Mercedes E320 Bluetec Diesel
Discussion in 'Other Cars' started by IsrAmeriPrius, Feb 21, 2007.
  1. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    In the Los Angeles Times:
    [Excerpts]
  2. Tideland Prius
    16,499
    did someone post that the one of the new VW diesels is T2B5 rated? i.e. better than the E320 Bluetec?
  3. Jonnycat26
    Jonnycat26 New Member
    1,748
    New Brunswick, NJ
    <div class='quotetop'>QUOTE(Tideland Prius @ Feb 21 2007, 07:04 PM) [snapback]394215[/snapback]</div>
    I didn't post it, but yes it is. And the VW does it without any urea injection system.
  4. Tideland Prius
    16,499
    <div class='quotetop'>QUOTE(Jonnycat26 @ Feb 21 2007, 03:07 PM) [snapback]394217[/snapback]</div>
    yeah.. so.. what's the difference? Is it because the E-Class uses a larger engine or what?
  5. Jonnycat26
    1,748
    New Brunswick, NJ
    <div class='quotetop'>QUOTE(Tideland Prius @ Feb 21 2007, 07:20 PM) [snapback]394232[/snapback]</div>
    I don't know, but it may have something to do with the particulate filter... here's the quote from VW's press release:
  6. Tideland Prius
    16,499
    <div class='quotetop'>QUOTE(Jonnycat26 @ Feb 21 2007, 03:44 PM) [snapback]394246[/snapback]</div>
    Must be the NOx reduction that gives it the Bin5 standing.
  7. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    Could be because of vehicle / engine size too. I read that larger VW TDI's like the Passat and Touareg will use a urea system.
  8. Jonnycat26
    1,748
    New Brunswick, NJ
    <div class='quotetop'>QUOTE(seftonm @ Feb 21 2007, 08:10 PM) [snapback]394259[/snapback]</div>
    The Touareg maybe... but the Passat has always used the same diesel engine that the Jetta/Golf has.
  9. seftonm
    seftonm Member
    408
    78
    Winnipeg, MB
    The most recent Passat and Jetta TDI's had different engines here. (are you in Europe?) Passat was a 2L, Jetta was the popular 1.9L. The new Jetta TDI will have a 2L common rail engine. I can't remember what the next Passat TDI will have. Perhaps the extra fuel needed to move the heavier Passat makes more NOx than the Jetta catalytic converter system can process.
  10. Jonnycat26
    1,748
    New Brunswick, NJ
    <div class='quotetop'>QUOTE(seftonm @ Feb 22 2007, 12:16 AM) [snapback]394365[/snapback]</div>
    Ack, you're right... the passat was a 2L, which is the same size as the new TDI engine in the Jetta. And the new engine makes more power than either old engine, so I don't see why it couldn't be used in the new Passat.
  11. JSH
    JSH Senior Member
    2,605
    140
    PDX
    <div class='quotetop'>QUOTE(Tideland Prius @ Feb 21 2007, 06:04 PM) [snapback]394215[/snapback]</div>
    That was most likely me you're quoting.
    The 2007 Mercedes Benz E320 CDI meets Tier 2 Bin 5 emission requirements. The reason that Volkswagen withdrew their diesels from the North American market in 2007 is because they use a proprietary Pumpe-Düse injection technology. All the other automakers use common-rail injection technology from 3rd party suppliers like Bosch. VW’s PD injection system will not meet the new North American emission requirements though it still meets the EU’s current regulations. For 2008, VW is switching to a common-rail system.
    M-B, BMW, and VW have announced an agreement that they will share the BlueTech technology first introduced by M-B in the new E-Class. The Europeans are looking to use there expertise in diesel technology to counter the Japanese hybrid technology in the quest to improve fuel economy.
    For those that will say that T2-Bin5 is a step back, dirty, just meeting the bare minimum of emission requirements; you’re right. But you also need to look at what other manufacturers are just meeting the bare minimum. For the 44 non-CARB states, all of Toyota’s cars only meet T2-Bin5. The E-Class also gets 20% better fuel economy than a comparable V6 Camry. (E-Class 26/37 mpg vs Camry 22/31 mpg)
    I've had a chance to drive a E320 CDI wagon in Europe and it is a fantastic car. It has way more power and size than what I would need but the E-Class is a joy to drive on the Autobahn. It also returned fuel mileage in the mid 30's averaging 120 mph!
