Fillers in the Gasoline
Discussion in 'Fred's House of Pancakes' started by Leadfoot J. McCoalroller, Jun 29, 2026 at 6:05 PM.
  1. Leadfoot J. McCoalroller
    8,257
    7,760
    Pennsylvania
    2018 Prius c
    Hi!
    I'm here to start a conspiracy theory that refiners are doing... things... to stretch gasoline products.
    Working through the conspiracy theory checklist, I have:
    • No proof
    • Sketchy anecdotes that support my conclusion
    • Time to kill
    • Access to a public platform
    • No access to petroleum QC equipment or methodology
    So, in the past 48 hours I've seen a new Jeep throw some rumbly misfires. A brand new Nissan Altima did the same- a car I rented from Hertz in Minneapolis a few days ago. Then, an hour ago, my own Mazda in Pennsylvania had an odd stumble in the idle when I drove it to the market.
    Are refiners allowing more junk in their retail gas lines? 2% water instead of 1%? I'm the wrong kind of petrochemical engineer to be doing detailed roadside analyses of fuel products.
  2. PriusCamper
    PriusCamper Senior Member
    13,364
    5,402
    Pacific Northwest, USA
    Clearly this is a counter-conspiracy theory that the corn lobby paid you and your colleagues big money to propagate because there's about to be a huge announcement about damage from ethanol in gas to finally being well documented enough that Gen3 Prius owners, as well as owners of many other makes and models will be able to file endless class action lawsuits against the corn lobby who's been providing falsified data for decades. Stay tuned to: http://www.pure-gas.org if you want to find out the truth!
  3. bisco
    52,740
    I haven't noticed anything in my bolt
  4. futurist
    futurist Member
    57
    174
    United States
    2024 Prius
    5G runs fine... but exclusively buy from one Top Tier station, and use midgrade vs. bathwater.
  5. ETC(SS)
    7,472
    That's OK.
    As we see here in PC, lackeys (or useful idiots) for the API have been banging on that drum since those HORRIBLE days during the Carter years when they started putting hooch in gasoline.
    2% water in gas?
    Really???
    I would think that PRIUS people above all others would be the FIRST to repudiate that idiotic notion!
    As in.....WHAT causes the Prius Death Rattle?!?!
    SO....
    Water and Gas do not get along well - and water is heavier so it will settle into the bottom of the tank when the car is parked.
    The API lobby is always yammering on about how E10 absorbs water.
    The API tells them to say "hydroscopic" a lot so people will think that they know what they are talking about - but HOW MUCH WATER will E-10 absorb before it becomes saturated - AND....what happens after THAT?
    eh?
    (I'm betting that this amount is a LOT less than 2%!!)
    Not all cars have comically small gas tanks - but SOME do....so we will use a 15 gallon "fill-up" as an average.
    2% water in a 15 gallon fill-up is not "a few ounces" - it's 0.3 fluid GALLONS......38 OUNCES! 4.75 CUPS!
    These are, of course, 'freedom units' but even if you throw down the 'metric' card 2% or even 1% is a NON TRIVIAL amount of water.
    Think that's going to get "absorbed" by the ethanol?
    Think it's going to be mixed in with the gas, or swirl around like some "lava lamp?"
    I don't!
    I think it's going to hang out in the bottom of the tank......where the FUEL PUMP is.
    That means that it is possible that you will get a bunch of MOSTLY WATER injected into your cylinder bores at some point.
    I doubt the car would even START with that much water in the gas and it it DID start I doubt you'd be knocking down 30+ MPG!!!
    One of the reasons that I really do not mind using Walmart gas is that the media (which is to say leftists) HATES Walmart - and we ALL know that they hate "Big Oil!"
    If their fuel was CONTAMINATED by water, just how long do you think it would stay quiet? ;)
    #5 ETC(SS), Jun 30, 2026 at 4:47 AM
  6. ChapmanF
    18,919
    On the mad overnight drive in my parents' car to drop me off for new student week at college, we stopped to fill up at some nondescript station that we found open at that hour in Nowheresville, Wisconsin. The car ran ok for several miles afterward. It was then very rough, and we weren't at all sure we would get to where we were going, or even to the next open station.
    We did manage to rattle in to another open station, far enough down the road that the tank could take enough more gas to achieve a better ratio in there, and the car ran ok after that, apparently no lasting damage done. Of course we never determined an actual percentage of the contaminant, or what the contaminant was, though water seemed most likely.
    I know it's chic to complain about regulation, but I've noticed in my later life I've been able to fill up anywhere from big-name chain stations to tiny Nowheresville ones and have never had that happen again, and to me that's a modern-life improvement...
    PriusCamper and Trollbait like this.
  7. ETC(SS)
    7,472
    I would submit that in these salad days of hyper-communications that it's a lot tougher for sketch gas regardless (or irregardless - whichever is the real word) of government regulation/intervention - although the threat of either is enough to keep vendors honest.
    There are petrol stations a plenty and competition is ever the more efficient 'regulator.' ;)
  8. futurist
    futurist Member
    57
    174
    United States
    2024 Prius
    I hate Wally's just because the worst of the human race tends to manifest their upbringings there. Still shop there tho :p
    But if a better deal's at TGT, buh-bye ;)
    Go to the petrol station I do, because 1) it's a Local institution I don't want to go away... and whilst they aren't even in the same universe as Publix-level customer service and attention to detail, for example... 2) the gas has never not been good.
    Not sure who's in charge out here on the space station to see that thru for 76... but it's been good as long as lived here, and the slight difference at Wally's isn't enough to allay fears of their overworked and underpaid staff just punching a clock and doing the bare minimum, when it comes to fuel quality -- they certainly aren't afraid to show their indifference with everything else about the store :rolleyes:
  9. ETC(SS)
    7,472
    I pump my own fuel, and use NFC payment at the pump, so I'm not there to socialize- but I've found that the attendant at MY local Wally is quite friendly.
    Several of the kids in my church work there and they all make about $18 an hour if they're being honest.
    The Local HD pays $20.....
    TIFWIW.
    John321 likes this.
  10. Rmay635703
    Rmay635703 Senior Member
    2,684
    1,722
    Somewhere in Wisconsin
    2013 Chevy Volt
    There were overseas emulsified fuel companies claiming an improvement in emissions and a reduction in diesel use, but you had to burn through a tank of fuel in around a month. Even some testing doing that with gasoline which is more sketchy.
    and of course hydrous ethanol fuels exist in Brazil .
    to do the above here would require modifications to our laws and standards.
  11. John321
    John321 Senior Member
    1,494
    1,425
    Kentucky
    They also have a college tuition assist program for their employees to take advantage of.....
    "Walmart’s Live Better U (LBU) program is designed to help employees advance their education and career opportunities while working at Walmart or Sam’s Club [​IMG]Scholarships360+1. The program covers 100% of tuition and textbook costs for eligible associates, eliminating financial barriers and allowing employees to pursue high school diplomas, undergraduate degrees, or professional certificates [​IMG]Scholarships360+2. Unlike traditional tuition reimbursement programs, Walmart pays the costs upfront directly to partner schools, so employees do not need to pay first and wait for reimbursement"
  12. Trollbait
    12,798
    Water injection is an old concept for improving performance, efficiency, and emissions. Emulsifying it in the fuel gets around installing extra equipment.
    A northern European country used to have hydrous ethanol 15%. Removing the last bit of water, and keeping it out, of ethanol isn't easy, so hydrous is lower cost. The water in there also protects aluminum parts from the ethanol.
  13. PriusCamper
    13,364
    5,402
    In general if you're doing gas additives you want to run it through ASAP. Unless of course its a fuel stabilizer for storage, but storing on a near empty tank with a plan to put 5-gallons in before starting it after storage is way better than fuel stabilizer.
  14. futurist
    futurist Member
    57
    174
    United States
    2024 Prius
    I used to work for $9 an hour Y2Ks, and that covered rent, food, sundry expenses (like internet and phone) + owning a car. Today? There's a reason I charge what I do for my work -- it barely covers living costs + a tiny bit of margin if anything ugly happens.
    Wherever you live now, I'll bet those kids getting $18/hr, pay less for all four, than we do here. So, underpaid? Yep (n)
  15. T1 Terry
    T1 Terry Senior Member
    959
    534
    :ROFLMAO: I'm not sure if this thread is supposed to be satirical or not, but I am getting a good laugh.
    Methylated Spirits, or denatured alcohol as it's known in the USA, was legendary for improving petrol octane and getting rid of water out of a tank of fuel, every bar stool mechanic would bet their life on how well it worked ....... yet the same bar stool experts will tell you that ethanol will destroy your engine, eat all the alloy and cancel any future birthdays.
    This was one of my favourite pub tricks, get an audience around the local font of all knowledge and steer them onto the path of the wonders of adding "Metho" to the fuel tank ... till they had all the nodding heads going, much like you see behind a politician making a speak at their podium or a press conference ......
    Once I had that generally accepted through the gathered crowd, I'd mention E10 and ethanol in the petrol, like dropping a burning log into a tank of alcohol ..... red faces and spitting while they spoke, the full works regarding how bad it was for any engine ... when they calmed a bit, I'd collect the bottle of metho out of the car and ask them if they could tell the folks what metho was made from (everything over here has to be labelled regarding the contents) 99% ethanol, that is why the alcoholics drank it, it was the methanol they mixed with it pre the being sued for adding anything that could injure or kill someone without a poisons information label being attached, it was then removed, but the meth part of the name remained ..... it is also the stuff the moonshiners make in their stills and water down to sell to their customers so they don't kill themselves .... not good for business.
    Now, if you think you can see the layer between the alcohol and the water in the next alcoholic drink you have, you should maybe stop drinking ......
    As an added piece of food for thought, the "Super Car" series over here in Australia, were running 85% ethanol, it might be down to 80% or so now, yet they produce engine power that is out of this world ..... top Alcohol and the Nitro class use it to mix with the nitromethane ......
    The fact ethanol can carry more than 50% water by volume before it becomes non flammable (the old under proof/over proof rum, could it hold a flame) makes it a great fuel additive, along with toluene/exylene ( https://grassrootsmotorsports.com/articles/toluene-or-xylene-fuel-tips/) or basically paint thinners, sold for years by BP Petroleum as Methyl Benzene, until it was exposed to be a made up name by BP and was actually toluene added to standard fuel. BP did a massive clean up campaign spreading the rumour that the whole Methyl Benzene was a made up parody and BP denied ever advertising their fuel contained it ...... but I did find this from the National Film and Sound Archives
    Bob and Dolly Dyer's BP Pick-a-Box was a legendary Australian radio and television quiz show. Sponsored by BP from 1959, the TV show featured the famous "Money or the Box" catchcry and ran until 1971. BP’s advertisements of the era heavily promoted premium fuel containing methylbenzene (toluene). [1, 2, 3, 4, 5]
    Fuel dilution has been an ongoing problem over here in Australia, both petrol and diesel, I once was caught out at a fuel distributor service stn outlet (mixing tanks advertised as storage tanks out the back taking up a very large area) the tanker driver must have dropped the "additive" into the wrong tank intake pipe, I had 1/4 tank when I filled up and made it less than 1 km to workshop yard, where the Hilux ute died ..... stripped the carby down and poured the fuel into a tin, it would not burn and left a white powder when it evaporated .... they paid me twice the premium fuel station price for a full tank of fuel in exchange from the fuel I drained from the tank ..... suited me fine, the company had paid for the fuel fill anyways :LOL:
    T1 Terry
    futurist likes this.
  16. futurist
    futurist Member
    57
    174
    United States
    2024 Prius
    Since there are experts on this topic in the thread... a testament (I think) and a question :D
    Whilst living in WA, used Heet in my SV650 commuter year-round but esp in the winter. If you want evidence water in fuel can ruin your day when it's -5C / 23F on the commute... just get a blob or two in your float bowls above freezing, let it set overnight... then try to commute needing ride the snow between tracks, as the tracks're too black-ice-y :LOL:
    There's the yellow bottle (isopropanol), and red (methanol -- called Iso-Heet, in a twist :rolleyes: ). Tried both in this use case, & red worked best by a long ways, all else being the same. Didn't notice any degradation of the fuel-touching components on disassembly, organic or metal -- nor weirdness on the exhaust side either (Akropovic stainless headers and can). Got much better fuel economy and starting too boot, red vs. yellow... but only in winter. In summers, used it mainly to slow down gumming a bit if needed sit (and on 39C / 102F days in summer on Kitsap Peninsula -- which shocked the f*** out of me, 1st time -- does help).
    Since carburetors have open access to atmo by nature... means the fuel's constantly exposed to ambient humidity too -- which in a place with glacial moraine troughs and drumlins as the rule, means over 27C / 80F, it's effin' muggy summers. Why was the isopropanol formulation so much less effective than methanol?
    Didn't and doesn't matter, as it worked :D ... but curious as to why the difference in a 11.5:1 compression 4-st carbureted vehicle, when the difference in my 9:1 EFI Paseo was minimal to none?
