Hello Prius chat members, My wife and I own a 2013 Prius V. Which we purchase new and had 170K miles. At about 145K we had the missing when cold and a good local service shop diagnosed and repaired the cloged ERG. Now we have occasional ratteling on cold start up. On a couple of occations I've check the coolent and observed it a minimum. But it's very irregular. I did the test for CO2 gas in the coolant tank, but the indicator never changed from blue. In the last month I have lost two full coolant tanks with not a drop on the ground. Most mornings it does not rattle. Today I pulled off the wiper assy. Plastic covers and removed the coils and plugs. Using my new Velvor bore scope I've posted what I think is steam cleaning of a piston and cylinder head. Notice the area arround the exaust valves are clean of carbon. This is cyl No. 1. I'd like another voice before I tear this car abart further. My wife loves this car. As far as she is concerened she would drive it another 170K miles. No milky oil. I did get an over heat warning light for five seconds last week when the coolant ran low while driving. There are no other codes. Just the 117 from the temp sensor. Should I go forward with a Head Gasket Job? Thanks
You need to fix it quick. Overheating will warp the head making a gasket repair fail and too much coolant in the cylinders can bend rods or blow holes in the block. “Hey Walt…”
Greetings, I'm faced with your situation on my 2013 Prius V, 150,000 miles. Cylinder 1, occasional misfire...rattle on start up, minor, sometimes without the check engine light, very subtle....goes away after maybe twenty seconds. I'm losing about a cup of coolant every month. So...... youtube..... and,,,, I know this is not gonna go over well here but some guy put Barr's stop leak in his and it.... so far...... worked..... I'm thinking I'll put a couple of Barr shots in mine and cross my fingers. Has anyone else tried Barr's as a solution?
It is short term and can clog your heater core (a $2,000 repair) and radiator which is micro channel. All for 3-10 weeks of hg denial.
Hello Hirshwin, I went ahead and did a Bar's small treatment, and so far so good. I drive the car daily, have had no rattle start ups and it's running better than it has in over a year. I didn't put very much Bar's in, I wish I measured it but was less than half the container. I followed their directions and I'm hoping it's fixed. I caught it early, knew it was number 1 cylinder, wasn't losing much coolant and now the level stays normal. I hear what rjparker is saying.... we'll see what happens. I've driven my V for a couple of weeks, put almost 200 miles on it. I'm in Wilmington NC so no interstate just city driving and it performs great, stop light start ups smooth, no misfire, no codes.....
@priusesforever @Hirshwin You guy should monitor your ECT, since you know you have an issue. Going into the summer months, as your engine starts running hotter - the hot exhaust gases is going to push that bar's leak band aid out of the way. Your engine dummy lamp doesn't light-up until the temperature reaches 248+F. Anytime your running near 240+F; head gaskets pop and/or components can warp - especially all the plastic they're using on modern cars now. Just food for thought.....
Coming soon to a sealer repaired engine near you... “Hey Walt… they want to wait and see if it gets worse…”
EGR system clogs, engine overheats and/or heats asymmetrically, head gasket starts leaking coolant into cylinders. Does it seem logical at this juncture, that cleaning the EGR system will stop the already leaking head gasket?
Our last used car was when we were young, poor, and I was a serious diy’er by necessity and choice . That was 1985
Update on my Bar's cocktail. 500 + miles later and everything's better. The ICE starts smoother than it did when I bought the car, oddly my gas mileage has improved by about 10%, I'm over 42 mpg now... and losing no coolant. Knock Wood, I reversed measured my Bar's container and it turns out I put a third of the container in the Prius, about 11 ozs. followed their instructions and left the heater turned on high for the first week or so of driving.
I did the same exact thing you did and had the same result "for a while"... It could buy you time, while it's doing that, make plans for a proper head gasket repair. My issue returned, and with more of a vengeance, overall its risky to keep dropping coolant into the Cylinder so my only advice is have a plan as when the BARS fails it will be worse then before. P.S. during engine tear down, a 1/2 container or less of BARS had minimal if any impact on clogging passageways. I did not inspect the radiator however but had no cooling woes. Just my experience, I decided to repair versus increasing quantity of liquid seal due to the inevitable failure.
It's been over 3 months and 1100 miles with the Bar's administered and the car is doing fine. Runs great, no coolant loss and gas mileage still high. I'll keep knocking wood and report back in at 2000 miles or coolant loss, whichever comes first.
Sounds similar to my head gasket issue. With the combustion gas tester it would take ages before it would change color. Aside from that it would have the startup stumble and would lose coolant slowly, like maybe a teacup every week or so. My EGR was clean, I suspect what did it for me was the water pump. The plastic encased rotor swelled and was pretty bindy in the water pump stator housing. I replaced the pump at the same time.
Hello Prius chat readers, My coolant loss was random and infrequent but when it occurred my coolant went from hi to low quickly. The last time was headed to the local airport to catch a flight. The engine head light did light up for a few seconds. I made my flight. When I returned a few days to my car I added water and chanced it home. That was point where I did not want to chance it any more. I did my own diy head gasket job. Thanks to the many fine YouTube video tutorials out there I was successful. I did go to some extra expenses . Fel-pro head gasket kit, New oem Asin water pump, I replaced all rubber hoses that were disconnected . Understanding the timing was critical. New fel- pro head bolts as well. Luckily I found an excellent machine shop. Take a few photo as you disassemble is my advice. Now almost 3 k later it drives like new. It I had to do it again I would just get a Toyota head gasket set as it’s more complete. Don’t wait on a proper repair as these cars still have a lot of value. Machine shop alone was 250. Add everything else and I spent over a thousand.
Agree. FWIW the Toyota head gasket has been revised. What’s referred to as the overhaul kit (by Toyota) is more complete.
Well, One more update on the indestructable Prius 2013...not exactly. Still running perfect on my dIy head gasket job. I´m glad I had years of auto tinkering and tools and very good youtube instructions to follow. As I I had some increased oil consumption, my first 3K I ran Valvoline 5-30 restore. I just did my first oil change since repair and went back to 0-20 valvoline restore. I feel I am very aware of how this engine feels and sounds. Owning the car since new. Both my wife and I feel the engine runs quieter, smoother and more powerful on 0-20. Does anyone else agree? I could hear the valve train much louder with the 5-30. BTW we had a significant loss of mpg with the 5-30. maybe 8%. Anyone have experience with a 5-30 switch?
