Valve seals or oil control rings? Which most likely?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Doug_M, Aug 6, 2026 at 3:09 PM.
  1. Doug_M
    Doug_M Junior Member
    Boulder Co
    My 2009 is consuming oil, about a quart every 1500 miles or so. The car has 250k miles. I have replaced the PCV valve to no effect.
    If it is the seals I might just persuade myself to replace them... I am planning to look in the cylinders with a borescope to see if they are glazed, in which case I won't bother.
    I did try a piston soak a while back, but I might try it again with a longer soak. How effective is a Chemtool soak? If that makes no difference does it very strongly indicate valve seals, or is it hard to say?
    Are there any other diagnostics than might be reliable?
    Thx.
  2. BiomedO1
    4,600
    2,414
    Left Coast
    More than likely the piston low tension oil control rings. A piston soak is simply a "hail mary"' because it doesn't address the actual issue. It's only going to be a stop-gap measure; if it works.
    The other issue or future issue is that high oil consumption is going to kill the CAT; eventually.
    I would start saving for another engine - NOT a used one. That's gambling and I don't consider tossing $3K+ at a used engine with KNOWN defects - probably ending up in the same place in a year or two. Or sell it.
    Just my 2-cents
  3. Brian1954
    Brian1954 Senior Member
    2,686
    1,073
    South Central PA, USA
    The Gen 2 engines do not have the low tension rings. The low tension rings started in 2010 Gen 3 engines.
  4. pasadena_commut
    pasadena_commut Senior Member
    3,065
    951
    Southern California
    Nevertheless, the Gen 2 oil rings can still get stuck, leading to increased oil consumption.
    If the valve seals are bad in a car typically there will be a puff of smoke at startup, when all the oil which dripped into the cylinder(s) while it was parked burns off.
  5. Doug_M
    Boulder Co
    I was assuming that the problem, if any, with the oil control rings would be that they were stuck. That would be the purpose of a soak with solvents.
    I haven't noticed smoke in the mirror when starting, but perhaps I should enlist a helper and look again.
    If the rings are stuck, how good are the chances that a solvent soak will unstick them??
  6. rjparker
    11,104
    6,967
    Excessive oil consumption is common on old gen2 and gen3 engines. Gen2s may have had an advantage because they were 5k oil changes while gen3 were 10k by the book. Miss one gen2 and you are at 10k the next time while missing a gen3 puts you at 15k-20k.
    The only way to resolve a quart every 1500 miles is with a ring job.
    Valve seals are almost never a problem in modern cars but make sense if the engine is being torn down for rings.
    Plugging your expensive catalytic converter is the real risk with excessive oil consumption assuming you or the previous owner did not run the engine dry of oil.
    #6 rjparker, Aug 6, 2026 at 8:05 PM
    BiomedO1 likes this.
  7. Doug_M
    Boulder Co
    rjparker: When you say "ring job" are you suggesting the oil control rings may be stuck, or that the compression (and oil control rings) are worn? If the latter, it seems that could be checked with compression/leakdown testing and perhaps by looking for the shape of the cross-hatching on the cylinder walls.
    I'm interested that you say that valve seals are almost never a problem. I had got the impression that these engines did suffer from leaking valve seals.
  8. rjparker
    11,104
    6,967
  9. BiomedO1
    4,600
    2,414
    Left Coast
    Old rubber based valve seals used to harden and start leaking - NOT the new formulations.
    Think of getting clay (in this example "sludge") in-between the rings and pistons and baking it. Chemical treatments will soften the surface layers; but you can't scrub between the rings and pistons or spray directly - that's why chemical treatments are a crap shoot. If that build-up isn't deeply baked in; that may work; but 200K miles of abuse/extended oil changes or missed oil changes doesn't solve that issue.
  10. pasadena_commut
    3,065
    951
    Southern California
    My son briefly had a 2007 Tacoma. He bought it from a friend whose father had passed away, and it was the father's work vehicle. It had sat outside for the better part of a year without being turned on or moved. After changing the fuel pump (which couldn't keep up under load) It worked well for a couple months and then literally as he was selling it it started smoking on start up. I don't know if the Prius has the same issue with valve guides going bad when the car isn't used for an extended period.
    There are numerous reports that a Berryman Chemtool B12 piston soak can reduce oil consumption in a 2nd generation Prius. Perhaps in Boulder it is cool enough to do one now. I plan on doing my car but in S. California in the summer it is so hot every day that most of the solvent would just boil off (exiting the cylinder through open intake or exhaust valves, assuming it didn't flash off when it landed on a motor which was 120F or higher).
  11. Doug_M
    Boulder Co
    OP here. I have some more information that I consider quite interesting..
    I pulled the plugs and took a look inside the cylinders with a borescope. There was carbon on the top of the pistons but not really gross big flakes or anything like that. There was no liquid oil visible.
    What was striking was that each cylinder had easily visible cross-hatching everywhere I could see. I made an attempt to measure compression but, due to the limitations of my compression tester, I couldn't get the adapter screwed in well enough to make a seal. I spun the engine for about a second and got an obviously wrong reading (10psi for a car that gets 48mpg) due to the insufficient seal. What was really striking was that the compression tester came out of the plug orifice absolutely drenched in oil.
    The plugs were not oily, so the pattern of an initial load of oil which is burned off while driving seems to make sense. This suggests valve seals, right?
  12. mr_guy_mann
    mr_guy_mann Senior Member
    4,118
    2,014
    NJ-USA
    It is more likely that the oil you had come out was pooled in the intake manifold.
    The Prius uses a "pseudo" Atkinson cycle engine (high compression ratio + late closing intake valve timing). Combined with frequent engine shut off it results in PCV oil vapor condensing inside the intake.
    When you attempted your compression test, it caused a large sudden airflow through the intake - likely blowing a "slug" of standing oil into (& out of) the cylinder.
    That said, most engine teardowns I do at work have carboned up oil control rings. When it's in the "early" stages, the oil rings get stuck & oil consumption goes up, up, up.
    This is where the ash and residue from oil in the combustion chamber will coat the catalytic converter and cause P0420 cat efficiency codes. I mostly see clogged cats from soot (rich run condition) or meltdown (caused by severe misfire)
    When it "gets bad", the compression rings carbon up and wipe out the bore. This is when the spark plugs will oil foul and misfire.
    I just don't see valve seal problems like I did 30 years ago.
  13. pasadena_commut
    3,065
    951
    Southern California
    Do you mean the honing marks? Those are supposed to be there. What you don't want to see are vertical scratches or patches of cylinder wall where the cross-hatching has been worn away.
    Good that your borescope shows those "easily". The borescope I use isn't great at showing them at all, I think because the light is too close to the sideways looking camera so it can't illuminate the "ridges" of the honing marks well. Sometimes they are visible with the axial camera but not reliably.
  14. frodoz737
    frodoz737 Top Wrench
    4,805
    2,561
    33
    You have 250K miles on this vehicle Doug. Perhaps it's just time to rebuild...or replace.
  15. Doug_M
    Boulder Co
    Yes, the honing marks indeed. I was quite impressed after 250k miles.
  16. Albert Barbuto
    Albert Barbuto Active Member
    119
    108
    Northeast USA
    Do an internet search for "Valvoline Restore and Protect reduce oil consumption". You will see people have gotten good results.
