Hi I have a prius 2005 with code p0a94-555 In indicates that is inverter but the car gets ready mode an it runs on battery ac and everything working in the hybrid part the car moves on batteryin all gears, but ice (internal combustion eng.) Not turning on It had the p1122 also change the part and code clear itself but not change in the other symptoms Ice. Stil not running . The only code is p0a94-555 Thanks in advance Expeting your expertise can help on this Thanks
Generally here you replacing the thing on bottom of inverter under gold plate with lots screws . Good luck getting that plate off . Faster to change whole inverter
Nope. That's also called a DC/DC converter, but it's the one that drops voltage to 12 volts for the low-voltage system. P0A94 is about the other DC/DC converter, the one that boosts voltage to 500 volts for the motor-generators. It's inside the inverter assembly, and replacing the inverter assembly as a whole still is probably the much easier way to go. The freeze-frame in the OP shows "Voltage before boosting" as 208 and "Voltage after boosting" as 207, which could be normal if the HV control ECU didn't want any boosting at the time, but would be a little disappointing if the system was trying to boost. In any case, the P0A94 code indicates the car can tell there's a problem there. The car may not be completely immobile with the boost converter out of commission, but it won't be happy.
Yep another DC to DC converter anyway it is no cost effective to work on inverter . They're getting thrown out all over the country. Can probably find one you can have locally. That's not broken.
Im trying to find a g9200-47121 i was told is a revised version for 2007 -2009 Can it work on a 2005 prius Thanks
I know it'll plug up I just got an 05 I'll probably try it if it fails. The Gen 2 inverter is pretty stout I haven't had any fail yet.
Happy Easter Found an inverter installed today Everythibg fine engine run no mil until I stopped the car in ready mode and the mil apeared aganin with different codes As follows Incude the hyb battery live info also I NOTICE ONLY 3 BARS ON THE DASH MONITOR and I think the batteries are full in the techstream. Thanks in advance
Good day Yes I put a 09 on it they say is mor actualize Today I connect bsrvice plug and battery and the car moves without code , so neither engines are bad , tje question is rhe inverter can run and rhen give a code or when is done is done? May be one of uou had the same experience Thanks
Around 8.2-8.4 V. It varies depending on ambient temperature and the condition/age of the module. In my experience, if you are able to charge to voltages higher than that, it indicates a depleted module. A module that exhibits that trait will probably also charge and discharge faster than the others. Note: A module is made up of 6 cells. As the modules are sealed, it is not possible to do cell-level analysis.
Hi to you all About the car with changed inverter , everyrhing was good no codes until last week the car goes again with the limp mode again with the codes provided in picture maybe someone had the same issue and what could be the problem. Any advice will be appreciated I've change the 12 votl battery and inverter water pump working turbulence seen in tank Thanks in advance
Look at the freeze frame data and tell us what the detail/INF code is. That will narrow down the trouble shooting process for the P0A7A code.
