Break in oil change?
Discussion in 'Gen 5 Prius Main Forum' started by jacklee95401, Jul 30, 2026.
  1. Preebee
    Preebee Senior Member
    898
    783
    Midwest
    2026 Prius Plug-in
    SE
    If Toyota isn't the exceptional brand, who is?
    I'll let the resale value do the talking on Toyota's quality, or lack thereof. Last two for me returned 95% of the MSRP when sold (to dealers).
  2. BiomedO1
    4,631
    2,427
    Left Coast
    IMHO; Don't tell your dealership that your running 0W20 - Dealership can use that as a basis to VOID your warranty. You don't want that fight.
    You've got at plug-in and running 80% in EV mode - so your only working the ICE 20% of the time. IMHO; I would do oil changes every 5K mile NOT every 6 months. That would be every-time the maintenance lamp turns on; that's assuming that the software is still on a 5K miles trigger base, like the gen4. As long as your using good quality, full synthetic oil, you should be good. If the oil turns really dark brown to black, then you need to increase the intervals, but I'm pretty sure your only going to be a light amber at 5K mile intervals. I do 10K changes on my gen4 and running the same EV-HV ratios as you are and my oil gets to be a dark amber or very light brown. I need to use a tissue paper to find the oil level on the dip stick for about a month, after my oil changes. I've calculated that I have around 7.5K max actual ICE miles on the clock. When I do run the ICE, I make sure it's running for at least 15 minutes solid - meaning engine gets up to temperature and then some to burn-out evaporate any moisture and fuel accumulated in the oil.
    It's a different story for a non-plug-in.......
    Hope this helps
    PS: don't forget to change your ATF around 50K miles - that's turning all the time, no matter which mode your in...... I believe your transmission takes the newer specific ATF formulation as opposed to my generic ATF-WS.
    Good Luck...
  3. Mendel Leisk
    42,358
    For 2023 model year at least, Toyota USA grudgingly "allowed" 0W-20, but advocated 0W-16 (see attached). They may have moved the goal posts since. Do you think a dealership would be able to discern oil weight, and they would be inclined to do that, and that a need to do that will arise?
    And then, the Toyota Australia 5th Gen Prius Owner's Manual is likely still mentioning 5W-40.
  4. jacklee95401
    jacklee95401 New Member
    San Francisco Bay Area
    2026 Prius Plug-in
    XSE
    Appreciate everyone's opinion. Regardless I am going to have the oil change this weekend at ~2.6K miles, it costs me $27 in oil/filter plus $40 labor, basically for a peace of mind. I have always done 1K miles initial oil change on our 08 RX350, 17 ES350 and 24 NX350h. With this plug in it is driven 80% in EV mode so I figure I could stretch it to 2.5-3K miles.
    Arthree, ColoradoBoo and frodoz737 like this.
  5. BiomedO1
    4,631
    2,427
    Left Coast
    My 2021 Prime calls for 0W16, don't know if the 2026 is down to 0W8 yet - but I know other Toyota engines started using that in 2024 or 2025.
  6. ColoradoBoo
    ColoradoBoo Senior Member
    1,354
    982
    Monument, Colorado USA
    Yep our 2017 Prius was 0W-20 but the 2021 Prius went down to 0W-16. I was half-expecting my wife's 2024 Corolla Hybrid to take 0W-08 but she, also, just takes 0W-16.....and I'm thankful....the 0W-08 is nearly impossible to find, still. (I buy oil all the time and only remember seeing it on the shelves once.)
  7. Mendel Leisk
    42,358
    I’d suspect this “downward motion” is in fact just decisions made ‘round a boardroom table, and nothing tangible has changed, with the engines.
  8. Arthree
    Arthree New Member
    Edmonton, Alberta
    2026 Prius Plug-in
    XSE
    Is it possible that, over time, manufacturing quality and tolerances have improved, and those improvements mean that engines built in later years don't need a thicker oil to compensate?
  9. Mendel Leisk
    42,358
    Funny, 0W20 used to be the bleeding-edge, thin oil. I doubt anything significant changes in engine design specs, for any year of a particular generation.
  10. Hammersmith
    Hammersmith Senior Member
    2,494
    2,552
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    But I bet each engine is initially designed with the next oil in mind. For example, I bet the current M20A was designed with 0W-8 in mind. They introduced it with 0W-16 and then saw how it did. Once they got back enough engines with high miles to tear apart and examine(and once 0W-8 availability was high enough for the change to be feasible), they felt comfortable making the switch to 0W-8, model by model.
    I was a little tempted to switch to it myself, but then Valvoline released Restore & Protect in 0W-16. Keeping my rings clean is my number one priority, so I'll go with VRP 0W-16 over TMGO 0W-8.
    I personally find the whole "It'S ToO tHiN" argument rather irrational. Based more on "feelings" rather than hard data.
  11. Preebee
    898
    783
    Midwest
    2026 Prius Plug-in
    SE
    Same thing might be said over not following the manufacturer's recommended oil change interval. ;)
    Trollbait likes this.
  12. BiomedO1
    4,631
    2,427
    Left Coast
    People think that thicker oil means better wear protection; but as you stated newer manufacturing equipment means that OEM can get better tolerances. The thicker oil is a throwback from bygone years when machines couldn't reliability manufacture within 10%-15% of specifications in bulk quantities. The thicker oils filled in the gaps and made engines run better and burned less oil.
    Today's tolerances are much tighter and today's engines has that start stop feature. We all know that firing up an engine in the morning, is kinda of a dry start - until the oil pump gets oil up to the valve train up top. If your running thicker oil; say 40wt. and you engine turns off then restarts; how long will it take 40wt. oil to lube the valve train as opposed to the specified 16 or 20 wt. oil?o_O There's also the issue of the oil driven variable timing - thick oil small passages.:whistle:
    YMMV......
