2017 Prius Two Eco – Severe loss of hybrid power, no inverter coolant circulation, no warning lights
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Ruslan77, Jul 30, 2026.
  1. Ruslan77
    Ruslan77 New Member
    Georgia
    Two Eco
    Hello everyone,
    I’m looking for some advice diagnosing a problem with my 2017 Toyota Prius Two Eco (ZVW51). The car was imported from a US auction and currently has around 64,000 km (about 40,000 miles).
    For the last 3–4 weeks, the car has had a significant loss of hybrid/electric power.
    The gasoline engine itself seems to run perfectly normally. The problem is specifically with the hybrid/electric power. Before this started, the car had very strong electric acceleration. Even with light throttle, it could accelerate very quickly using electric power, and on suitable roads it could reach around 100 km/h (62 mph) without the gasoline engine running.
    Now the car still drives electrically, but the electric power is extremely weak. On a flat road it struggles to gain speed using electric power alone. When I press the accelerator harder, the gasoline engine starts immediately and the car continues accelerating, but because the hybrid system is no longer providing the same electric assistance, acceleration is much weaker than it used to be. The gasoline engine itself sounds and feels normal.
    The hybrid battery does not seem to discharge unusually fast. The state of charge stays reasonably stable and the battery generally holds charge well. When the car is weak, the battery level may drop somewhat faster, but I think that may simply be because the electric system is not working properly and the gasoline engine is doing more of the work.
    There are no warning lights, no Check Engine light, and no obvious hybrid system warnings on the dashboard.
    One very strange thing is that the problem is sometimes temporary.
    For example, recently I stopped to refuel. Before stopping, the car was suffering from the weak acceleration problem. I turned the car completely off, refueled, and started it again. Suddenly the hybrid system worked almost perfectly again. For about 5–7 minutes, the car had its old electric power back. Even very light throttle was enough to accelerate strongly and the gasoline engine did not need to start. After several minutes, the weak hybrid power returned again.
    I also noticed something concerning with the inverter coolant system.
    The inverter coolant reservoir has the correct coolant level now, around FULL, but when the car is in READY mode there is absolutely no visible coolant circulation in the reservoir. I mean the coolant surface looks completely still — no small waves or movement at all.
    I can hear a small electronic whining sound from the inverter coolant pump, so it sounds like the pump is running, but there is no visible circulation. I have only noticed a few very small bubbles deep in the reservoir once or twice, but not actual coolant movement.
    Both the engine coolant reservoir and inverter coolant reservoir were around the LOW mark when I bought the car. They were not empty, but they had clearly dropped below FULL over time. I topped both of them up, but the hybrid power problem did not improve. The coolant levels have remained stable since then and I have not noticed any coolant loss or leakage.
    Another thing I noticed recently is a slight whistling / air-blowing type noise when I press the accelerator. There has always been a small high-frequency electronic whine from the hybrid system, but now under acceleration I sometimes hear a slightly different whistle that sounds almost like air being blown. I am not sure where exactly the sound is coming from.
    The 12V battery is new, replaced about 2–3 months ago. I am not referring to the hybrid battery here. The car has the original lithium-ion traction battery, and given the low mileage and the fact that it holds charge well, I have not replaced it.
    At the moment I am wondering whether the problem could be related to the inverter cooling system:
    • Could there be air trapped in the inverter coolant loop?
    • Could the inverter coolant pump make noise but still fail to circulate coolant properly?
    • Could poor inverter cooling cause the hybrid system to limit electric power without immediately producing a warning light or DTC?
    • Could the system temporarily work normally after a restart and then reduce power again as the inverter heats up?
    I am planning to have the car properly diagnosed with Toyota Techstream / hybrid live data, but before I do that I wanted to ask the Prius community.
    What would you check first based on these symptoms? Could this be an inverter coolant pump / trapped air / cooling circulation problem, or should I be looking somewhere else such as the inverter, transaxle, MG2, or hybrid battery?
    Any advice from experienced Prius owners would be greatly appreciated.
    Thank You!
  2. BiomedO1
    4,616
    2,416
    Left Coast
    Sorry; a US version 2017 Toyota Prius Two Eco won't go 62 mph on battery only. It's possible the European software version will allow this; but I know for a fact that the US software will NOT allow that. See pages 231-233 of the owners manual.
    Toyota Manuals and Warranties | Toyota Owners
    Don't know what your being told; but I'd probably run the VIN on US databases to see what your actually dealing with and what modifications and/or repairs has been made to that car.
    Good Luck....
    Ruslan77 likes this.
  3. Ruslan77
    Ruslan77 New Member
    Georgia
    Two Eco
    I know it sounds unusual, but I’m not saying the car can normally accelerate to 100 km/h on battery power under heavy throttle. What I mean is that when I gently press the accelerator, the gasoline engine does not start, and the car continues accelerating electrically. Before this problem started, it could gradually reach around 100 km/h this way. I’m talking about very light/moderate acceleration, not flooring the pedal. Now, with the same light throttle, the electric power is much weaker and the gasoline engine has to start much sooner.
  4. BiomedO1
    4,616
    2,416
    Left Coast
    It doesn't matter how light the throttle is applied; USA Prius, non-Prime, will kick-on the gasoline engine beyond 25mph. I've heard European models are programmed differently; though I haven't experienced it personally.
  5. Mendel Leisk
    42,352
    Do you have a code reader, or can you get access to one? Techstream (Toyota's proprietary software would be best bet). Even without dash warnings there might be codes.
    How long have you had it, longer than the 3~4 weeks the issue's been manifesting?
    First suspect would be inverter water pump, but it's very low miles/kms.
    Just to clarify, your "Georgia", is not the US State, it's the country to the east of the Black Sea?
  6. Ruslan77
    Ruslan77 New Member
    Georgia
    Two Eco
    My Prius is a US-spec car imported from a Copart auction from the United States. The VIN is JTDKARFU8H3033682. The dashboard can even be switched between metric (km/h) and imperial (mph), so it is definitely a US-market Prius.
    I’m not confused about the market. I own the car, imported it from the US myself, and the VIN confirms it’s a US-spec Prius.
  7. Ruslan77
    Ruslan77 New Member
    Georgia
    Two Eco
    Thank you for your reply.
    I don’t have a scan tool yet. Would a regular OBD-II scanner be enough to see useful hybrid data, or do I really need Toyota Techstream?
    I’ve owned the car for about one year, and it has never behaved like this before. The problem only started about 3–4 weeks ago. The difference is very noticeable—the car feels much heavier and much more sluggish than it used to be.
    Interestingly, the problem has disappeared once or twice, but only for 2–3 minutes after restarting the car. During those few minutes, the hybrid system felt completely normal again, then the weak acceleration returned.
    The car was imported from a Copart auction in the United States, but I currently live in Georgia (the country, east of the Black Sea), not the U.S. state of Georgia.
  8. bisco
    52,862
    could the inverter coolant pump be bad?
  9. bisco
    52,862
    when-does-gas-kick-in.187744
    post #15
    The Gen4 limit for running in EV mode is 68mph - this is about 110km/h. Beyond that speed MG1 would exceed it's 17,000 RPM limit
  10. Mendel Leisk
    42,352
    Autel MaxiAp AP200 is an inexpensive Bluetooth dongle that’s highly recommended here. It’s around $80 USD, and you’re entitled to one car’s data for that price, if I’m not mistaken. More cars require an extra charge I think.
    it interfaces through your phone, and is apparently quite complete in it’s capabilities. I’ve never had one so just passing on info. Someone with more knowledge may add details.
  11. rjparker
    11,116
    6,974
    Yes high inverter temperatures caused by a marginal inverter coolant pump can lower power and or disable air conditioning. There have been cases where the light flashes and goes away.
    No movement of fluid in the inverter coolant reservoir is a clear indicator. It should run anytime the car is in Ready.
    Be sure you are not looking at the engine coolant reservoir which can be very still until the thermostat opens.
    Typically a failed inverter coolant pump would provide a "Malfunction" warning light and or message (“Hybrid System Overheated. Reduced Output Power").
    A weak hybrid battery would also provide a "Malfunction" light and or a "Have Traction Battery Inspected."
    #11 rjparker, Aug 1, 2026
  12. Ruslan77
    Ruslan77 New Member
    Georgia
    Two Eco
    I don’t get any warning lights at all. There is no Check Engine light, no Hybrid System warning, and no other warning messages on the dashboard. Should I still have the inverter coolant pump checked, even if there are no warning codes?
  13. rjparker
    11,116
    6,974
    Measuring inverter coolant temperatures is possible with a scanner but the acceptable temps are much lower than engine coolant temperatures. Typically less the 65c.
    Fix it.
    #13 rjparker, Aug 2, 2026
  14. BiomedO1
    4,616
    2,416
    Left Coast
    I took a quick look at that thread and there seems to be mixed results. People committing with gen3, gen3 PiP or gen1 PiP, gen4 mix of regular and Pip - Primes and European software configurations.
    If you drop down to post #17, he actually mentions Prime and the regular non-Prime MG1 is the theoretical 62mph max. The Prime has an extra clutch that allows it to reach 82 mph, before the ICE is forced on.
    IMHO; anyone claiming 40+ mph in EV only needs to tell us what exactly they are driving and what software they have. The standard non-Prime battery pack is small and would generate a lot of heat and would switch-on the ICE to protect the pack.
    My Prime, at highway speeds throws off a lot of heat in EV mode. That's with a much larger battery pack at just 60-70 mph. I usually manually switch over to HV; since the ICE is more efficient above 50 mph sustained.
    YMMV
  15. bisco
    52,862
    i think someone else mentioned intermittent operation
