Did i void my prius's warranty?
Discussion in 'Gen 2 Prius Technical Discussion' started by evil_lbt, Feb 17, 2007.
  1. evil_lbt
    evil_lbt New Member
    hi all
    I was foolish enough to not drive in my prius to the dealer to get oil changed at 5000 miles. I took at in @ 7600 miles ( i drive a lot due to my job)
    does that automatically void my car's warranty?
    thanks
  2. Rest
    Rest Active Member
    1,210
    CA
    Yep you're done. Nothing left to do now but to sell it.
    Seriously though....no it doesn't void the warranty unless Toyota can prove you have oil related engine damage due to the additional 1500 miles. I guarantee your oil can go more miles than that and not hurt the engine. And even further still if you use synthetic oil. You don't even have to get the oil changed by a Toyota dealership or any dealership.....you can do it yourself and keep your warranty good.
  3. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(Rest @ Feb 17 2007, 03:39 AM) [snapback]391970[/snapback]</div>
    And of course, even if it had done damage (and it probably couldn't if only done one time, even with dino oil), only the engine would be out of warrantee, nothing else.
    Dave M.
  4. Rest
    Rest Active Member
    1,210
    CA
    One thing I should point out is that an engine is pretty tough and even if you went 10,000 miles on dino oil it wouldn't hurt it. Sure the oil would be dirty but it still wouldn't hurt the engine doing this once.
  5. tochatihu
    tochatihu Senior Member
    9,513
    3,672
    Kunming Yunnan China
    2001 Prius
    Hi Ryan, as your engine oil has now been changed, I would recommend that you take a sample of the current batch when it is due to be changed and have that analyzed. The procedure is relatively simple and will cost you an additional $20.
    In all likelihood the results of that analysis will show that your Prius engine is in fine shape. Then you can go back to enjoying it and put this minor incident out of your mind.
  6. Rest
    Rest Active Member
    1,210
    CA
    <div class='quotetop'>QUOTE(tochatihu @ Feb 18 2007, 09:33 PM) [snapback]392793[/snapback]</div>
    Going 1600 miles over the recommended change time will NOT result in engine damage nor does it need an oil analysis.
  7. ceric
    ceric New Member
    1,114
    Fremont, CA
    Relex, Ryan.
    Just follow the schedule from now on.
    We are not talking about 20K miles w/o oil change here.
    With my '98 BMW, if I had strictly followed the computer, the first scheduled oil change was due at 14K miles.
    No kidding. Not synthetic either. Of course, I love my BMW more than THAT. <_<
  8. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    <div class='quotetop'>QUOTE(Rest @ Feb 17 2007, 05:39 AM) [snapback]391970[/snapback]</div>
    Sell it? After running the oil that long? Good luck with that!
    Out of the generocity of my heart, I'll haul it away for free. It won't cost you a dime to get that oil-burning, out-of-warranty Prius off your hands.
    What do you say? B)
  9. Ichabod
    Ichabod Artist In Residence
    1,794
    Newton, MA
    ryan,
    Tony is giving you a GREAT deal there, and I suggest you take him up on it right away. He might change his mind and not want to do you the favor if you don't hurry.
    (Tony, when he gives you the car and you sell it, I want a cut).
  10. bhaynnes
    bhaynnes Member
    225
    Belmont CA
    <div class='quotetop'>QUOTE(TonyPSchaefer @ Feb 20 2007, 05:57 AM) [snapback]393218[/snapback]</div>
    You are a Saint. It should be Saint Tony. You are all heart guy. :p
  11. dmckinstry
    1,034
    <div class='quotetop'>QUOTE(bhaynnes @ Feb 20 2007, 12:32 PM) [snapback]393463[/snapback]</div>
    Granted, he is. But there are many others of us here willing to make the same offer. Great sacrifice though it is.
    Dave M.
  12. nicoss
    nicoss New Member
    304
    Lets start the bidding without the seller :p
    P.S: I think we scared the OP away :lol:
  13. jayman
    jayman Senior Member
    13,439
    641
    Winnipeg Manitoba
  14. Rest
    Rest Active Member
    1,210
    CA
    <div class='quotetop'>QUOTE(jayman @ Feb 20 2007, 11:14 PM) [snapback]393662[/snapback]</div>
    There is no "Doubt" about it. Running 1600 miles past with regards to oil changes does not damage the engine nor does it void the warranty. This is a non issue!
    Now if you do this all the time it could shorten the life of the engine and Toyota could possibly challenge a warranty claim down the road. But going over the mileage limit once in a while is no big deal.
    Remember there is also a time portion to oil changes with the warranty. I have rarely follow it, I only use the mileage and once a year (for limited use vehicles). I've had one engine malfunction due to oil starvation over the years and the manufacure replaced the engine under the warranty. Even after receiving my hand written owner record of doing oil changes myself.
  15. santana
    santana New Member
    <div class='quotetop'>QUOTE(Rest @ Feb 21 2007, 07:27 PM) [snapback]394266[/snapback]</div>
    just wanted to join in the discussion on oil changes. First off the M.F. act protects you if you use synthetic oil or different(longer) oil changes. As far as usability of synthetic oil I have ASTM tests comparing oils in key relevent areas. THe areas would be friction (4 ball wear test), volatility (how fast it evaporates when it is hot). In europe oil changes for the same engines are 10,000mi. Using the correct oil you can do that and improve your gas mileage and decrease wear on your engine. [attachmentid=6648]
  16. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    <div class='quotetop'>QUOTE(tochatihu @ Feb 18 2007, 06:33 PM) [snapback]392793[/snapback]</div>
    I would agree with this, just incase when the engine does need work done(not necessarily because he missed this oil change but later downt he road) and toyota wants to challenge him, he has proof that the car was fine at the time. just a little CYA. you never know, they might want to prorate the repairs or something based on this oil change.
    And I know waiting this long to change the oil is no problem at all. just dont do it all the time or ever again. Just bad pratice.
  17. evil_lbt
    evil_lbt New Member
    cool
    thanks all
    sorry haven't had time to get back to you guys due to work.
    thanks again
  18. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    <div class='quotetop'>QUOTE(ryan lin @ Feb 23 2007, 10:27 AM) [snapback]395206[/snapback]</div>
    Say what? You work instead of posting and reading on PriusChat? Hmm, I'll have to explore that option...
    I've been debating the time for the next oil change myself. It's been 6 months since my last change, so the Mainenance Required light just started flashing on the dashboard when I first start up. Thing is, I've only gone 4,000 miles, so I'm inclined to push it off a month.
  19. dmckinstry
    1,034
    <div class='quotetop'>QUOTE(nerfer @ Feb 23 2007, 08:47 AM) [snapback]395217[/snapback]</div>
    I'm convinced that there are people here that live on PriusChat. Some with over 10,000 posts in a years.
    Dave M.
  20. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    <div class='quotetop'>QUOTE(nerfer @ Feb 23 2007, 11:47 AM) [snapback]395217[/snapback]</div>
    Yeah, I'm beginning to doubt the sincerity of this new Prius Owner......... he neglects his vehicle by not following recommended maintenance oil changes, and now we find out he's got a job and can't pay 100% attention to his Prius and keep current with the posts here on PC........... Hhhhmmmmmm B) B)
