I was an early adopter of the Gen5 PPP (Pretty Prius Prime), so took care of the getting the locks replaced when the recall came out back in 2024-ish. I got another letter earlier this year about the same recall, same locks, same issue (water), so tossed it thinking it was an artifact of me moving so having a different address. Given the activity on here about the issue I'm now wondering if there is indeed a second recall for exactly the same issue? I looked up my car and it shows an outstanding recall issued January this year, so now thinking it is a second recall. There is (for good reason) a LOT of chatter about the recall, but if that detail is buried in those threads somewhere I glossed over it. I wanted to post a thread just about this question. Thanks in advance. will
Yes there was 24TA05: Rear Door May Open While Driving in Rain - Latch Recall and there is 26-TA03: Recall Rear Doors May Open. I had the 24TA05 recall performed in September of 2024, and just took my 23PP in for the 26-TA03 recall. It was explained to me that this recall would involve one or two "long visits", the first to inspect a circuit board in the latch to determine if replacement was needed. The second visit would be after the part ordered at the first visit was in, and that this would again be "a long visit". At my "first visit" for the 26-TA03 Recall, I was at the dealer for four hours, and my service notes states "26TA03 Recall - Completed Recall", and then lists "04005-37147 Wire Kit, RR Door, Special Order, Quantity 1 is special ordered" I was told verbally that the "recall actions were performed" and that I do not need to bring it in again. I cannot even hazard a guess at what was actually done. I had to roust up the service manager to check me out due to seeing my car ready for quite a while but no one coming to tell me it was complete. I never experienced my rear doors opening, in the rain or otherwise.
First recall replaced door handles with a better water-proofed design. Second recall modified wiring to add an extra power relay that ensures there's no way for any short in the handle to open the door unintentionally.
Thanks @tovli and @KMO, I feared that was case after realizing there was a lot more chatter. Well, crud, time to get started on that and thanks for the warning about being patient. I'll plan accordingly. Same here, BTW, never had any issues with the doors ever--including driving occasionally in some pretty good "gully-washers". will
You could be waiting anything from one hour to four hours; it all depends on how many times the tech has performed the recall so far. I've heard up to three hours of actual work for a first timer that's being extra careful. And I've heard 45min or less for a tech that's already done several. Toyota is paying 1.7hrs for the job, so techs will be trying to get under that number so they don't lose money on the job. The longer you wait to get it done, the more likely the tech will have performed the job a few times and be quick.
I've seen no public reports of issues anywhere - this is one of those super-precautionary safety recalls, not a fix for a common user experience issue.
By the way, I spent some time staring at the wiring diagrams to figure out how the new fix works. Can't be 100% certain, but here's what I've deduced. The opening motor is connected only to the handle. The handle has 6 wires - the 2-wire motor connection, power, ground, "handle pressed" button circuit to ECU, and "open door" command signal from ECU. (Or likely "open door permitted" - don't know if the handle would open just from ECU command without handle press. I guess safety would suggest not.). The designers did think about the problem of false switch activations, and designed for that. The ECU has to approve door opens, and it presumably won't command a door open if not appropriate - presumably if locked or moving. The open motor is analogous to a normal handle motion - its attempt to open won't work anyway if the door is locked. A normal mechanical and central lock mechanism is present and separately controlled. But because the handle has the constant power supply, sufficient shorting in its control module could make it send power to the motor, even if the ECU is not telling to open. It's designed to cope with switch shorts, but not control module shorts. The original fix presumably better water-proofed the control module. The new wiring harness is inserting a relay on the power line to the handle that only provides power to the handle when the "open door" signal is active. So now control shorts could only open the door when safe according to the ECU. And that relay and its wiring are placed in a sufficiently secure location - I imagine the intricate routing is thinking about crash impact, waterproofing, stuff like that.
