How long before that new car is just a throw away item?
Discussion in 'Fred's House of Pancakes' started by T1 Terry, Jun 18, 2026.
  1. T1 Terry
    T1 Terry Senior Member
    959
    535
    This is an exercise carried out by the Victorian fire service to train on how to handle EV fires ....
    this one is deliberately damaged using a portapower ram to puncher the cells, after cutting two holes in the battery case so creating a flow path for the fire ..... watch when they drag the fire blanket out, the fire is all over, just needed sand bags around the edges to hold it down.
    When the trucks go up over here, all they can do is try to control where the diesel runs off to down the drains so they don't set the local waterways on fire as well ..... the trucks burn till there is nothing but a twisted chassis and an engine block, even the bitumen under the truck is destroyed and the road repair crews have to dig up that section of road and relay it from the packed rock layer up .....
    T1 Terry
    EDIT:
    This is the long version if you are into watching fire fighting failures, how someone wasted half a million dollars on a chemical to add to the water that simply doesn't work, you can see the person who was going to get a new butt reamed for him, he's the chief looking bloke who keeps getting in front of the camera
    #61 T1 Terry, Jun 26, 2026 at 9:25 AM
  2. John321
    John321 Senior Member
    1,494
    1,425
    Kentucky
  3. BiomedO1
    4,469
    2,351
    Left Coast
    :D:eek::LOL::ROFLMAO::whistle:
    #63 BiomedO1, Jun 26, 2026 at 11:17 AM
    futurist likes this.
  4. Trollbait
    12,799
    Forgot to mention I didn't bother with the video at all.:cool:
    Knew Na-ion was around that of LFP in terms of energy density. LFP is already becoming the most common EV chemistry because of costs, so I don't see Na-ion not succeeding when it comes to market. The issue, in the US, is the charging situation. 250kW and higher chargers existing doesn't mean they are available. Fast charge rates won't help the car owner if there isn't a charger around that supports it.
    Talk of structural batteries from manufacturers seems to be implying the cells being even more integrated into the chassis. So dropping the battery from under the car for service or replacement becomes more difficult
    They use to bring in a back hoe to bury VWs with a burning magnesium engine block on site.
    No longer a need to mention the giant fire blankets. It is just a question of time until all departments have them. They, and water tanks, don't solve the built in oxidizer issue. An EV is going to require a far longer fire watch than an ICE car no matter how the fire is handled.
    Is the equipment for the foam just not practical for such use?
    They could also use an even bigger fire blanket;) Such will be needed for EV trucks.
  5. ETC(SS)
    7,472
    Gasoline has its 'little problems' too.
    What EVangelists seem to be forgetting is that they only got to the party about 20 years ago - which is a lot longer than it took humans to adapt to using gasoline.
    Because my beloved government is ever struggling to thwart the beneficial side effects of Darwinism, we're STILL having to modify store-bought gas cans to make then usable by normies.
    Petrol cars almost never explode when they catch fire - but humans can (and do!!) die horrifically when they are involved in an accident which traps them in a burning car (or bus!) before they can get out safely.
    The human animal's 'super power' is adaptability - NOT ethics.
    It only took about 15 minutes after the invention of the paid parking lots for somebody to invent like one-way directional tire shredders to prevent people from driving the wrong way out of their parking lots to avoid the toll.
    Meanwhile?
    Drunks and elderly drivers still harvest human lives on our interstates by somehow winding up in the wrong lane.
    #65 ETC(SS), Jun 26, 2026 at 1:14 PM
  6. Rmay635703
    Rmay635703 Senior Member
    2,684
    1,722
    Somewhere in Wisconsin
    2013 Chevy Volt
    Lifepo4 were also supposed nonflammable but several large grid fires involved the casings and other materials burning
  7. BiomedO1
    4,469
    2,351
    Left Coast
    Any battery can burn; but my understanding is that anytime a Li battery is punctured or shorts out - it can become a self sustaining fire; with the metal battery casing giving you time to evacuate the car. Unable to be put out by any of or current conventional fire fighting means.
    Do you have the reference article that states Lifepo4 batteries are nonflammable? I know a couple of labs re-configuring the process to make them less subseptable to thermal runaway and from punctures/internal shorts - so they don't go up in smoke as easily.
  8. ETC(SS)
    7,472
    I use LiFePo4 batteries for field radios - and I don't consider then to be 'Non-flammable' and neither do airlines - but then try getting through TSA with ANY detectable amount of gasoline. ;)
    I'm limited to 100Wh batteries.....up to 20 if I want to bring that many, although I would expect questions from the TSA about it.
    Although batteries still suffer from a yuge energy deficiency versus petrol - even Li-Ion batteries are a 'little' more stable than some $50 nanny-state approved, 'EZ-Spill' - three hands-required gas can that even SMELLS like it once held fuel. :unsure:
    #68 ETC(SS), Jun 28, 2026 at 9:10 AM
    futurist and BiomedO1 like this.
  9. BiomedO1
    4,469
    2,351
    Left Coast
    I know that TSA can make you prove the chemistry and Wh or Ah of your backup battery pack or they take it away at the checkpoint.
    I've been on several international flights since that rule was applied; (knock on wood), haven't been stopped or ask to do so yet - but I usually toss it out with my laptop. It's in plain view, which I think is part of the reason I haven't been stopped.
  10. Trollbait
    12,799
    I believe the "suppose" is doing a job there.
    LFP is more thermally stable than the nickel-cobalt chemistries. The chance of thermal run away without obvious precipitator is low enough to treat them as nonflammable with proper use and storage. An EV likely has a BMS and cooling system designed around those other Li-ion chems, and babies an LFP.
    Of course, damage and abuse changes that equation, but that is also true of lead-acid batteries and other energy storage systems.
  11. T1 Terry
    959
    535
    from about the 8:40 mark if you only want to see the tests ..... An interesting video, but the specs aren't a lot better than the gen 2 sodium ion cells CATL are producing, so .....
    T1 Terry
  12. Rmay635703
    2,684
    1,722
    2013 Chevy Volt
    There are sodium prototypes that now exceed standard lifepo4 energy density.
    sodium discharges linearly like FLA, that’s good for legacy systems and removes a lot of bms complexity but makes motor controllers more complex
