Spark plug torque wrench
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by MeGuinness, Apr 14, 2017.
  1. BiomedO1
    4,506
    2,361
    Left Coast
    Just a FYI; You should relieve the tension on those spring loaded torque wrenches. Take it back down to zero before putting it in the case and don't drop them. You'll ruin the calibration. Those spark plugs thread into an aluminum head (soft metal); don't put too much muscle on them. I've done enough spark plugs to not need a torque wrench; never had one that I did, back out, cross threaded, or wielded in place - but have run into quite a few.
    YMMV
    ASRDogman likes this.
  2. Mendel Leisk
    42,251
    I thought I recalled suggestion, to take it down to the lowest setting, not zero, so googled:
    relieve tension on torque wrench after use
    And Google's AI concurs, saying:
    always wind it down to the lowest torque setting on the scale, not zero.
    Brian1954 likes this.
  3. Gloria&Suzanne
    Gloria&Suzanne Junior Member
    37
    Sacramento, CA
    My understanding is that the correct torque is 15 ft/lbs.
  4. Mendel Leisk
    42,251
    That’s correct. And finding that value is not trivial: Owners Manual says nothing. In my bootleg copy of the Repair Manual (what several other manufacturers refer to as Shop Manual, there’s a section devoted to spark plugs, with no mention of spark plug torque value. I finally found the value, on a page related to (totally unrelated) valve cover removal and install.
    attached is aforementioned spark plug section, with the valve cover page tacked on the end.
    note: there’s no mention of lube on the spark plug threads, so “presumably” they should be torqued with clean/dry threads. That’s Denso’s recommendation as well.
