How can i install li-ion batterys on my prius
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Ssss4, Aug 2, 2026.
  1. Ssss4
    Ssss4 New Member
    Georgia
    Hi i have 2010 prius how can i install ford fusion li-ion batteries on my prius and can yall tell me what will i need and if there are some kind of schemes that i could use.any advice would be helpful
  2. Tombukt2
    13,864
    2,519
    Everyone that tries these kind of modules li ion they never work correctly . Not sure the issue and really don't care but people have tried
  3. bisco
    52,862
    just wire them up in parallel, shouldn't be a problem
  4. Tombukt2
    13,864
    2,519
    You have to wire the mess up until you make 200 volts .
  5. Tombukt2
    13,864
    2,519
    The fusion outage is 281V I wouldn't be afraid to try a whole pack like that in a Prius I've seen close voltages in a Prius . Probably won't hurt a thing If try it if I had the pack. There's some other things that plug up to the battery pack that may have to be sorted
  6. bisco
    52,862
    I'd just wire it up in a box in the hatch and see how it performs
  7. bisco
    52,862
    maybe rewrite the bus software to prevent an explosion, or maybe use the bus from ford
  8. rjparker
    11,116
    6,974
    The problem is the hybrid system monitors 14 battery voltages (2 modules each) and the total voltage. It expects the voltage charge discharge characteristics of niMh and the system will code and go as far as shutting down if the characteristics are not the same. The most well known seller of lithium retrofits had to fake the voltage feedback resulting in unreliable and unsafe operation. Fires and very short lifespans resulted.
    Lithium also needs more monitoring points than niMh for safety and reliability.
    Another company is working on a retrofit gen3 Prius bms control similar to a successful implementation they developed for Honda Insights.
    The best way to get lithium is to buy a car that was engineered for the chemistry. Toyota used lithium in overseas Prius v's and in certain gen4 and newer hybrids.
    CR94 and Brian1954 like this.
  9. Brian1954
    Brian1954 Senior Member
    2,688
    1,074
    South Central PA, USA
    I don't think so!
  10. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    The safest thing to do is skip the lithium, and put in a Sodium Ion Battery Pack.
  11. bisco
    52,862
    ford has sodium?
  12. ASRDogman
    8,066
    4,089
    Contact Jack....
  13. bisco
    52,862
    jack ford?
  14. ASRDogman
    8,066
    4,089
  15. GLCReviews
    GLCReviews New Member
    2014 Prius Plug-in
    AFAIK Jack only sells Toyota/Lexus, 1 version of the GM Tahoe hybrid battery, and is now offering an awesome and perfectly safe version of Lithium for Hyundai/Kia option. I am not sure the Ford market is really something he thinks is a good venture at this time perhaps?
  16. rjparker
    11,116
    6,974
  17. bisco
    52,862
    he doesn't know jack
  18. GLCReviews
    2014 Prius Plug-in
    I think everyone knows by now that he's the owner of the company right? Is this some proprietary knowledge we're not supposed to be privy to? o_O
  19. rjparker
    11,116
    6,974
    Yes. And most know about the short lived lithiums he sold, his failure to warranty many users and the bogus voltage averagers he used to hide issues. To say nothing of fires.
  20. GLCReviews
    2014 Prius Plug-in
    Have you done exclusive, non biased research into the sodium versions and how well they are performing compared to the Lithium?
