2012 Prius (49k miles) - Code P0AFC / Harness Corrosion. Dealer wants $5.5k. Need advice!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PeggyPriusG3, Jul 8, 2026 at 1:04 AM.
  1. PeggyPriusG3
    PeggyPriusG3 New Member
    Tuesday
    Hi everyone,
    I need advice on a sudden hybrid battery issue with my 2012 Toyota Prius. I don’t drive very much and it has very low mileage—only 49,643 miles.
    The "Check Hybrid System" light came on. The Toyota dealership pulled code P0AFC (Sensor Module Circuit Malfunction). They found green corrosion on the battery voltage wire frame harness that possibly crept into the Smart ECU pins. They want me to have a full battery and ECU replacement, quoting me over $5,500.
    I bought a Veepeak adapter, and scanned the car myself.
    • Blocks 4–14: Perfectly healthy, stable green bars (15.52V–15.74V).
    • Blocks 1 & 2: Reading dead at 0.02V and 0.04V.
    • Block 3: Flashing red at an impossible 24.97V.
    • DeltaV: 14.05V. Temperatures are normal.
    • I tried clearing the codes, but the warning light came right back on in "READY" mode.
    I called almost all local repair shops, and they either refuse to open the high-voltage box or won't give me a quote to only place the harness.
    My Questions:
    1. Is there any way to replace just the wire frame harness and clean the ECU pins without throwing away my good, low-mileage factory battery cells?
    2. Does anyone know of a component-level hybrid specialist near North Florida or South Georgia?
    3. If I have to use a mobile service like Green Bean Battery, is it worth paying extra for their "Brand New Modules" option ($1,749) to match my car's low mileage?
    Thank you for any guidance!
  2. PeggyPriusG3
    Tuesday
  3. PriusCamper
    PriusCamper Senior Member
    13,396
    5,411
    Pacific Northwest, USA
    Apologies that someone haven't thrown the criminals at the Toyota Stealerships in jail for grand theft!
    Basically when a Prius isn't driven very often the battery blocks will self-discharge at different rates and if it sits long enough it will no longer have the same voltage across all block and you get a red triangle. It's an easy fix to charge and balance with a high voltage trickle charger on the pack overnight. Of course the criminals at the Stealership wouldn't rather lie to you and make you pay the value of the car for a new battery pack you don't need. They should have their business license revoked for that and get shut down!
    As for the voltage sensor harness... Use the link in my signature to get a better one that's higher quality than OEM. There was a time before acenbay.com made these harnesses that we had to buy used ones becuase Toyota refused to sell this replacement part and forced you to buy the whole pack just to get the part because they're greedy evil scum!
    There's lots of you tube videos on how to do this job and If you need additional help let us know what part of Florida you live in and we'll find someone near you.
    PeggyPriusG3 likes this.
  4. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    When you say you don't drive often, how long has it been sitting? If these errors suddenly came up after driving it the blocks could very well be shot.
  5. PriusCamper
    13,396
    5,411
    It's a 14 year old car with only 49K miles on it. This is a known problem with old low mileage Prius. There's nothing wrong with OPs battery pack that a high voltage trickle charger can't fix, yet Toyota has spent the last 25 years ripping people off as though they have a failed battery pack rather than just a pack that needs a charge and balance.
  6. PeggyPriusG3
    Tuesday
    From 2012 to 2020, I drove the car 5–6 days a week. Since 2020, I've typically driven it only 2–3 times a week. I also don't use the car for about a month during the winter break each year. The car is always parked outdoors, either in my driveway or in an outdoor parking lot.
    The error messages first appeared after the car had been parked for four consecutive days over a weekend at the end of last month.
  7. PeggyPriusG3
    Tuesday
    Thank you very much for understanding and for the suggestions! I have absolutely zero car repair experience and am not comfortable doing any repairs myself.
    I live in Tallahassee, Florida. I have called almost all the local workshops here, but I am surprised that they are either unable or not willing to commit to replacing just the harness.
    If you know of anyone near the Tallahassee or North Florida area who handles these hybrid component swaps, please let me know.
  8. PriusCamper
    13,396
    5,411
    There's nothing wrong with battery blocks when a car sits for a long time, it's natural self-discharge and it easy to fix with a charge and balance from a high voltage trickle charger. This is hybrid battery repair 101 stuff! Very easy!
  9. bisco
    52,764
    Brian1954 likes this.
  10. bisco
    52,764
    matt at tampa hybrids is a member here. he might know someone up your way
  11. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,559
    2,598
    Taylors, SC
    Tampa is at least 275 miles from from Tallahassee.
  12. PeggyPriusG3
    Tuesday
    I have. The owner told me they can repair the electric motor and replace the 12V battery, but they don't work on high-voltage (HV) batteries. He said I'd need to take it to a Toyota dealer for any HV battery repairs.
  13. DirkAshburn
    DirkAshburn Member
    161
    66
    Virginia
    I'm well aware of that which is why I asked that exact question. After only being sat for a few days, I highly doubt it's a discharge issue. As for removing the pack and balancing the cells - for most of us here, yes, this is straight forward stuff but for someone who has never done car repairs themselves it certainly not very easy.
  14. PeggyPriusG3
    Tuesday
    Thank you for recommending AcenBay harness. I plan to purchase one myself if I can find a shop that's willing to install it. I contacted every independent repair shop in Tallahassee, and all of them declined to perform a component-level repair. I also asked each shop whether they knew an independent hybrid technician, but none could recommend anyone locally.
    Do you all think towing the car to a city with a hybrid specialist who performs component-level repairs is my best option at this point, or are there other alternatives that I haven't considered?
    If anyone knows of a reputable Prius or hybrid specialist that is closer to Tallahassee (or somewhere else in North Florida or South Georgia), I would really appreciate your recommendations!
  15. Brian1954
    Brian1954 Senior Member
    2,656
    1,059
    South Central PA, USA
    Did you call the place linked in post #9?
  16. PeggyPriusG3
    Tuesday
    I did. Please see my post #12.
  17. Brian1954
    2,656
    1,059
    Sorry. I missed that post. How can they be a hybrid specialist and refuse to work on the HV battery. Makes no sense to me.
