My 2015 Toyota Prius V Complete Sound Deadening + Audio System Build
Discussion in 'Prius v Audio and Electronics' started by Beton, Jun 27, 2026.
  1. Beton
    Beton New Member
    Virginia
    2015 Prius v wagon
    This thread documents my 2015 Prius V refinement project focused on cabin noise reduction and an audio system upgrade. The goal is to improve daily driving comfort and in-car sound quality through a complete NVH and audio system build.
    Viviparous likes this.
  2. Beton
    Beton New Member
    Virginia
    2015 Prius v wagon
    I eventually decided to upgrade the audio system in my Prius. I already had a few components, and after researching different setups online I picked up the rest of what I needed.
    Before touching the car itself, I wanted to make sure everything was working correctly, so I set the entire system up on a test bench at home first.
  3. Beton
    Beton New Member
    Virginia
    2015 Prius v wagon
    I needed some lugs, battery terminals, circut splitter, wires, fuses
  4. Beton
    Beton New Member
    Virginia
    2015 Prius v wagon
    Important note: wire terminations. I'll came back to this later
  5. Beton
    Beton New Member
    Virginia
    2015 Prius v wagon
    Started from the doors. Surfaces needed to be clean.
    #5 Beton, Jun 30, 2026
  6. Beton
    Beton New Member
    Virginia
    2015 Prius v wagon
    Two layers inside the doors
  7. Beton
    Beton New Member
    Virginia
    2015 Prius v wagon
    Aftermarket speakers + deadening the doors under panel surface
  8. Beton
    Beton New Member
    Virginia
    2015 Prius v wagon
    During a second test, I accidentally shorted the circuit, and the head unit stopped powering on. It's a good reminder to be very careful when working with 12V electronics.
    After taking it apart, I found a burned PCB trace. Fortunately, I was able to repair it by soldering the trace back together, and the head unit started working again. I got lucky—if any other component had been damaged, I might have had to replace the entire head unit.
  9. Beton
    Beton New Member
    Virginia
    2015 Prius v wagon
    I continued working on the trunk area. Everything had to be removed to get access to the battery.
    The hybrid battery is heavy, but it was better to remove it to make routing the signal and power wires easier. I applied two different layers of sound deadening and insulation, plus a third layer of noise-absorbing material in specific areas.
  10. Beton
    Beton New Member
    Virginia
    2015 Prius v wagon
    Then it was time to “skin the bear.” After removing the seats, center console, side trim panels, and clips, I pulled out the carpet.
    And it was a great opportunity to give it a proper deep cleaning.
  11. Beton
    Beton New Member
    Virginia
    2015 Prius v wagon
    Headliner. After taking it off, I put in two layers of sound deadening material. Unfortunately, I didn't take pictures of all the steps.
  12. PriusV17
    PriusV17 Active Member
    440
    207
    CA
    2017 Prius v wagon
    Cool. You should post a video of how you removed all the panels. I want to remove my front passenger door panel to see what is rattling inside. But I don't want to break or snap anything.
    I think in the future I want to install solar panels on the roof so seeing how it looks with panels removed is interesting.
    Beton likes this.
  13. Beton
    Beton New Member
    Virginia
    2015 Prius v wagon
    Unfortunately, I didn't have the camera recording while I was doing it, I only took photos. However, I did use a few YouTube tutorials as a reference, though. I'll look for them and post the links later.
  14. Beton
    Beton New Member
    Virginia
    2015 Prius v wagon
    Soundproofing the interior floor of the car was quite a time-consuming job. I had to carefully remove the seats, the center console, and the side trim panels, while keeping track of where everything came from and how it was installed.
    The trickiest part was dealing with the connectors under the seats. To disconnect them, you have to pull a special locking tab on the connector, which wasn’t obvious at first. Later, I found a YouTube video showing the proper way to remove them, and that made the process much easier.
    For the floor itself, I applied two layers of sound-deadening material in some areas and three layers in others, depending on the location and available space. One important thing to keep in mind is making sure the carpet clips and fasteners can be properly reinstalled afterward.
    There is no need to apply insulation to the crossbars of the frame. The main focus should be on covering the actual floor areas where it makes the biggest difference.
    Overall, it was a lot of work, but taking my time and remembering how everything was assembled helped avoid any issues during reinstallation.
  15. Viviparous
    Viviparous Junior Member
    31
    Back in California
    2014 Prius v wagon
    For me, the sound deadening steps are something that I could definitely do in the future, after my Prius’s warranty expires. So, I bookmarked this thread.
    I wonder if adding the sound-proofing / sound deadening alters the heat inside the vehicle when the vehicle is in the sun or has full occupants, i.e. people’s bodies radiate heat, and heat enters through windows and through the metal of the roof and doors.
  16. Beton
    Beton New Member
    Virginia
    2015 Prius v wagon
    One of the materials that is widely available on the market and heavily marketed is the so-called "thermal and acoustic insulation" material, which is advertised as providing both benefits in a single layer. It is commonly used as the middle layer in a three-layer sound deadening approach.
    If you decide to use it during a sound deadening project, it will certainly do its job. When running the heater or air conditioning, it can help reduce heat transfer between the cabin and the outside environment. The real question is how effective it is, which largely depends on its thermal conductivity rating.
    In that case, the vehicle's ventilation system becomes an important factor. I'm speaking in general terms here, but hopefully the idea makes sense.
    Overall, I would answer your question with "yes." If you have five people inside the vehicle generating body heat, or if the car has been sitting in the sun, an additional thermal insulation layer will slow down the rate at which heat dissipates or enters the cabin. However, once ventilation or air conditioning is operating, temperature equalization occurs much more quickly.
    Ultimately, it comes down to the quality of the insulation material and the amount used. It would be incorrect to assume that you can leave an insulated vehicle in direct sunlight for several hours and expect it to maintain the same interior temperature it had when you parked it with the A/C running.
    Thermal equilibrium will still occur—it will just happen more slowly.
  17. Beton
    Beton New Member
    Virginia
    2015 Prius v wagon
    Next up is the front dash insulation.
    On the Prius (and possibly other Toyota hybrids as well), engine noise becomes quite noticeable when the ICE is running under heavy load. One area that helps reduce this is the front dashboard area.
    I'll add a link later showing how to remove the dashboard once I put together that portion of the project.
    For this section, I used only two layers: a constrained layer damper (CLD) for vibration control and an acoustic absorption layer. In my experience, adding mass in this area helps reduce some of the engine noise transmitted into the cabin, especially during hard acceleration or long uphill climbs when the engine is operating at higher RPM.
    While this won't eliminate engine noise entirely, it does make the cabin noticeably more refined and improves overall driving comfort.
