Trunk Hatchback Lift Supports
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Postea, Sep 27, 2024.
  1. Postea
    Postea Junior Member
    San Mateo, CA
    My hatchback lift supports were weak and I decided to replace them. The supports that I was removing were the original OEM supports and they were made by Stabilus so I decided to purchase new Stabilus supports. I looked at several different models on Amazon as well as reading the reviews on Priuschat. Eventually, I called Stabilus Customer Support to figure out which is the correct model for my Gen 3 Prius. The Stabilus model SG329044 is not the correct model. The Amazon site title says "Compatible with Prius 2008 to 11/2010" but this is not correct and they are not compatible with Prius up to 11/2010. When I mentioned this to the Stabilus agent she told me that they have tried to get Amazon to correct this error but it has not been done for years since Amazon creates the web listing for Stabilus. There is another item on sale at Amazon with the title, Stabilus 4B-015513. This is also not the correct model and the AmazonConfirmedFit correctly states that this does not fit the 2010 Prius (Gen 3). The correct Stabilus model has the Amazon title of: "Qty (2) Fits Prius 2010 To 2015 Hatchback Trunk Lift Supports (Exc V, C Models)" and the correct Stabilus model number is: 4B-136715. This Amazon listing shows other OEM numbers for other vehicles that are compatible with the Stabilus model 4B-136715. I installed these and they fit perfectly and work like the original without any problems. They are exactly the same length and diameter as the originals. There is no right or left side as the top rotates either way to fit either side. The install only took a few minutes and the hard part was lifting out the security clip on the top of the old lift with a small screwdriver. (Wear safety glasses as the clip can shoot across the room or hit you.) For the install you can use a second person to hold up the hatch while you change the lifts because it will drop once you remove one of the old lifts. I used a small rope and attached it to the ceiling of my garage and then to the hatch latch. For the install, there is no need to touch the metal clips as the new ones just snap onto the connectors on the Prius.
    #1 Postea, Sep 27, 2024
  2. Tombukt2
    13,809
    2,504
    I just use a trimmed piece of 2x4 with a v notch and one end and flat on the other and it just holds the trunk up while I do whatever I'm doing back there and even cars were the struts are worn out then make a bunch of different struts now you can even get linear actuators that are almost the size of the struts you have and push a button and watch the hatch raise all by itself car stereo affectionatos have seen this for years It's kind of like the bed motors on an adjustable bed frame but micro miniature and they are some that are gas filled that when you pop the lock on the trunk they will automatically start the hatch-raising I'm sure a lot of these struts can easily be quickly fabbed up with different ends to screw into different bosses on different cars It's the length and the space between the threaded inserts and whatnot that will generally make the difference for the travel and what have you but there's a lot of sites that used to play around with these strut things on various parts of the car doing the hood with them so when you pull the hood release the hood just start gently raising till it's fully up etc some people like that kind of stuff.
  3. Mendel Leisk
    42,271
    I replaced ours, using a recommendation here. The fit is fine, but they are definitely more aggressive, to where you want to keep a hand on the hatch going up, and you need to put more of your weight on it pushing down. Purchased on Rock Auto, info (fwiw) attached.
    anyway, with the ones you got, the feel is about the same, going up or down? Say as the originals, before they started going off?
    #3 Mendel Leisk, Sep 28, 2024
  4. MAX2
    MAX2 Senior Member
    1,436
    490
    101
    Third planet from the Sun
    Try turning the rod down and pumping it up and down a few times.
    I recently used this method on my GEN2 when I changed the lifter supports.
    Now the trunk opens, goes up easily, and slows down at the top point.
  5. Postea
    San Mateo, CA
    I purchased the Prius 14 years ago and I have forgotten what the lifts were like originally. What I can say is that I got tired of pushing up the hatch every time I opened it. Now, after the first slight hand lift the hatch rises up with its own power. I think that I keep my hand on the hatch door all the way up. I am completely happy with the way that it lifts automatically and I don't have to put in effort any more to lift the hatch. My distant recollection is that it is very similar to how the original lift supports worked years ago, but I can't be sure.
  6. Mendel Leisk
    42,271
    I was just thinking about this yesterday; the replacements I got (maybe 6 months back) seem to have mellowed slightly, not too bad now. I still have the old ones around too.
  7. tweedle99
    tweedle99 Member
    125
    69
    Round Rock, TX
    I bought the same StrongArm 7088 and yes they are quite strong, especially comparing to the originals that are failing.
    I just cruised Rockauto site; they have 3 recommendations from strongarm, 7088, 6244 and 4094.
    7088 has max force of 106 vs 6244/4094, 93. that would explain why 7088s seems more forceful.
    I've installed them for about 6 months now and yes they have "settled" a bit.
  8. kwc
    kwc New Member
    Monday
    NV, US
    I did something dumb yesterday and started to back out of the garage with the hatch still open. It caught on the bottom edge of the open garage door and got pulled up farther than it was supposed to go. The damage didn't seem to be too bad overall (the spoiler got a little messed up but I think I have that taken care of), but it did yank the lift supports off of the ball studs and blow out the end fittings (socket joints) in the process.
    I suspect I should replace the lift supports entirely, but does anyone know if it's possible to remove and replace just the end fittings? I tried twisting them and they didn't budge, so I suspect they might be molded onto the supports. (Gen 3, 2015)
  9. 20113rdgen
    20113rdgen New Member
    New Zealand
    I got a pair from china for about 10 usd shipped. They are oem quality tbh
  10. rjparker
    11,009
    6,898
    Just replace them. You can get a set from Amazon starting at $20 or at an auto supply around $45 (which I found to be too strong).
