2027 toyota prius
Discussion in 'Gen 5 Prius Main Forum' started by Gerald10, Jun 14, 2026.
  1. Gokhan
    Gokhan Senior Member
    6,707
    2,652
    Paramount CA
    LOL. That is because it is summer and very hot, not because it is 0W-16. An oil’s viscosity decreases greatly with increasing temperature. Try pouring it in subfreezing weather or after you put the bottle in a freezer.
  2. Hammersmith
    Hammersmith Senior Member
    2,457
    2,520
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Yeah, I doubt it is oil. More likely it's a software change to the VVT-i system. Maybe a little more aggressive on the intake cam when the system is asked for max power.
    There's no links in the NCF linking to any changes in the engine, so I'm fairly sure it's just software and no physical changes.
    Gokhan likes this.
  3. Gokhan
    6,707
    2,652
    Paramount CA
    It is interesting that the torque hasn’t changed. It could be that they have increased the maximum rpm because thinner oil lets you run higher rpm.
  4. Hammersmith
    2,457
    2,520
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    I didn't include that in my earlier post, but all hp rpms were listed at 6000.
    Gokhan likes this.
  5. Gokhan
    6,707
    2,652
    Paramount CA
    OK, then, they must have increased the torque at high rpm. It is probably a software update, as you said.
  6. Hammersmith
    2,457
    2,520
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Listed torque ratings are the same at 139 lbft at 4400 to 5200rpm for both the 2026 and 2027 versions. (188 Nm)
  7. Gokhan
    6,707
    2,652
    Paramount CA
    But hp equals torque times rpm. Perhaps something changed in the electric motors.
  8. Hammersmith
    2,457
    2,520
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Okay, I guess that still works, because the bump in torque at 6000rpm(131.3 to 136.6 in the HEV) is still under the max torque for the engine at the lower rpm band.
    Regardless, I'm 99% certain it's just a change in programming. Either in the VVT-i programming, the transaxle programming, or some combination of the two. The engineers have probably been tweaking the M20A and the 5th gen hybrid system as they've added them to more models, and they realized they were leaving some safe power on the table.
    (I've been doing the research to see whether I can add dual zone climate with ionization to my 2023 HEV, which is why I've been doing a deep dive the last few days. It's looking good from a technical standpoint, but sourcing parts is going to be interesting if I want to keep costs down. Probably a mix of US salvaged parts, new parts from Japan, and at least one new or salvaged part from Europe that I have no idea how to source.)
    Gokhan likes this.
  9. Tande
    Tande Active Member
    553
    338
    Mich.
    You are correct ........I have both
    Gokhan likes this.
