ThinkDiag2 question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lioninstreet, Jul 23, 2026.
  1. Lioninstreet
    Lioninstreet Junior Member
    29
    Thanks in advance for your answers & advice. Everyone here has been great.
    So, while driving my G2 base, the gas motor shut off right after rounding a corner and the dreaded red triangle came on (along with most if not all the other dash lights). The traction motor stayed on long enough for me to make a U-turn back towards home. But shortly afterwards when I stopped at a red light, no more love, the car bumped itself to neutral, AC shut down, and an hour later AAA brought me and the G2 back home.
    • My battery was just under 3 years old and didn't pass a load test. Lucky for me the replacement warranty wasn't pro-rated. Thank you Walmart.
    • The AM2 fuse is OK fine
    • Inverter pump coolant flow looks very weak (ie: peering in the reservoir, the coolant is barely moving). The pump was replaced about 8 years ago so I'm having a new Toyota 04000-32528 and some SLLC2 shipped to me.
    • Using my ThinkDiag2, the primary Fault code is a P0A94. There's also a few SRS codes (B1826, B1650, B1653, B1655, B1821, & B1826), an Occupant Detection code (B1771 which may be the root of the SRS issues), and two AC codes (B1421 & B1442).
    So here are a few questions. Since the biggest concern is the P0A94, I can't for the life of me figure out how to get my ThinkDiag2 to display the P0A94 subcode. Is that beyond the capacities of this scanner? If you happen to know that it's not, could you share the steps to get them to display?
  2. Tombukt2
    13,875
    2,521
    So when the think diag maybe going to the freeze frame data and see if offers Alt code .
  3. Tombukt2
    13,875
    2,521
    You're only supposed to see the coolant barely moving in inverter resvoir. Normal
  4. Tombukt2
    13,875
    2,521
    So the big question now is what's voltage on 12V sitting they're off ? And the minute you ready the car it should read 14 Volt you should see the change on voltmeter instantly 13.4 and less no good
  5. Lioninstreet
    29
    It sits just below 13v after a trickle charge on a brand new battery
  6. Tombukt2
    13,875
    2,521
    While it's ready I'm talking. So you walk up to the car in the morning you test standing should be above 12.4 AGM. Then you ready the car and it should jump to 14V . ????? ?. If that's not the case you may be looking at the DC to DC converter
  7. mr_guy_mann
    mr_guy_mann Senior Member
    4,120
    2,018
    NJ-USA
    P0A94 shows as "DC - DC converter performance". Since there are over two dozen sub codes, you really need the additional information to figure out where the problem is.
    As mentioned, go into freezeframe data for the code, and scroll through it. Somewhere should be several lines labeled "INF" or "detail". Most will have 000, but one should have other numbers - the sub code.
  8. Lioninstreet
    29
    @Tombukt2 Could I ask you to rephrase. Im not sure I understand your thought.
    @mr_guy_mann I'll give it a shot. I remember seeing freezeframe data as an option, but I don't remember where it was in the (quite robust) Thinkdiag menu. BTW it was your OBD eval thread that pointed me at this tester to begin with. Much appreciated
  9. Tombukt2
    13,875
    2,521
    Walk up to your battery with the car sitting there and measure the 12 volt voltage anywhere you can connect . And then do the same thing after the car is ready . Looking for 14V. Pretty basic stuff here
  10. ChapmanF
    19,054
    It's important to remember that while the P0A94 fortune cookie is talking about a "DC - DC converter", it isn't talking about that DC - DC converter.
    It's not about the one that downconverts from the traction battery voltage to 14 volts for the car's electronics and aux battery charging.
    It's talking about the one that upconverts from the traction battery voltage to 500 volts for the drivetrain motors.
  11. Tombukt2
    13,875
    2,521
    Yep probably the sensors in the transmission under those covers . I believe trans change . Is the way . Hey ya a lower mileage hybrid drive if you lucky . This is the two stupid things called the same thing .
  12. Lioninstreet
    29
    @Tombukt2 12.62c with vehicle off directly at the battery. In ready mode (Ignition full on, dash lit up like xmas tree...) 12.34v.
    @mr_guy_mann After doing a full diagnosis, on the screen that displays the 3 specific P0A94 codes (Pending, Current, & History), I find the freezeframe selection is greyed out. On the main menu when I select freezeframes it takes me back to the 3 specific P0A94 codes.
    Still trying to figure that one out with an em to ThinkCar.
  13. Tombukt2
    13,875
    2,521
    12.6 off at rest and 12.3 in ready mode yeah they're done issues looking 14V at ready .
  14. Tombukt2
    13,875
    2,521
    Things greyed out generally means your model doesn't support it the next price point up does same with most of em
  15. Lioninstreet
    29
    I'm past the level 1 support at ThinkCar, so hopefully they will confirm if ThinkDiag2 can read subcodes. . If not, is anyone willing to suggest an OBD reader that will read Toyota subcodes without spending > $500 to do it?
  16. Lioninstreet
    29
    Still dealing with ThinkDiag. At this point they are giving me the run around. not answering my direct questions about the limitations of their ThinkDiag2 (or any of their other OBD tool's ability to read INF sub-codes for that matter). In the meantime, my G2 just sits, so I'm pretty disappointed.
    Is anyone willing to suggest an OBD reader that will read Toyota subcodes without spending > $500 to do it or am I stuck making the investment in a Techstream setup?
  17. rjparker
    11,133
    6,983
    Some with a win7 or win10 laptop w cd drive would buy one of the mini-vci obd2 interfaces with the hacked older version Techstream.
    Sometimes tricky to install. Read vendor limitations above.
    Brian1954 likes this.
