1. pasadena_commut
    pasadena_commut Senior Member
    3,018
    939
    Southern California
    Went to fill up the tank and the little rubber "anchor" on the end of the gas cap retaining cord popped out of its metal hole. It didn't feel very flexible anymore. Today was very hot, and maybe it was one very hot day too many. Pushed the little rubber plug back into the hole but its grip has gone.
    It looks like that bit of rubber and its tether is not separate from OEM gas cap 77300-47010. Or is there some way to replace it? A new cap would be around $25 which isn't much but seems a little ridiculous in this case since the cap works fine otherwise.
    This is the only car I have ever owned that had a tethered cap like that, and since the car still has a place to rest the cap on the little door while fueling, I'm thinking maybe just cut off the tether so it will be like all those other cars. Don't want to leave it flapping around loose. With my luck that loose tether will somehow manage to eject the little rubber plug into the filler tube at just the wrong time and somehow break the fuel pump.
  2. ChapmanF
    18,960
    PlastiDip.
    Or RTV silicone.
  3. pasadena_commut
    3,018
    939
    Southern California
    Put that material in the hole and put the no longer grippy piece into that (glue it in)?
    Or put the not grippy piece in the metal hole clean and cement it in place with a blob of one of those two materials?
  4. ChapmanF
    18,960
    I think you kind of want it to be able to twist in the hole.
    So I think my first try would be to push the not-grippy piece through the hole and blob some material on the end of it so it doesn't want to pull back through, but without gluing it to the metal around the hole.
    I guess that presupposes some access to it behind that piece of metal—which I haven't checked to see if there is.
  5. pasadena_commut
    3,018
    939
    Southern California
    There is some space but putting that blob on just the top of the rubber would be tricky. Assuming it wouldn't just pop right off again when the force on the new part of the anchor pulls off the outer layer of the old degraded rubber on the old part.
    What is the purpose of the tether? When it is not screwed in I always put the cap on the little shelf (well, two bent pieces of metal near the bottom of the door that stick out, with space in between that it fits on) on the fuel door, just like other cars. The tether does nothing for that. I guess the tether would keep me from dropping the cap on the ground if I did something clumsy. I may have dropped a gas cap at some point in the last 50 years, but don't recall such an event. So not a very critical function. Maybe some people just let the cap hang on the tether as a "convenience"?
  6. pasadena_commut
    3,018
    939
    Southern California
