Fueling trick - How to get your Gen 2 to take gas
Discussion in 'Gen 2 Prius Main Forum' started by gen2enjoyer, Jun 20, 2026 at 6:24 AM.
Tags:
  1. gen2enjoyer
    gen2enjoyer New Member
    Michigan
    Since the fuel tank can be a bit stubborn due to the design I've found that filling just a little bit then going for a short drive and trying again usually helps.
  2. Tombukt2
    13,760
    2,491
    See the flange where you're putting your nozzle at 12 on that flange use a punch and punch two holes . They'll be close to a quarter inch holes or such I can usually run on high to 6.4 gallons then half squeezing to get to 8.4 takes me about 1.5 min to gas up SE USA
  3. Hayslayer
    Hayslayer Active Member
    509
    306
    and pray that you don't create a spark?
    Wth...............this has to be the absolute worst advice ever given.....
  4. Moving Right Along
    Moving Right Along Senior Member
    739
    594
    I’ve found occasional success by rotating the angle of the fuel nozzle to where it’s sideways and filling the tank slowly. But most of the time, it was just paying attention to which station and pump I was using when there were problems and using different ones after that. I always did my best to pump in at least 3 gallons at a time, since that’s what the car requires to detect that there’s added fuel in the tank.
