No "how-to" head gasket posts for a Gen4?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by C Clay, Jul 26, 2026.
Tags:
  1. C Clay
    C Clay Member
    408
    82
    Lexington, KY
    2019 Prius
    L Eco
    I searched back through posts for some good how to posts and find nothing. I see a lot of "you probably need a new head gasket", but none of the rich content like is available for the Gen3. I've done 2 head gasket jobs this year, so I'm familiar with the task. Unfortunately, my 2019 is looking like she's needing this done and I'm just wanting to read/view some experiences as a sanity check.
  2. Mendel Leisk
    42,364
    These were 4th gen's?
    Due to some symptoms?
  3. C Clay
    C Clay Member
    408
    82
    Lexington, KY
    2019 Prius
    L Eco
    I’ve done a 2011 and a 2014.
    My symptoms on my 2019:
    -Billowing white smoke upon starting in maintenance mode yesterday morning
    -using about 2-3 of coolant each morning (refilling from the loss each day)
    -snot mix on the inside of the oil
    filler cap (I already cleaned it last week)
    -rule out head exchanger, I bypassed that almost immediately after buying it.
    Sure seems head gaskety. Not sure how or why it happened. It did happen after my first “big trip”- 600 miles up to Baltimore, back through the WV mountains. I did feel like sometimes I was going straight up a steep incline for 10 miles lol- maybe I pushed her too hard.
    I just bought it. Had 205000 miles on it.
  4. Mendel Leisk
    42,364
    Was the exhaust heat exchanger leaking? Maybe previous owner had neglected coolant top-up, let the engine run dry a time or two, led to head gasket failure. That’s been reported here before.
    douglasjre and ETC(SS) like this.
  5. ETC(SS)
    7,571
    I was tapping this while he was typing that......
    First, make sure you really have a failing head gasket!
    The G4 has a common manufacturer defect in the exhaust heat exchanger that can cosplay as a blown head gasket.
    Cracks in the plumbing allow coolant to leak directly into the exhaust system rather than onto the ground by causing mysterious coolant loss and white exhaust smoke without the Prius Death Rattle caused by coolant getting into the cylinder bore.
    Toyota released a technical service bulletin (TSB T-SB-0135-19)and I suspect that there will be a video as the G4s age a little bit more and suffer from being "dealer maintained."
    G4's probably overheat more from resulting coolant loss because you do NOT have the Prius Death Rattle, and this WILL cause head gaskets to fail from heads warping rather than blocks being hydro-locked.
    The oldest G4s are coming up on 10 years and truthfully speaking they have been much more reliable than the G3s.
  6. Mendel Leisk
    42,364
    One thing, it’s early years of gen 4 that we’re having the exhaust heat recovery (EHR) system leaks. My memory’s flakey, but it might have been resolved by model year 2019. Not sure though.
    douglasjre likes this.
  7. C Clay
    C Clay Member
    408
    82
    Lexington, KY
    2019 Prius
    L Eco
    Even after I bypassed the heat exchanger (and I did it under the car), you are stating there is still a way for the coolant to be leaking into the exhaust? IMG_4512.jpg
  8. C Clay
    C Clay Member
    408
    82
    Lexington, KY
    2019 Prius
    L Eco
    I’m sure it is unrelated, but listen to the car in maintenance mode. Probably best around 35 seconds. There is something clanging in her that I am disturbed about.
    When you try and diagnose issues- I think of everything I know about the cars history and everything since I’ve had it. Drives fine, 52-54 mpg.
    And then there was that day I jacked it up under the wrong jack point and bent the subframe a little, shooting the radiator up slightly so that the hood forces open and I wouldn’t shut. I pulled that all back down. I call that “stupid tax” for being in a hurry on my first oil change.
    The car doesn’t appear to have any issue related to that event- no coolant loss that I ever saw from say a damaged radiator.
  9. Mendel Leisk
    42,364
    Not sure he's saying that.
    Sequence that does make sense, assuming the EHR system did have a leak:
    1. EHR system commences leaking.
    2. Owner doesn't notice for some time, belatedly tops up coolant, but by then engine's run dry a time or two, overheated, and head gasket commences to leak coolant into combustion chambers.
    3. EHR system is bypassed, but head gasket continues to leak.
    Regarding your original question, I think 4th gen head gasket replacement would be VERY similar to 3rd gen, the engine being "mostly" identical.
    The imgur video sounds "somewhat" too noisy. Is it worse on cold starts? That tends to be when significant coolant accumulates, causing very nasty sounding bangs.
    Just technical: is there an arched/ribbed face of the wheel chock against the ground, and flat face against the tire? If so, think it should be flipped:
    #9 Mendel Leisk, Jul 27, 2026
  10. BiomedO1
    4,635
    2,433
    Left Coast
    And if you don't get hot coolant going pass your temperature sensor ( too low) your dummy lamp isn't going to light up....:(
    You could've crushed some cooling coils, that isn't leaking, but caused enough restriction to reduce cooling capacity. Newer car designs are very stingy on parts requirements and there isn't much excess capacity to spare on folly.:notworthy::cry:
    PS: the lower radiator coils may be for ATF cooling - double check the manual. If that's the case; you may want to look at the condition of the ATF.
    #10 BiomedO1, Jul 27, 2026
  11. Bill Norton
    Bill Norton Senior Member
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    I'm curious why you bypassed the EHR system. I thought it was a known issue and was redesigned by '19.
    I don't think that oil cap looks that bad. It's probably not after you did your big road trip. And on Gen3's the oil rarely gets into the oil. It just seeps into the #1 or 2 cylinders after shut down. This I know, a few times.....:(
    Brother, I just found this thread and I'm following it. Good Luck. I'm sure you can handle this head gasket change.
    Does Felpro offer a Gen4 version?
    I bought a '19 Eco in Dec, '25 with 232k miles.
    I think a courier had owned it. And I use it commercially also and I'm now at 280k miles!
    It runs great, uses very little oil between 5-7k mi oil changes. Mobil 1 all the way!
    I may do an oil analysis test on it because it looks cleanish.
    What's with the 25k mile M1 version? I may be the perfect user for that crazy figure.
    All I did to mine soon after I got home was change the transaxle fluid to Redline D6.
    The ATF that came out was fine looking, so I'm pretty sure someone gave it a change at some point.
    And I cleaned the battery pack fan filter, It seriously needed it.
    I know I should change the engine and inverter coolants... It's a bigger job....
  12. C Clay
    C Clay Member
    408
    82
    Lexington, KY
    2019 Prius
    L Eco
    On assertion #2- I lost less coolant to the heat exchanger issue that I am losing now.
    The wheel chock is facing correctly
  13. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Sorry for your problem.
    But to me, This is good news!!!:)
    C Clay likes this.
  14. C Clay
    C Clay Member
    408
    82
    Lexington, KY
    2019 Prius
    L Eco
    It was pretty clear it was the heat exchanger as I understand it. You could smell it while driving actually. The coolant was literally coming out of the exhaust.
    And I did reach out to Toyota, and they wanted no part of replacing it for free with its 205000 miles.
    Interesting, this also was a fleet vehicle of some kind. The maintenance was always done at Toyota or a chain tire place in the area (Nashville- where I bought it, but I live in Kentucky.). The engine is so clean you can eat off of it, and even all the undercarriage parts/plastics are all there. There’s some relationship to the car and the Toyota dealership that I never figured out. Either it was used as a delivery vehicle or maybe a loaner. One year, if I read correctly- it had like 60k miles put on it.
    Bill Norton likes this.
  15. Mendel Leisk
    42,364
    Think you’ve got it right: 3rd gen it was at top, 4th it’s at bottom.
  16. ETC(SS)
    7,571
    Nope.
    I said: "First, make sure you really have a failing head gasket!"
    You've already dealt with the EHR either proactively or reactively.
    It seems to me that there is one definitive way to determine if your head gasket is head gasketing, which would be to perform a leak-down test. It generally costs you nothing but time if you have a parts house that will lend you the kit.
    The semi-conclusive test would be to bore-scope the bottom end and look for signs of 'steam cleaning' or coolant present in the bore.
    This is also likely to be a no-cost test in the Commonwealth of Kentucky even though auto parts houses do not usually lend out bore-scopes
    These instruments have non-automotive uses and it's almost certain that you or one of your friends or neighbors already has a scope in 'another' tool kit.
    If all else fails - just get one on Amazon for about $30.
    The REASON that there are not many head gasket threads for the G4 is that it's not a common failure for these cars.
    #16 ETC(SS), Jul 28, 2026
  17. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Just a note: There are 2 kinds of 'leak down' tests.
    The one you're referencing it a Coolant system pressurized leak down test. 15 PSI is the typical pressure used.
    Another Leak Down test is used in Aviation and in the auto world is Combustion chamber leak down
    The spark plug is removed and each cylinder has to be tested at its TDC and manually held in place.
    A typical aviation pressure for this test is 80 PSI.
    And with this test you'd then look for the coolant system to rise in pressure.
    Which means you need two test sets and two pressure gauges in action at the same time.
    With pressurizing the coolant to 15psi pushing thru a < pinhole in the head gasket takes time to visually see it happening with a borescope.
    Good luck C Clay. Post pics of what you find!!
    ETC(SS) likes this.
  18. ETC(SS)
    7,571
  19. C Clay
    C Clay Member
    408
    82
    Lexington, KY
    2019 Prius
    L Eco
    Have mercy, I started it this morning in maintenance mode while I added coolant- wow.
  20. Bill Norton
    2,247
    754
    MONW, Ks.
    2019 Prius
    L Eco
    Not good. But was there the 'Death Rattle' when you first started the engine, like reported with Gen3's?
    If all that coolant came from one cylinder due to a pinhole in the head gasket there would be some misfire and noise, I would think.....
    And the coolant would clear quickly. I have experienced this...:(
    This seems like something else.
    This seems like a pool of coolant is getting heated slowly and removed from the exhaust system.
    Are you sure all coolant hoses are removed from the EHR parts near the CAT?
    Is it possible the EGR cooler has a coolant leak?
    It's time to go borrow the coolant system pressure tester from your friendly auto parts store.
    Leave the coolant pressurized for 30 minutes to see if you can see the level drop in the reservoir.
    And then start the engine, and I'll bet it starts fine but starts making this steam cloud again.
    Good Luck !(y)
