I think it’s a fuse, but I’m not sure.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ShihFa, Jun 7, 2026.
  1. ShihFa
    ShihFa Junior Member
    53
    Milpitas, CA
    Hello all,
    These are the symptoms:
    1. The daytime running lights turn on intermittently when I turn the headlight switch to that option.
    2. The non-driver side windshield washer nozzle does not work, and I’ve already tried to declog it to see if that was the issue. And it was not. The driver side works just fine.
    2a. When I pulled out the fuse that is connected to the windshield washer motor, some white dust came out. And there was white dust on the fuse. I could not tell if the fuse was still intact.
    3. Now, the rear windshield washer nozzle doesn’t work either.
    Do you all think all these things are related to the same issue? What do you all think my next step(s) should be to troubleshoot this issue?
    Thank you and regards,
  2. ASRDogman
    ASRDogman Senior Member
    8,042
    4,075
    #1: I believe that is what is supposed to happen.
    #2 & 2a: Since the drivers side works, it's obviously not the motor.
    Either the hose is cracked, or the "splitter" is clogged, and/or nozzle
    The splitter is a common issue
    #3: Is the motor running for the rear washer? If it is, again, check for a clogged
    nozzle, or cracked hose.
    It is possible the motor is clogged up, even if it is running.
    Pull the hose off the 2 none working nozzle and see if the fluid is getting to them.
  3. ChapmanF
    18,957
    In fairness, it's only obvious to someone who knows there's just one motor for the fronts.
  4. PriusCamper
    PriusCamper Senior Member
    13,403
    5,412
    Pacific Northwest, USA
    I know Gen2 has a motor for front windshield sprayer and a separate motor in same reservoir for the rear. Did they change that design in Gen3?
  5. ChapmanF
    18,957
    I think it's the same in gen 3. So if I saw one front nozzle spraying, I would rule out a motor problem. But somebody who didn't know that might not.
    PriusCamper likes this.
  6. PriusCamper
    13,403
    5,412
    Yep, OP hasn't cleaned their clogged nozle holes enough yet. Needles work great and removing it from the hood makes it easier to be more thorough.
  7. ASRDogman
    8,042
    4,075
    Any update?
