Normal Coolant Temps for Gen 3 Prius on Long Uphill Climbs?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by marksky57, Aug 14, 2026 at 1:29 AM.
  1. marksky57
    marksky57 Junior Member
    Phoenis
    2010 Prius, 260k miles. Coolant temp reaches about 209°F on flat highway driving in Arizona summer heat. Recently repaired a P261C electric water pump circuit issue. No current warning lights or codes. Concerned that sustained mountain climbs in 100°F+ weather could push coolant temps beyond 215°F. What temperatures are other Gen 3 owners seeing on long grades, and what components should I check first: water pump, radiator efficiency, thermostat, airflow, or cooling system contamination?
  2. Brian1954
    Brian1954 Senior Member
    2,690
    1,076
    South Central PA, USA
    I see 195 to 199F on flat road 70mph. Going up a long incline, I see 202 to 207F.
    The engine water pump and checking the air flow through the radiator would be the two things I would check.
