Forcing the ICE to Run
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ekpolk, Mar 24, 2007.
  1. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    My apologies in advance if I've missed the obvious here. I've run a couple searches and come up dry. I recall seeing this before, but....
    Anyway, how do you force the ICE to stay on? For example, I just changed my oil, and I like to have the engine idle for a couple minutes with me watching to make sure nothing's leaking. I can't recall the procedure for making it stay on for such purposes. TIA.
  2. DFWPrius
    DFWPrius New Member
    Hurst, TX
    Easy way is to turn on the A/C and set it to max cold or to max heat.
  3. Marlin
    Marlin New Member
    1,407
    Bucks County, PA
    <div class='quotetop'>QUOTE(DFWPrius @ Mar 24 2007, 06:15 PM) [snapback]411637[/snapback]</div>
    Yeah that was apparently how the dealership did it for my car this morning. When I got the car back, the AC was off Auto Mode and set to 75 degrees.
  4. brick
    brick Active Member
    1,083
    79
    Upstate NY
    Never tried it, but I've heard that shifting to "B" mode will do it, too.
  5. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    A while back, there was a rumor that if you hold your foot on the brake and pump the gas three times it will trigger a high rev state that will fully charge the battery. Once the battery it fully charged, the engine will rev down.
    I've never tried it so I don't know if it works.
    Try it and let us know.
  6. ken1784
    ken1784 SuperMID designer
    2,943
    1,380
    67
    Yokohama, JAPAN
    - keep Parking brake on
    - press and keep brake pedal on by left foot
    - shift to D
    - press accelerator pedal to start ICE by right foot
    - shift to N during ICE running
    Ken@Japan
    Yaga1973 likes this.
  7. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
  8. adam1991
    adam1991 New Member
    218
    <div class='quotetop'>QUOTE(ken1784 @ Mar 25 2007, 02:19 AM) [snapback]411787[/snapback]</div>
    In N, the battery doesn't charge.
    At least, according to the owner's manual.
  9. ken1784
    2,943
    1,380
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(adam1991 @ Mar 25 2007, 04:47 PM) [snapback]411815[/snapback]</div>
    You're correct.
    My procedure is just to force ICE running, not for battery charging.
    Ken@Japan
  10. ekpolk
    548
    176
    2018 Prius
    Two Eco
    Ken:
    That's exactly what I was looking for. Thanks very much!
  11. 8AA
    8AA Active Member
    550
    62
    Maryland
    If you don't mind sitting in the car while it's running, just put it in Park and press the gas pedal down part way. The ICE should start and continue to run as long as you keep the pedal depressed. If you want the ICE to run faster, press the pedal down further and it will switch to a higher speed.
  12. ekpolk
    548
    176
    2018 Prius
    Two Eco
    <div class='quotetop'>QUOTE(8AA @ Mar 25 2007, 01:46 PM) [snapback]411941[/snapback]</div>
    I have noticed that it does that, but in this particular case, I want the ICE running while I'm looking at the underside of the engine room, ensuring no leaks right after I changed the oil. I suppose one could prop the gas pedal, but that would be so . . . inelegant. Thanks for the reply, though.
  13. member
    member New Member
    197
    <div class='quotetop'>QUOTE(ken1784 @ Mar 24 2007, 11:19 PM) [snapback]411787[/snapback]</div>
    Is there a repository of these tricks? Where do you get them?
  14. ken1784
    2,943
    1,380
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(Display Name @ Mar 26 2007, 12:09 PM) [snapback]412101[/snapback]</div>
    Just try and observe. :)
    Ken@Japan
  15. moxiequz
    moxiequz Weirdo Social Outcast
    2,781
    Bay Area, CA
    Aside from the PriusChat forum itself, there are the entries in WikiHow at:
    http://tinyurl.com/2nl9sh
    I think Ken's recipe is worthy of a WikiHow page.
