P0A80 options
Discussion in 'Gen 3 Prius Technical Discussion' started by Matt98svt, Jul 21, 2026 at 11:31 PM.
  1. Matt98svt
    Matt98svt Junior Member
    91
    South Carolina
    2015 Prius v wagon
    IMG_7372.png IMG_7652.png IMG_7655.png IMG_7660.png IMG_7668.png IMG_7672.png So this last week my wife’s Prius had the check engine light (as well as a few other lights on the dash) pop up as she backed out of the driveway. Car is a 2012 with 200k and for what it’s worth it was 98 degrees out when it happened. I got home yesterday and scanned the car and am seeing P0A80. In other post I have seen people who get this code usually also get a message check hybrid system or something of the such pop up but hers never did that. I tested the 12v and it tested 12.42v. I cranked the car and it ran for awhile all like normal and the meter on the dash showed that the hybrid battery was indeed charging up while the engine ran. I took a few screenshots in Dr Prius hoping it would be of some benefit. The numbers seemed to fluctuate so I posted a couple. I plan to plug up techstream tomorrow to see if it can give me some more info. The car still gets good gas mileage and I have a prolong hybrid charger but have never used it on this car. Can anyone tell from these screenshots if there are any problematic cells that needs to be replaced first before using the prolong?
  2. Brian1954
    Brian1954 Senior Member
    2,668
    1,066
    South Central PA, USA
    I think that the hybrid battery modules are okay based on the Dr Prius screenshots that you uploaded. The main problem is that the Delta SOC (state of charge) is 34.0%. What that means is that the battery modules are not balanced to each other. When that happens, the voltage difference between the battery blocks (two battery modules= one battery block) becomes large enough to trigger the P0A80 code during high current flow through the battery. A healthy balanced battery has a 0.00% Delta SOC.
    To balance the battery modules to each other, you need to use the Prolong grid charger to top balance the battery pack. Follow the instructions on Hybrid Automotive's website. Going from memory, you want to charge for 20 to 24 hours. Take note about the maximum ambient temperature in the instructions. Also, make sure you let the battery burn off the extra voltage in the battery by letting it rest fot 4 to 5 hours before starting the car.
    After doing this, monitor the Delta SOC of the battery for the next few weeks and then every month or so. When the Delta SOC starts increasing again, use the Prolong charger again. Hopefully, you can go 6 or more months between charges.
    #2 Brian1954, Jul 22, 2026 at 8:17 AM
  3. Hayslayer
    Hayslayer Active Member
    529
    320
    Your screenshots show voltage values while the battery is being charged or a very small discharge. This hides a lot of problems. Your best condition evaluation will be performed when the battery is being discharged a bit heavier. You can do that by completely warming up the car, then running the AC on full blast while monitoring voltages. This way the car engine will stay off until the HV battery reaches 40% ish or a weak module shows itself and it needs to start for battery charging. Rarely ever can a good evaluation be performed of the modules when the HV battery is under charge conditions.
    Another question is about how long does the car sit unused? At that age and mileage, assuming the original battery, sometimes even sitting over a weekend unused will allow a weak module to self-discharge enough to drop the indicator to 2 or 1 purple bars. The good thing is they will usually charge back up, and as long as the car is used frequently, you'll never notice a problem.
    #3 Hayslayer, Jul 22, 2026 at 8:34 AM
  4. bisco
    52,805
    a 2012 with 200k might be a time bomb. consider carefully how much you want to spend maintaining it
  5. Hybrid Battery Exchange
    Gresham, OR
    All those Dr. Prius screenshots were taken with the battery charging or with a very slight discharge @ high SOC, outside of the delta SOC reading the rest of it isn't very useful.
    After it sat overnight and before starting the car, turn the ignition to ON, ready mode off by not holding the brake while powering on the car take a screenshot of the battery voltages. This will give us some idea of the self discharge of your battery.
    Start the car, let it warm up until the engine shuts down. Turn on the A/C on the coldest setting and fan on high, turn on the headlights including high beams, engage the parking brake and put the car in reverse, make sure it holds. This will put a 10-15 amp load on the hybrid battery, keep it there and continue to take screenshots. Post only the last screenshot you took before the engine restarted and began charging the battery. This will give us some idea of how the battery performs under a light load @ low SOC.
  6. Matt98svt
    91
    South Carolina
    2015 Prius v wagon
    I will post my discharge test below but I can say the car does not sit much. My wife works an hour away and drives to work 3-4 days a week and is driving it at least to town daily so it doesnt sit much
  7. Matt98svt
    91
    South Carolina
    2015 Prius v wagon
  8. Matt98svt
    91
    South Carolina
    2015 Prius v wagon
    So the first photo taken at 8:12pm is when I first started the car and shows the battery after it has set unstarted for 24hrs. The second photo was taken right before the ice engine kicked on to recharge the hybrid battery after running the air/lights/in reverse for a couple of mins.
    bars as the battery charges up. The last phto i overnight.PNG before engine.PNG
  9. Albert Barbuto
    Albert Barbuto Active Member
    116
    108
    Northeast USA
    If this was my car, I would do the following:
    (1) Remove the top metal cover above the battery pack.
    (2) Module pairs #2 and #3, measure the voltage of the individual modules. It is possible that just one module of the pair is the weak one. Cycle this module two times with a hobby charger. If both are weak, cycle both.
    (3) Now do the Prolong method.
    (4) Now do a test drive. While logging the pack voltages, do a full throttle acceleration from a dead stop. A healthy pack will deliver 150 amps. Weak modules will clearly be seen while doing this.
  10. Matt98svt
    91
    South Carolina
    2015 Prius v wagon
  11. Matt98svt
    91
    South Carolina
    2015 Prius v wagon
    I took the cover off of the hybrid battery and recorded the following values of the individual modules. These are in order from 1 to 28 starting with the #1 module being the one that is closest to the hybrid cooling fan (the passenger side of the car) and working toward the drivers side being #28.
    1. 7.91v
    2. 7.97v
    3. 7.87v
    4. 7.84v
    5. 7.78v
    6. 7.96v
    7. 7.93v
    8. 7.91v
    9. 7.94v
    10. 7.91v
    11. 7.93v
    12. 7.91v
    13. 7.91v
    14. 7.94v
    15. 7.94v
    16. 7.92v
    17. 7.93v
    18. 7.94v
    19. 7.94v
    20. 7.89v
    21. 7.93v
    22. 7.93v
    23. 7.95v
    24. 7.93v
    25. 7.95v
    26. 7.92v
    27. 7.91v
    28. 7.94v
    I have been looking at hobby chargers commonly used for prius and they look to be $100 or so. Would it be easier just to purchase used replacement modules and swap out the bad ones? I guess my question is would replacement modules allow me to jump right to the prolong process vs having to use a hobby charger? Thanks so much
  12. Brian1954
    2,668
    1,066
    Do not replace any battery modules until you follow what I wrote in post #2. If that does not fix the problem, then you can consider replacing battery modules.
    #12 Brian1954, Jul 25, 2026 at 5:21 PM
