    11,035
    6,920
    You are on the right track with your electrical tests. I would probably repeat them and then ohm out the egr to ecm wires.
    With Techstream you could try the egr step test as well which measures changes in intake pressure as the valve opens and closes.
    However with that code its most likely not moving and the system can detect an electrical issue like an open or short.
    Brian1954 likes this.
  4. Mendel Leisk
    42,296
    What’s the miles on the 2015 Prius? EGR could be carbon-clogged.
  5. Daddywolf
    226,786, sorry, didnt respond yesterday. Wife had ohysical therapy.
  6. Daddywolf
    I tested the ohms on the plug on the egr motor, still read 20.5 for the shown pins. Tested resistance on ecm-ecr connector wire, all pins registered well under 1 ohm on shown pin connectors.
    Tested all pins for shirts, found all pins OL on 20k ohm setting, no shorts detected. OHM reading
    Voltage showed 14.45 upon turn on but engine did kick on.
  7. Daddywolf
    I dont have much experience with e8 bolts. The one holding the engine block to the egr came out with some difficulty. The one connection the egr cooler to the exhaust pipe though, well. After a few explectives I have managed to make this job harder. See photo fir example of oafishness.
  8. Mendel Leisk
    42,296
    If you remove both lateral studs, one at the EGR valve, the other through EGR cooler’s lower bracket (access difficult), then you can leave the rearmost pair of longitudinal studs, that connect EGR cooler’s end flange to exhaust manifold, still manage to extract the cooler. Side benefit is that pair of studs will keep the gasket in place, avoid it dropping down during removal, and align it during reinstall.
    when pulling out the EGR assembly with rearmost studs still in place, it will bump into a tube above (gas vapour return?), but loosening its hold down bolt will give sufficient clearance.
    #8 Mendel Leisk, Jun 5, 2026
  9. Daddywolf
    I got in luck as the egr cooler already had its lower stud removed, guess its been servuced before. The only things holding the egr cooler in place are the cookant lines and that rear exhaust manifold pipE SO i guess Ill try and figure out how to remove it.
  10. Mendel Leisk
    42,296
    If the coolant systems still full, draining a couple of quarts from the radiator will drop the level below the EGR components, avoid any spill. Just pour it back into reservoir when done.
  11. Daddywolf
    Didnt realize the stud on the egr cooler coukd stay stationary that that there was a nut on the rear. I got it apart, cleaned the egr cooler, bought a new egr valve just in case, Im the orocess of cleaning the air intake manifold right now and replacing the sparkplugs and pcv vakve because, why not?
    When I reconnect the egr cooler and everything, do I need to bleed the system or will it bleed itself?
    Thanks again.
    Mels on youtube has abeen a good help as well.
  12. ETC(SS)
    7,515
  13. Daddywolf
    Tha ks for the suggestions. Unfortunately I have sinned and made a mistake. I cleaned the intake ports and now I see puddle of parts cleaner on top of the intake valves of 2 ports. How best to proceed. Would it be best to take out spark plugs put some fogging oil in the cylinder and crank the engine to blow out any debris/solvent? I dont want to blow the engine or cause too much metal on metal friction.
  14. Mendel Leisk
    42,296
    I just pour the drained coolant back into reservoir. I left the coolant vent spigot open (it’s atop EGR components), till coolant started coming out, while pouring. Later gen 3 years (than our ‘10) may not have the vent, but leaving the topmost coolant hose temporarily disconnected could achieve same I think.
  15. Daddywolf
    I think the discontinued the vent spigot on 2011s and up. I took a picture of the hose in question.
    Shoukd I woory about the brake cleaner that found its way into my intake ports?
  16. Daddywolf
    The top hose
  17. Mendel Leisk
    42,296
    ^ Exactly. You’re just giving the air, and eventually coolant, an exit route at the top.
    You could do a final blow-out with compressed air. I’ve no compressor, use wet/dry vac on blow, and sometimes a corded electric leaf blower
    #17 Mendel Leisk, Jun 13, 2026
  18. ChapmanF
    18,976
    Or just doing nothing at all there, which is what they changed the repair manual to say at the same time they 86'd that valve.
