P0A08 and I have to pee! Can I drive at all?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by PriusPaddler, Jun 30, 2026.
  1. PriusV17
    PriusV17 Active Member
    440
    207
    CA
    2017 Prius v wagon
    I would just change the 12v first. 9 years is long considering typical lifespan is 5 years. That code's primary cause is a very weak 12v battery. I'm changing my 12v quite frequent. Because once it's drained, it's damaged and not the same. I'm now on the 12v Sodium Ion version. Just the switch alone reduced 20lbs of weight. So far pleased with the switch. If I have to reset the battery it's just a button on the battery.
    PriusPaddler likes this.
  2. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    I understand that idling in heat will be hard on a car... this time was not planned, just was mixed up schedules between my son and I meeting to move him out of an apartment and I did some work in the car waiting for him. I'm just curious how the people who camp in their prii handle that? With my 2009, I remember choosing to sleep in my car once vs setting up a tent at 11pm, but it was so hot out (in SD in September it was over 95 degrees) that I ended up rolling up windows and sleeping with A/C on. That would have been 5 hours or so... maybe I just got lucky.
    So - sounds like I'm headed to a dealer no matter what. Exactly what I was hoping to avoid. $230+tax just to walk in the door and that amount of money is hard for me... but of course as you point out, better than damaging entire engine. I guess I need to encourage one of my mechanically inclined children to get certified!
    I did tell them to move forward replacing the original 9.5-year-old Yuasa 12v battery.
  3. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    I had them proceed - they were kind of astonished, given the car was put into service in late 2016. That needed to be done even if it doesn't solve anything else. Glad you like your new one. Hopefully you don't have reason to reset it often.
  4. Brian1954
    Brian1954 Senior Member
    2,677
    1,071
    South Central PA, USA
    The shop is not using Techstream, but it looks like a good scanner. It was able to scan 20 different ECUs.
    The first three codes are the ones to concentrate on fixing. I will try to find the service manual for those and post links in a later post.
    Did you check the engine coolant level in the plastic reservoir? Have you added coolant?
  5. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    I have personally never had to add coolant. I only checked the small reservoir for the inverter coolant, but the shop said they checked both and it was fine.
    Brian1954 likes this.
  6. rjparker
    11,096
    6,962
    The B1503 means the coolant temperature sensor downstream of the exhaust heat exchanger exceed 248f. Normal it is around 195f, typically not exceeding 210f even under high load.
    Often the engine coolant temperature does not code, perhaps because the exhaust heat exchanger sensor codes first and the system starts shedding loads.
    Two causes are typical, one is the main water pump or thermostat has failed or is weak or second, the exhaust heat exchanger is stuck in a mechanically controlled fast warm up mode.
    Often normal shops don't know an exhaust heat exchanger exists much less are reading its live data.
    The typical advice is to bypass the exhaust heat exchanger and see what happens next. Repair by the book is replace it which can be $2k or more. Bypass is the better diagnostic move and in most states is no problem long trrm.
    Monitoring these temperatures while driving with the ac on can be helpful and your shop could do it.
    Others who have had this code found the engine temperature sensor remained normal but the exhaust heat exchanger caused issues. With your "too hot to touch hood", etc it may be more fundamental whole engine overheating.
  7. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    Here is the latest word on AC from mechanic:
    "I checked both the pressures in the AC system and I believe that the system is overcharged. Therefore, at idle the pressure gets too high and the system shuts down. Cleaning the radiator is recommended, might help, but does not fix the underlying overcharge situation. We can do the cleaning first and see if it gets us close enough or not. And it needs to be done regardless. Other possibilities exist, but all further AC diagnostics require starting with a known properly charged system so it is our first step after the radiator cleaning. Short term, you can leave it, but it is stressing out the compressor."
    EDITED TO ADD - I have never charged or recharged the AC, so it has gone 45k miles "as is" from the dealer in January 2025. Problem at idle started this year, whenever Minnesota warmed up.
    And on overheat:
    "I believe the code and overheating hybrid cooling system is due to a failing water pump. I can't prove that."
    Sooooo. New 12v battery is in... *** Do I move on with either evacuate and recharge the AC? or the radiator clean (they say they have adapted a tool to do this well, but still charge a couple hundred $$)? And hope that whole improvement reduces the chances of overheating?
    First three codes are P0171 (never saw that before myself - could be gas or O2 sensor maybe?), P0A08, and then B1503 (also I've never been able to read that before).
    I like the approach of fixing one thing and then seeing the fallout before moving forward. BUT I'm not sure swapping 12v will be the end of it - what would be the next logical step? Hard to say if I have one problem or two... (or more)
    Do I get the car back and drive without AC and see if it ever overheats again? Or fix the AC and then wait and see? I do a LOT of driving on rural highways where I will be pretty good and stranded if it gives out on me. Not sure how long I can last without AC either - I start melting, lol.
    #27 PriusPaddler, Jul 1, 2026
  8. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    @rjparker I was typing while you were. I will digest your posts and read the links. Thank you.
  9. rjparker
    11,096
    6,962
    You did not see the codes because Dr Prius is not that good for most codes.
    Fix the ac charge first. Cleaning the outside of the condenser is logical. Delay "cleaning" the radiator or a radiator drain and fill. No 12v battery unless it fails a load test.
    He is guessing on the water pump and apparently does not know the b1503 is pointing to the exhaust heat exchanger.
    Engine water pump is good preventative maintenance but only if he uses an oem pump. Aftermarket pumps fail quickly.
    #29 rjparker, Jul 1, 2026
  10. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    He was proposing cleaning radiator FINS I think... not necessarily drain and fill... is that helpful at all? It could be full of the guck in the air or dog fur that floats around my yard like clouds.
  11. Brian1954
    2,677
    1,071
    Why does the mechanic think the hybrid cooling system is overheating? The B1503 code is on the separate engine cooling system.
    The P0171 lean code is usually a leak at a vacuum hose. A scanner that can read live data is very helpful with fixing the problem.
    I agree that the AC should be fixed first.
    #31 Brian1954, Jul 1, 2026
  12. rjparker
    11,096
    6,962
    Fix the ac charge first. Cleaning the outside of the condenser is logical. The radiator is behind the ac condenser.
    He is guessing on the water pump and apparently does not know the b1503 is pointing to the exhaust heat heat exchanger.
    See this post from earlier today about the almost free bypass. 2019 Prius Slow Coolant Leak | Page 2 | PriusChat
    #32 rjparker, Jul 1, 2026
  13. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    I just looked at my own records and saw that I replaced the water pump in December 2025, about 16,000 miles ago. Was just done at my local mechanic - totally trustworthy but not hybrid specific. So, this is the first summer on that water pump. I will call them and see what brand they would have typically used.
  14. Brian1954
    2,677
    1,071
    Which pump was replaced, engine or hybrid cooling system?
  15. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    Engine water pump. I see the bill, but can't tell the brand of replacement they used. Can call when they open tomorrow.
  16. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    FYI - the shop where it is now, they stock Japanese Gen 3 replacement engines... because of the demand. Apparently Japanese replacement engines are very low miles? They used to retrofit Gen 4 engines in there, but can do these Japanese ones for much less money I guess. Interesting approach.
    Battery tested as "very weak" for whatever that is worth.
    #36 PriusPaddler, Jul 1, 2026
  17. PriusPaddler
    PriusPaddler Member
    226
    52
    Twin Cities, MN
    Thank you!
    My brain is dead for tonight, but I'll check those out tomorrow. Main mechanic is gone until Monday now. But I believe I can direct any of the changes to proceed with his team tomorrow, just probably no more diagnosing...
  18. rjparker
    11,096
    6,962
    They are called JDM engines, used in Japan engines imported here. You can win big if you get a 2020-21 gen3 engine from them which were still sold overseas. However there is no vin or carfax tracing of years. Around here the engine is about $1k from a JDM distributor.
  19. Mendel Leisk
    42,343
    JDM = Japanese Domestic Market
