lights on steering wheel
Discussion in 'Gen 2 Prius Main Forum' started by ywbird, Mar 28, 2007.
  1. ywbird
    ywbird New Member
    Does any Prius' steering wheels illuminate?
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(ywbird @ Mar 28 2007, 09:49 PM) [snapback]413918[/snapback]</div>
    They all do. The lights are dim and are not adjustable.
  3. Stev0
    7,201
    1,074
    Northampton, MA
    2022 Prius Prime
    <div class='quotetop'>QUOTE(ywbird @ Mar 28 2007, 08:49 PM) [snapback]413918[/snapback]</div>
    Yes, just very, very badly.
  4. pkittie
    pkittie Junior Member
    LaLa Land
    Just enough to make you think that your vision is deteriorating ;)
    Sezy likes this.
  5. qbee42
    3,081
    I used to think mine were too dim, but now I can read them just fine. I suspect it has to do with knowing the layout.
  6. scargi01
    scargi01 Active Member
    785
    58
    Missouri
    This is the kind of thing that makes wonder about Toyota sometimes. For all the effort they put into making sure the car is designed and built well, when I drove mine at night the first time i thought "Why are these steering wheel lights so dim and how do you adjust them?" One model year I can understand, but after that is irritating. <_<
  7. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    <div class='quotetop'>QUOTE(ywbird @ Mar 29 2007, 10:49 AM) [snapback]413918[/snapback]</div>
    I mounted two small LEDs in front and two in the rear, using extension plugs that run off the front under dash outlet, in order to add some ambient light to the interior. Your comment about the steering wheel lights is well taken, but the whole interior of the car at night is like a bad tavern with a single small TV over the bar as the only source of illumination. My partner's Jetta has a gorgeous red and blue lit interior, maybe a bit overdone, but preferable to the Prius cave. A few little lights adds a lot. And, by the way, you'll get used to the dim lights on the steering wheel and it'll be fine.
  8. ywbird
    ywbird New Member
    <div class='quotetop'>QUOTE(Angel Flight Pilot @ Mar 29 2007, 01:57 PM) [snapback]414442[/snapback]</div>
    Thank you for all the information. I will get used to it all soon, I'm sure. Just thought I was nuts or something because I couldn't find the switch.
