Red triangle + VSC/ABS while driving uphill
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by stephonicle, Jun 20, 2026.
  1. stephonicle
    stephonicle New Member
    San Francisco, CA
    Hi folks, hoping to get some insight on the following issue w/ my Gen 2 / 2007 base:
    While driving up a steep hill for about a quarter mile, the red triangle + VSC/brake warning lights came on. No loss of power or other noticeable issues, and car drove normally until I could pull over a mile later.
    Turned car off and back on again. Red triangle remained, VSC & brake lights were gone. Basic scan showed no new codes (besides ever-present P0420). I cleared codes, and red triangle disappeared.
    A few miles later on the next steep hill, red triangle, VSC, ABS lights came on again (along with usual check engine). Performed same series of steps two more times with the same results.
    Some addt'l info:
    • Odometer: 124,572
    • I bought the car 3 months ago. Previous owner was removing/reinstalling catalytic converter due to theft concerns. He put it back in a few hours before I picked it up. I drove 5-10 miles before check engine came on (code P0420). It's been on ever since.
    • New hybrid battery was installed 6 months/1,500 miles ago. It's under warranty for two years/24K miles.
    • AC running when warning lights came on (caused no change to AC).
    • Inverter coolant level is normal and shows movement when car is on.
    • Oil, brake fluid, and radiator coolant levels all normal.
    • Battery recharging normally after idling.
    My next step is to get it scanned for any Toyota-specific codes at my mechanic Monday morning. In the meantime, would really appreciate any thoughts from the community. I tried to include as much info as possible, please let me know if I left anything out
    Thanks!
  2. Tombukt2
    13,875
    2,521
    Plug up your scanner and while you're going up the hill and all that kind of carrying on when red triangle is shown look at you're scanner which should be beeping and carrying on during your whole drive it's continuously scanning the car while it's sitting on the seat soon as soon as triangle appears look at scanner or gone etc .? What have you got I don't think Toyota spec codes are going to. Matter. Unless you're using a really really really cheap scanner. So now what if you got when you do it like that.
  3. Brian1954
    Brian1954 Senior Member
    2,694
    1,077
    South Central PA, USA
    The red triangle (master warning light) indicates a problem with the hybrid drive system in the car. You will learn more on Monday when your mechanic gives you the trouble codes.
  4. Brian1954
    2,694
    1,077
    Any updated about the codes?
