Replace rear drums and brake pads or not?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lento47, Aug 9, 2026 at 3:10 PM.
  1. Lento47
    Lento47 New Member
    Colorado
    As mentioned in another post, just replaced front pads and rotors on my 2009 Prius.
    After test driving, braking with the brake pedal was mostly fine, except for a squeak from the back as the car came to a stop.
    So I cleaned the drum brakes. Then did another drive test. This time, there was no squeak, but I discovered that if I pulled the ebrake from just 5mph, the rear brakes squealed loudly (only when going forward, they didn’t squeal going in reverse). So I investigated further.
    With rear up on jack stands and tires off, turning the drums by hand I discovered that both have a drag/sticky point or two across the rotation when I had the ebrake clicked in 4-5 clicks (ie there were spots of resistance as I rotated them, then easy turning). When I got to 7 clicks they were solidly locked and couldn’t rotate them, which is expected.
    I sanded the pads lightly to remove any glazing, but sticking points remain when I rotate by hand. I’m guessing I have one or two ‘high’ spots in the drums themselves.
    I thought the rear drums were supposed to be good for ~ 150,000 - 200,000 miles. Is this normal to have high spots in the drums at 85,000 miles (and again, it's an 2009)? And is this ok? There were no squeals during normal braking, just when engaging the ebrake. But clearly they are not perfectly round now. Or are these sticking points and ebrake squeal a solid indicator that the drums must be replaced? (I’ve seen elsewhere that replacement is a better option than machining as it’s not that much more.)
    Thanks!
  2. BiomedO1
    4,605
    2,414
    Left Coast
    Don't take this the wrong way; but it sounds like your don't know what your doing and watching YouTube videos to figure it out.
    As a "rule of thumb", the rear needs to get done on the second set of pads placed on the front. That DOES NOT overrule what you find on an inspection, since people forget to release their parking brakes and wear them out that way. IMHO; 7 clicks is excessive - to me 4-5 clicks should be FULL lock; if those rear shoes was adjusted properly.
    Please read-up on theory of operations of a rear shoe set-up and measure to see if it needs replacement. There are OEM specification for replacement intervals for that. NO guessing involved. Squeaks are merely a symptom, NOT a root cause for replacement. Any tire & brake shop will gladly take your money for a full overhaul; when dumping out the accumulated brake dust and cleaning the mechanism will cure that symptom.
    YMMV
  3. Mendel Leisk
    42,348
    Repair Manual info:
  4. Tombukt2
    13,863
    2,519
    That's how they work they go around hit a high spot go around hit a high spot that's just normal because the pads are two pieces not a perfect circle and so on you want them adjusted tightly. The Prius likes a good drag on the rears it will finish the adjustment two minutes after you head down road. Used to be in the old days you used a fish scale to set drag . It was a thing . Look in a 83 Corolla or Celica manual
  5. BiomedO1
    4,605
    2,414
    Left Coast
    LoL; fish scales would really smell-up the shop. I just adjusted the star wheel until I could hear and feel the shoes intermittently touching. After that adjustment; a test drive would settle everything into place and the parking brakes would actually be useful.:cool:
    I've watched kids adjust parking brake cables without looking at the rear brakes FIRST. A rookie/AI move.:cry::(o_O Garbage in - Garbage out; addressing the symptom NOT the underlying problem. :whistle:
