new owner here
Discussion in 'Gen 2 Prius Main Forum' started by lkylsr, Mar 3, 2007.
  1. lkylsr
    lkylsr New Member
    hi all have had my 2007 prius for 3 weeks now getting used to it a learning curve definately .. first question how do you increase the green cars of reused energy on the consumption display .. 2.. questioni was reading about the bladder issue here and its expansion .. 2 tanks of fuel and no more than 7.2 gakllons into tank yes it was 15 degrees out so i can understand a lil had 2 bars left which i thought i had 1/8th left is this the norm here for it ..avg mpg @ 46-47 in cold lately in ny upstate not bad cant wait till this week going to the south warmer temps road trip so lewts pray for 55mpg ...
  2. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :) First... WELCOME to the "Wonderful World of Prius Ownership!" There's so much fun in store for you. PriusChat is a terrific source for practical information and assistance.
    You will increasingly learn to maximize re-generation by 'coasting' whenever traffic permits - thus more 'little green cars' each worth 50 WattHours back into your big, main traction battery.
    As you read more posts regarding the fuel bladder you will find that it's not unusual to pump only 7 or 8 gallons, particularly in cold weather. The theoretical 11.9 gallon capacity is not realistic with the bladder feature. I usually pump from 7 to 8.5 gallons at the last 'non-blinking' pip on the GUESS gauge. I have no fascination of being able to 'brag' that I was 'able to pump 10.8 gallons... some Prius owners seem obsessed with how much fuel they can pump. I treat fuel capacity much as I did light aircraft - it's USEABLE FUEL that's important.
    My advice [for the 2¢ value it may have] is {a} Don't PUSH the fuel to the point of running dry - it's bad for the big battery and can be very inconvenient, even dangerous; {b}Bear in mind that the GUESS gauge is not linear - that is, if you see half of the pips showing that doesn't mean you still have half a tank of fuel available; {c} Don't fall into the trap "Well, I've got over 11 gallons of fuel and I'm showing 41.5 MPG on the display, so I can drive 456.5 miles before needing fuel."
    ENJOY YOUR NEW PRIUS... :)
  3. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    <div class='quotetop'>QUOTE(lkylsr @ Mar 3 2007, 08:41 AM) [snapback]399499[/snapback]</div>
    Regenerating used energy means that you were wasting it in the first place. The trick for getting good mileage is to produce as few green cars as possible on the consumption screen. Anticipate stops, coast as much as you can and minimize the need for using your brakes.
  4. jimmyrose
    jimmyrose Member
    646
    Northern NJ
    I just posted a reply to a thread (sticky) you should read (this had the benefit of "bumping" it up again, if you do a View All New Posts). There's a link in there from efusco that bears reading. And welcome to PC and congrats on your Prius!
  5. Susanne101
    Susanne101 New Member
    46
    Charlotte, NC
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(Susanne101 @ Mar 3 2007, 02:21 PM) [snapback]399548[/snapback]</div>
    Susanne,
    The speed of the scenic route is a sweet spot for mpg. Use of the instantaneous screen rather than the 5 minute average screen will give you a better idea of what is happening.
    Coasting with your foot off the gas causes regenerative braking. Keep a little pressure on the pedal to glide. It takes practice so just be patient.
