Can we use Li-Ion battery in 2011 Prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Javed Khan, Jan 24, 2021.
Tags:
  1. Javed Khan
    Javed Khan Junior Member
    Islamabad
    I want to replace NIMH battery in my 2011 Prius. Can I replace with Li-Ion battery?
  2. PriusCamper
    PriusCamper Senior Member
    13,388
    5,409
    Pacific Northwest, USA
  3. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    I would rather wait for lifepo4 instead of lithium ion battery. Lifepo4 voltage is much more steady compared to li ion when draining from 100 or 80 percent to 40 percent.
    PriusCamper likes this.
  4. bisco
    52,760
    okay by me
    GG707 likes this.
  5. Irakli 500
    Irakli 500 New Member
    Thursday
    Georgia
    Yes, you can, you need to install a cheat that will increase the voltage in the information cables and trick the battery ecu.
  6. Irakli 500
    Thursday
    Georgia
    I have tested it on Ford Fusion batteries and it works perfectly. If you know of a similar charger, please share it with me.
  7. ChapmanF
    18,944
    Batteries are DC. Such a transformer can only work its magic on AC.
    Brian1954 likes this.
