Did this part fall out of my Prius?
Discussion in 'Gen 2 Prius Main Forum' started by Bob Quick and Dirty, Jul 29, 2026 at 11:42 AM.
  1. Bob Quick and Dirty
    Bob Quick and Dirty New Member
    Today
    Lincoln MA
    I just sold my gen 2 Prius. Right before the buyer took it away, I changed the front rotors (pads were new and not changed) and topped off the engine coolant reservoir. After the car was driven off, I swept the garage floor and found this rubber gasket. It may or may not have come from the Prius. Can anyone identify it? It's 40 mm in diameter and 1.5 mm thick. The white substance may be dried white grease. Thanks! IMG_0668.JPG
  2. BiomedO1
    4,565
    2,395
    Left Coast
    It looks like a screw capture washer - nothing important.... A sealing washer wouldn't have those cut-outs near the center of the hole.
  3. PriusCamper
    PriusCamper Senior Member
    13,444
    5,428
    Pacific Northwest, USA
    Maybe the fill valve for the blinker fluid? :)
    BiomedO1 likes this.
  4. Dany Dan
    Dany Dan Member
    58
    Québec, Canada
    2024 Prius Prime
    SE
    Looks like the lock that holds the rear brake pads...
  5. Bob Quick and Dirty
    Today
    Lincoln MA
    Thanks for the input, but so far my only guess is that it's a rubber insert on the inside of the cap for the coolant reservoir tank. Since I don't have the car anymore, could someone take a peek and see if there's a rubber insert like this in the cap? Many thanks!
  6. LRO
    LRO Member
    94
    97
    United States
    2024 Prius Prime
    XSE Premium
    Toyota has been known to use such a keyed gasket in coolant reservoir caps as shown here.
    PriusCamper likes this.
  7. PriusCamper
    13,444
    5,428
    If only we knew what the size of it was?
  8. Leadfoot J. McCoalroller
    8,281
    7,791
    Pennsylvania
    2018 Prius c
