Coastel EV switch stopped working?
Discussion in 'Gen 2 Prius Technical Discussion' started by grasshopper, Feb 6, 2007.
  1. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    Since the weather has turned cold, I have not been able to get my coastal EV switch to work. Today I drove about 50 miles in 40 degree weather and when I got to my road I stopped and tried to go into EV mode (by pulling up on the cruse control lever) but nothing. :angry:
    Is this something to do with cold battery or should I disassemble the dash and troubleshoot? I’m beginning to regret buying it. Please tell me that it something simple!
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,195
    Nixa, MO
    When you say you got "nothing" was there a triple beep? Were you on the Energy screen or consumption screen when you tried to engage? What was the SOC of the battery? All green, in the pink, or blue?
    Have you tried again, since turning off the car, to reengage EV? What happened?
    There are lots of reasons EV won't engage and it can be particularly difficult in cold weather for a number of issues. But if you're getting the triple beep when it doesn't engage then you know the circuit is working properly, just that conditions necessary for it to engage haven't been met.
  3. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Nothing annoys me more than sitting still with an idling engine. Unfortunately, Priapus tends to take to this activity when it's -5ºF outside. So occasionally we exchange words and I hit the [EV] button. He triple-beep laughs as me and sits there idling defiantly.
    If not for the triple beeps, I would think that the [EV] were broken.
  4. Priapus
    Priapus Alter Ego
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Feb 6 2007, 12:13 PM) [snapback]386151[/snapback]</div>
    Alright, look it!
    I have this tiny little all-aluminum engine and it gets cold really darned fast. So if you think just because we came to a stop I am going to automatically shut off, you're out of your mind. And pushing my buttons isn't going to change my mind.
    Now, if you really cared about emissions you'd understand that one of the things my engine does is to keep the catalytic converter heated properly. When will it sink into that thick-skulled meatball that I will not shut down my engine when it might sacrifice the proper operation of the catalytic converter?
    And by the way. What do you say you look at the window a little more often. I see you sitting at your desk talking about me. It's snowing out here. Do you care? NOOOooooo. It's 2ºF and snowing! Would it kill you to buy an engine block heater?!
  5. TonyPSchaefer
    14,816
    2,499
    66
    Priapus. We've talked about this. Internet access is a privilege. You are not to be posting here.
    I'm sorry that it's snowing. On the way home I'll play some Jimmy Buffet and we can sing Margaritaville.
  6. efusco
    19,891
    1,195
    Nixa, MO
    Lithium Tony....now!
  7. txav8r
    txav8r Senior Member
    43
    DFW, Texas
    <div class='quotetop'>QUOTE(grasshopper @ Feb 6 2007, 11:57 AM) [snapback]386134[/snapback]</div>
    My coastal EV switch works just fine at 40F as long as the battery state is above 3 bars, the ICE is warmed up, I am at 34 mph or less. Outside those parameters, you get 3 beeps. Are you holding the cruise stalk back for the 2 seconds? That is how it is activated. If it is working, but not available, that will be displayed at the top of the MFD; "EV MODE NOT AVAILABLE".
    The efficiency of this device is another matter. Draining the battery down to 3 bars in using EV causes a longer running time of ICE to recharge. So it is my observation that the only time it is efficient is at the end of a drive when stopping for a longer period of time where ICE will run anyway to warm up when restarted. Or when just backing out of the garage to wash for example is another time to use it. Also, stopping completely to use EV is not efficient either because it take more battery power to accelerate from a stop than to just go into EV once below 34 mph. I find that I am 99.99 mpg once I take my foot off the pedal while decelerating and even if I continue to drive it stays at 99.99 mpg for a period of time while driving below 42 mph until charging is needed or the engine cools to much. So EV is really a toy but used effectively can possible gain some limited amount of efficiency. I give credit to Evan as he gave me most of the insight upfront that I have applied to develope my own usage from.
    I think you might not be holding the cruise stalk long enough to activate...try it, I hope it is that simple.
  8. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(efusco @ Feb 6 2007, 10:34 AM) [snapback]386163[/snapback]</div>
    Wouldn't work Doc, he would just try to feed it to his battery! :)
  9. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    I was on the consumption screen, completely stopped and had green bars. I tried to make it go into EV mode several times but to no avail. No beeping or messages? It had been doing that for about two weeks and that’s why I was getting nervous.
    After reading the replies, I went out and started it cold and tried to put it into EV mode and got the message. That was good news because that meant that the system knew that it was installed. I then drove around for a few minutes and tried again and it worked. So I don’t know what the problem was but it seems to be working for now. It’s probably the PriusChat magic MoJo. Ask the question and all your problems go away. Ouuuuuuuuuu Spooky! :unsure:
  10. efusco
    19,891
    1,195
    Nixa, MO
    <div class='quotetop'>QUOTE(grasshopper @ Feb 6 2007, 07:02 PM) [snapback]386437[/snapback]</div>
    I'm sure this is a combination of cold weather and high battery SOC...green bars is one of the situations that will prevent the EV mode from engaging....sometimes it will with seven green bars, but sometimes not, and almost never with full green (8 bars).
  11. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
    <div class='quotetop'>QUOTE(efusco @ Feb 6 2007, 08:56 PM) [snapback]386478[/snapback]</div>
    Now that is something that I did not know. You say that it won't go into EV mode if I have 8 green bars? Well that got to be the problem because I had it again today and I knew that I was fully charged. It doesn't seem to make sense that it won’t work when fully charged, :huh: but if you say it then I believe it. Thanks.
  12. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    I've definitely noticed a correlation between temp and the EV mode not responding. I've held the stalk for way longer than two seconds and I get nothing. No beeps. I've never seen a message displayed... ever and I've had ev toggle installed for over a year now. Is that a 2006 thing?
  13. aaf709
    3,862
    2022 Prius Prime
    <div class='quotetop'>QUOTE(tripp @ Feb 7 2007, 06:35 PM) [snapback]386770[/snapback]</div>
    Yes it is. Just goes to show how much EV software there is in the Prius, considering we're in a country where the EV mode isn't available.
  14. efusco
    19,891
    1,195
    Nixa, MO
    <div class='quotetop'>QUOTE(tripp @ Feb 7 2007, 08:35 PM) [snapback]386770[/snapback]</div>
    Yea, started w/ the new MFD on the '06.
    I definately experience odd EVb behavior in the cold sometimes as well...I'll get a beep (from the CAN-View) suggesting it's going into EV, feel a 'bump' as it seems to try, then goes right to regular ICE -on mode without entering EV. Sometimes I get nothing. it all varies.
    Regaring the high SOC...that's one of the well documented conditions that prevents EV from engaging...I don't know why.
  15. tripp
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(efusco @ Feb 7 2007, 07:41 PM) [snapback]386775[/snapback]</div>
    Well, I'm glad I'm not the only one noticing this. I don't see green very often, the highest I usually get is 6 bars. I've noticed that I don't even really need to activate EV when the SOC is really high though. The car seems to go there itself until the SOC comes back down into the blue. The few times I've had 8 bars the car runs almost exclusively off of the battery unless I demand a lot of power (which I don't, I just let the car do its thing).
    This winter's been much colder than last year so I havn't been able to ev as much. Hell, there have been a number of days when the ICE starts up almost immediately upon boot up. Way faster than 7 seconds, more like 0.5-1.
  16. efusco
    19,891
    1,195
    Nixa, MO
    <div class='quotetop'>QUOTE(tripp @ Feb 7 2007, 09:17 PM) [snapback]386801[/snapback]</div>
    That's interesting. My Prius does the 7 sec. thing no matter what (unless I high the accelerator hard). But my HiHy starts the ICE immediately when it's cold. Perhaps they changed the programming for that after the '04.
  17. tripp
    4,717
    79
    Denver, CO
    <div class='quotetop'>QUOTE(efusco @ Feb 7 2007, 08:21 PM) [snapback]386805[/snapback]</div>
    It seems to do this when the temp is < 15F but I haven't really kept tabs on it. Next cold snap I'll see if I can't gather better data.
    Now that my sailboat is in the garage the Prius is parked in the driveway so the engine is pretty much at OAT when I start it up in the morning.
  18. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(tripp @ Feb 7 2007, 07:17 PM) [snapback]386801[/snapback]</div>
    The only time I haven't been able to go into EV at cold startup (and this has been down to 0F), has been when other conditions haven't allowed (e.g., state of charge). The only times that I haven't had ~ 7 seconds were when I wife had left the defroster or AC on when powering down.
    Are you certain that the defroster hadn't been left on?
    Dave M.
  19. mrbigh
    3,686
    699
    Long Island, NY
    My Coastal EV switch always worked erratically and mostly under cold temperatures, not to long ago I started using the relay driver from CANview and comparing operations of same and 95 % of the time when Coastal EV didn't engage the EV mode, the hard connection from the relay activated through CANview :D provide me the necessary EV mode in the Prius. So, under my Lupe, the Coastal EV product is not a perfect operating piece of equipment yet, or at least the one I have. After 2 emails sent regarding this to the guys @ Coastal with not answer, I decided to give up the case. Their customer support is well known already in this forum. :p
    It is a great product and I love it when worked right, but......
  20. grasshopper
    grasshopper Member
    425
    Myrtle Beach SC
