Gen 2 AC Compressor Replacement: Toyota or Aftermarket?
Discussion in 'Gen 2 Prius Main Forum' started by landolfi, Jul 2, 2026.
  1. landolfi
    landolfi Junior Member
    43
    My wife had her Prius Gen 2 (2005) AC compressor replaced last September with a non-OEM AC compressor. This year already it didn't seem to be very cool, so we took it back to the independent mechanic who replaced it. They checked freon and said it was low, but found no leaks. They recharged it, but cannot explain why the refrigerant was low. The car cools acceptably now, particularly since I replaced the cabin filter, so at least part of the cooling problem seemed to be a dirty cabin filter. But AC on my gen 3 Prius (2011) still seems to cool the car better than the AC in the gen 2.
    I doubt the engineering is that much better on AC systems between Prius gens 2 and 3, but that's the first question--is the gen 3 AC system better? And the second and more important question: The mechanic is willing to replace the aftermarket compressor they used with a genuine Toyota compressor. since their repair has a 3-year warranty. My next and more important question: Is there a significant difference in part quality between OEM and non if it's a reputable shop? I have no idea what brand was used, so I suppose the question is whether the genuine Toyota part is likely to be superior generally.
    Thanks in advance for any insight.
  2. ChapmanF
    19,052
    Reading your question, I find myself unsure whether your mechanic has offered to do that entirely on their own dime, or has offered to comp the labor if you want to buy the replacement compressor. That might make enough difference to me to change my answer.
    If offered the opportunity to have a Toyota compressor put in for free, I would probably take it. If the offer involved me buying the part, maybe that would take more thought. I don't know anything about aftermarket compressors specifically, but on PriusChat we have seen examples of other aftermarket parts being made much less robustly than the originals.
    It might be worth remembering that Toyota also has its own remanufactured-parts program, though it is kind of limited, only covering a smallish selection of parts and even those aren't always available. Last I knew, if you were looking at a part number xxxxx-yyyyy, you could search for xxxxx-yyyyy-84 to find out if a Toyota reman version was available. I would definitely be willing to buy a Toyota reman part.
  3. landolfi
    43
    They are offering to put it in for free. They said after the recharge it seemed to them that it was OK, and they didn't get any codes so they thought the low freon was the only issue. So they suggested I try it as is, but when I picked up the car after the recharge, it was still blowing coldish but not cold air. I called them immediately and told them I going to bring it back for the replacement. But since I couldn't get it in before the holiday, I though in the meantime to try replacing the cabin filter, which to their credit they said neded replacement although they didn't connect it as a potential cause of the AC issue. And the reason for my question is that even with the cabin filter the AC mostly works but still seems it could be better, possibly with the complete replacement they are offering. So the question now was going to be, given an offer of a free parts and labor replacement to a Toyota OEM part, should I do it? And I suspected the answer would be yes even if things are working OK. As far as the mechanic knows, I am electing to go forward.
    Part of my concern was that before the complete recharge they said the compressor was noisy, which is why they were going to replace it. They said it stopped making noise after the recharge. I Have wondered all along how the freon could be low a year after a compressor replacement. If there are no leaks but freon was low, would the issue likely be the compressor?
  4. Tombukt2
    13,875
    2,521
    What kind of numbers are you getting on the low and high side gauges when the thing is charged up properly and running like it's supposed to according to the gauges while it's sitting in the shop that's what youd like to know . I think most all of the electric compressors are remanufactured generally not getting new even my Chevy is same it's a Volt. Rebuilding these compressors doesn't seem like a real big to do to be honest about it very similar rotary radial design like all the round compressors . do maybe it's a poor rebuild that got through.
  5. rjparker
    11,133
    6,982
    Without a leak you can't have low refrigerant unless it was low to begin with and never worked right.. With a poorly designed aftermarket compressor you could have low pressures.
    There are other possibilities like a bad txv or a blend door allowing heat during ac. A good ac tech knows how to check for those issues.
    I would get a new compressor from Toyota and split the parts cost if he covered the labor and refrigerant.
    This is an online price which might be further reduced in the cart due to the nationwide July 4th sale.
  6. Tombukt2
    13,875
    2,521
    I mean this is an easy job compared to years ago no belt a plug and four bolts . All of 45 min to install .have gauges set pulling a vac . Oil already in compressor .
    97trophy likes this.
