2019 Prius Slow Coolant Leak
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by JeffPGH, Jun 25, 2026 at 3:51 PM.
  1. rjparker
    10,931
    6,856
    Sounds like just the ac and fans were running at first then the rattle on engine startup.
    But you are losing a lot of coolant in one day. If it was coming out at the exhaust heat exchanger I would expect some steam soon after the exhaust heated up.
    With that much coolant loss the combustion leak detector test might be an easy test without having to remove the windshield wiper assembly to access plugs.
    Any shop could do that test as well.
    If it is negative, you could do the exhaust heat bypass or move straight to a borescope test with the specific setup as described in item 2 of post 16 and as demonstrated in the videos.
  2. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    I have a few updates.
    I did 166 miles yesterday after I filled it up in the morning and when I checked it this morning it was right at the low line.
    I was at the dealership today for my complimentary oil change and I spoke with the guys there. They said the overnight pressure test they did included looking at the engine with the borescope. According to them it looked good. However, they did say that when I’m running it and it’s getting hot it might possibly open up a small crack and start leaking. They said it would never get that hot here in the shop. Since I’m coming in soon (in about a month) for my coolant flushes he said I could try the stop leak stuff to see if it helps and anything left in there would get flushed out during the flush. I figure the stop leak stuff is kind of a last resort right? I don’t really want it to risk it messing anything else up. How safe is it to use? Also, while they’re doing the coolant flush I’ll have them do some tests on the water pump and check it out.
    I was thinking my next step would be to try the combustion leak test just to see if that does turn up anything or not but It probably won’t if they did a good job on the borescope test. If that doesn’t show anything I was thinking about doing the bypass just to confirm 100% if it is the new heat exchanger pipe or not.
    Does that sound like a good plan?
  3. Brian1954
    Brian1954 Senior Member
    2,637
    1,048
    South Central PA, USA
    What was the engine coolant temperature during the trip?
    Do NOT use the stop leak. That is something you use as a last resort
    Danno5060 likes this.
  4. bisco
    52,739
    just before you sell the car :D
  5. BiomedO1
    4,464
    2,350
    Left Coast
    Are these the same people that claimed you passed the coolant leak test???? Why would they suggest you place stop-leak into a system that they declared; there was NO leaks? I've never heard of a "professional" shop suggest putting stop leak into a cooling system - sorry, that's usually the purview of a shade tree mechanic or used car lot. Cover-up the symptoms so they can make it someone else's problem.
    I would find another shop; preferably a Prius specialty shop or an old mechanic that knows how to test and find problems - rather than just point a parts cannon at cars.
    Good Luck......
    FWIW; metal expands when heated; so their theory that the leak is caused by heat - doesn't really hold water. Historically, on Prius coolant leaks happen when cold, because the aluminum block contracts and separates from the head gasket. As the engine warms up, the aluminum expands and closes the leak.
    Easy to prove; do a coolant leak test when the engine is at operating temperature. Simple - NO GUESSING. I still think they messed-up the initial coolant leak test or just didn't do it properly - because your coolant is going some place and that's the fact.
    #25 BiomedO1, Jun 29, 2026 at 1:48 PM
  6. rjparker
    10,931
    6,856
    Keep in mind most service advisors have never been mechanics. Most dealerships might have one Master Mechanic and he may not have performed your borescope test OR the exhaust heat exchanger is leaking again.
    This should be the last resort primarily due to its potential to clog up heater and radiator heat exchangers AND the difficulty to actually get it out, even right away. The term flush is used loosely, the standard coolant change is a drain and fill which leaves almost half of the coolant in the system. The coolant system also has multiple parallel paths which makes a real flush difficult.
    This is a good idea if you do it quickly. You should not be piling up 200 miles a day with this issue. If you are not in engine replacement mode yet you could soon be there.
    In defense of the service advisor, stop leak can be diagnostic of a hg leak if it stops the coolant loss. But if I were his defense lawyer in court and the prosecution had an expert witness, I would lose.
    #26 rjparker, Jun 29, 2026 at 1:55 PM
  7. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    I did the block test with the Prius in maintenance mode to keep the engine running and it stayed blue. I also noticed that it is not going down the same amount per number of miles. Sometimes it goes down a lot and sometimes it goes down a little with more miles than other days. Since they already did the pressure test with the borescope I don’t think it’s the engine. Since it’s going down at different speeds is it more likely a water pump sticking without throwing any codes or the new heat exchanger pipe they put in? Or something else?
    Coolant Leak Tracking
    • 6/26/26 Put on new cap
    • 6/27/26 344542 Coolant was a little below the Low line. Topped it off to Full after it sat all night.
    • 6/28/26 344768 (226 miles) Coolant was about 1.5 inches below full line…. It was below the low line. Topped it up to full
    • 6/29/26 344934 (166 miles) Coolant was right at the Low line. Topped it up to full.
    • 6/30/26 345168 (234 miles) coolant was halfway between the Full and Low line. Topped it up to the Full line.
    • 7/01/26 345414 (246 miles) coolant was almost at the bottom of the reservoir. Put the Prius in maintenance mode to keep the engine running and did the block test. It stayed blue. I put the tester by the exhaust pipe and confirmed that it started turning green. Let it cool down and topped it up to the Full line.
  8. rjparker
    10,931
    6,856
    A hg leak is rare on a gen4 but could happen after a serious overheating event.
    The thermostat must be open and coolant circulating with the engine running during a combustion gas test. That requires full operating temperature first and perhaps switching to maintenance mode second for continuous engine operation.
    Even then, a hg leak may seal up at operating temperatures. Your coolant loss seems higher than a normal early onset hg leak.
    It passed the borescope test. No obvious leaks. It points at the exhaust heat exchanger again. I would bypass it. Again. If a bypass fixed it I would leave it bypassed and force the exhaust heat mechanical thermostat into its extended, warmed up state.
    Gen4 Coolant Flow
    Exhaust Heat Control Valve Forced Open on a Gen3
    Exhaust Heat Recirc Actuator 2of4JPG.jpeg Exhaust Heat Recirc Actuator 1of4JPG.jpeg
    Finally, a borescope test can provide a false negative if done by an inexperienced person. A exhaust heat bypass that does not solve the issue points right back to the hg.
    #28 rjparker, Jul 1, 2026 at 12:10 PM
  9. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    Thank you. I tried to get it up to operating temperature but there is no gage on the dash so I just did my best. I think I’ll try the bypass again and see what happens. If I can prove it is a bad heat exchanger I should be able to get them to replace it again for free since they just replaced it. The trouble is they keep saying it’s a new part and it is the redesigned on so it is probably fine.
  10. rjparker
    10,931
    6,856
    Many have been frustrated by assumptions that a new part can't be the issue. If nothing else a bypass is an easy diagnostic.
    Again, no obvious releases points to a exhaust heat exchanger or a hg, both of which vaporize coolant out of the exhaust.
    A borescope test looks for "steamed cleaned" pistons, sometimes a clean spark-plug like you show in post 1 and, sometimes coolant in the cylinder or a drip from the head gasket. Seeing it drip takes a quality articulating borescope on a cold engine with a manually pressurized cooling system. Often requiring the car to be left overnight and not started. Room for error.
    #30 rjparker, Jul 1, 2026 at 12:29 PM
  11. rjparker
    10,931
    6,856
    I would also monitor the coolant temperature in real time as noted before using a simple bluetooth scanner and a phone app or a dedicated obd2 display.
    #31 rjparker, Jul 1, 2026 at 12:46 PM
  12. JeffPGH
    JeffPGH New Member
    Thursday
    Pittsburgh, PA
    2019 Prius
    I did leave it overnight for the pressure test so I hope they did it correctly. I tried using my Blue Driver OBD II app to monitor the temp while I was doing the test. I might get one of those HUDs for the future. IMG_0106.png IMG_0108.png
  13. Brian1954
    2,637
    1,048
    You should be monitoring the coolant temperature while driving. That is the only way to rule out an intermediate water pump. I thought you were going to do that.
  14. rjparker
    10,931
    6,856
    Use your app while you are driving to verify the engine stays below 210f with typical engine on temperatures around 195f or less.
    Also note in post 31 there are two "engine" temperature sensors. My gen3 experience is the engine temperature is a bit higher than the exhaust heat exchanger when the engine coolant is warmed up.
    This "Car Scanner" app trending capture shows full load peaks when driving up a steep grade several times with ac on in the summer.
    Each horizontal axis time period is 8 minutes
    Note how much the engine cooled in the last segment. That period was Ready engine off with the ac on and represents the rapid thermal cycling a Prius can experience. It was followed by one more high load hill ascent.
    #34 rjparker, Jul 1, 2026 at 1:13 PM
