2006 throwing up service lights
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by misterdean, Aug 5, 2026 at 10:11 PM.
  1. misterdean
    misterdean Member
    206
    29
    FL
    red triangle, VSC, and ! in the circle. car won't start unless i disconnect the battery. drives fine after battery disconnected. i'm reading inverter pump. the fluid is moving, very slightly. not sure how much it's suppose to move. also hearing the cheapo code scanners at auto zone are not able to pull codes that are red triangle / hybrid battery related.
    thoughts?
    #1 misterdean, Aug 5, 2026 at 10:11 PM
  2. ChapmanF
    19,025
  3. pasadena_commut
    pasadena_commut Senior Member
    3,067
    952
    Southern California
    Car details, recent maintenance/accident history?
  4. Dennis Brown
    Dennis Brown Junior Member
    33
    Baltimore County
    Three Touring
    The blinking light code will need a source to tell you what the issue is as well as understanding the blink rate. Easy to do but be careful using a paperclip to short between sockets - make certain to count carefully.
    Higher end code readers but well under $200 are well worth the cost. They can read codes and also freeze frame to isolate and tell you what is causing the code in more detail. Get one from amazon with next day delivery. Codes can then be looked up on line or buy a repair guide (extremely useful for minor repair issues, anyway) to get details on the code relative to your model.
    These will pay for themselves many times over because an old Prius will be throwing codes again and again in the future. Knowing what to fix and even ignore can save $$$. Some might be easily fixed by yourself rather than a shop.
  5. misterdean
    misterdean Member
    206
    29
    FL
    130K, had it for 10-15 years. haven't put any money in it besides combo meter 12v battery and regular maintenance. it does however have a history of falsely throwing up services lights. maybe 5 years ago the triangle came up with 4-5 other lights. spooked me and was ready to dump it. unplugged the battery and they all went away. drove fine for maybe another 2-3 years before it happened again. same story, disconnected battery and drove fine for a few more years. once the check engine light came on by itself, same story. the last few weeks the mentioned lights came on + the check engine. this time they came back immediately, minus the engine light. that one never came back. my opinion, the lights lie. something is wrong for sure, but i don't trust what the lights tell me. not sure why the brake lights are coming on. brakes work fine. i know the triangle is hybrid battery. only 2 bars missing from the battery health on the center console. still gets 45-50 mpg. seems to be driving normally after i disconnect the battery.
    not sure if relevant, but the center console screen is really dim. so dim it's not visible during the day due to sunlight reflection. at night i can see it and it does function. it's been dim for a few years. but it just started being dim beyond usability at the same time the dash lights came on.
    #5 misterdean, Aug 6, 2026 at 4:48 PM
  6. reyesgarage
    reyesgarage New Member
    Phoenix, AZ
    Read the fault codes before you disconnect the battery next time. Right now the disconnect isn't fixing anything, it's just clearing the stored codes and dropping the fault latch, which is why it starts again. It also wipes freeze-frame data, so the exact snapshot of what the car was doing when the fault set gets erased along with it. The thing making the car usable is the same thing destroying the evidence you'd need to actually diagnose it.
    That reframes the history too. Five years ago, then again a couple years after, those weren't false alarms. Same fault, real each time, erased three times before anyone could read it. It's not a car that cries wolf, it's one fault nobody's caught yet.
    You're right about the cheap reader. Generic OBD-II only pulls standard powertrain/emissions codes, hybrid and brake-control faults live in separate modules it can't touch. That's exactly why the blink-code method mentioned above is worth doing here, it's free and it reaches that side.
    Also worth knowing: triangle, VSC, and brake light together on these usually means one upstream fault, not three separate problems. The brake and hybrid control chain shares dependencies, so one trip takes the others with it.
    Your pump theory is testable. Just needs a code behind it, not a visual on coolant flow.
    Brian1954 likes this.
  7. pasadena_commut
    3,067
    952
    Southern California
    Hmm. In the era when the MFD display was designed LCD backlights were usually small fluorescent tubes on two opposing sides of the display, run off a high voltage power supply. As the tubes age the power supplies can draw substantially more power. This is based on computer displays, assuming it is the same here. Among other things this often resulted in failure of the electrolytic capacitors in that supply, which would eventually, puff up or leak. I suppose it is possible that the MFD is now drawing so much power it is affecting other systems, although I would have thought a blown fuse would be the outcome, rather than the dash lighting up. Another possibility is that the 12V system is running at too low a voltage. If the OP has a voltmeter perhaps check the voltage between the jump post in the fuse box under the hood and any nearby bare metal (the bolts on the edge of the inverter work.) If that isn't at least 13.5V with the car on then there is a problem with the "12V" system and that should be investigated.
    An OBD2 dongle and some software is still needed though. There are probably codes right now, and they will give a much better suggestion of what might be wrong.
  8. ChapmanF
    19,025
    The lights and trouble codes don't lie, but are often misinterpreted by people who don't look up the full explanations of what they mean, or who make dubious assumptions like "brakes work fine → brake codes can't have anything useful to tell me".
    Most of the codes are intended as warnings, so it isn't surprising that they often appear before the driver notices an issue. If they only appeared when you already knew there was a problem, they wouldn't be warnings.
    The conditions to trigger the warnings are in many cases very specific and elusive, and usually required to come up in two consecutive drives to trigger the warning. So it also isn't surprising that sometimes when you clear them and pass up that first opportunity to deal with whatever issue they were reporting, the next opportunity may come weeks, months, or sometimes years later.
    The brake system in a Prius relies on a properly-functioning hybrid system to handle its part of regen braking and traction and stability control. For that reason, the brake system will always report trouble codes when the hybrid system does. However, the only way to know if those are the only brake system codes you have is to read them.
    The triangle comes on for around two hundred distinct trouble codes, only some of which have anything to do with the battery. You mention knowing that the triangle is about the battery in your case, but you didn't say much about how you know that. That information would help us give you better advice. And really, the best way to help us give you better advice is to post the actual codes: not paraphrase descriptions or what somebody somewhere thought they meant.
    The source for what the blinked code means is the same repair manual where you would look up the alphanumeric codes from a reader. How to understand the blinking is, of course, in that manual too, but also fully explained on the PriusChat wiki page that was linked above, which also explains the easy way to find those codes in the manual.
    Looking up the code meanings online is always dicey. Most of the codes fall either into the manufacturer-defined categories or into the industry-wide categories where they are assigned by SAE. (Many threads here on PriusChat have more detail on that, and how to recognize codes in those different categories.)
    A manufacturer-defined code can mean completely different things in cars from different manufacturers, or even different models from one manufacturer. Those are the ones where, obviously, you have to look in the repair manual for the car model you have, and ignore with extreme prejudice everything you may find online that is different.
    The SAE-standardized codes sound more promising. The good news is, you can search those online and at least the one-liner fortune cookie descriptions that come up will be right. The bad news is, they'll be so generic—"Throttle / Pedal Position Sensor / Switch Circuit B" is one actual example—that you still have to go to your car's repair manual to pin down what actual part of a Prius is the one Toyota decided to identify with that SAE standard name.
    Brian1954 and frodoz737 like this.
  9. Brian1954
    Brian1954 Senior Member
    2,687
    1,073
    South Central PA, USA
    Based on your description, my guess is that you have a P0AA6 trouble code, "Hybrid Battery Voltage System Isolation Fault". You need a capable scanner to read the INF/sub-code for that code to help determine the location of the problem to make troubleshooting easier.
  10. Dennis Brown
    33
    Baltimore County
    Three Touring
    I have all those 'blink' codes in my Prius Gen 2 repair manual. So, just find out which ones, post it, and I can look them them.
  11. DanThePriusMan
    DanThePriusMan New Member
    Saturday
    The Boondocks
    Does your Prius have a fault code right now? If so, I could use your help!! please see below (and DM me if you need any help)
    I’m building B.E.T.S.Y. (Battery, Engine & Toyota Scanner for You), an open-source Android Prius diagnostic app.
    It can already read raw Toyota INF/detail codes from the hybrid ECU using a standard Bluetooth ELM327 adapter. The next step is decoding them, and for that I need real-world captures.
    Looking for Gen 2/3 Priuses (roughly 2004–2015), especially with stored or active faults.
    P0AA6, P3000, P3019, or really any fault is useful. Healthy cars help as controls too.
    You need:
    • Gen 2 or Gen 3 Prius
    • Android 8.0+
    • Bluetooth ELM327 adapter
    Install B.E.T.S.Y., connect, run the capture, then tap Share. Takes about two minutes.
    The app is fully open source, the APK is built from the public source by GitHub Actions, and no VIN, location, or identifying data is uploaded.
    Stored fault code? Even better.
    Please DM me if you need any help getting it working.
    Download B.E.T.S.Y. v0.0.2
