VW Polo Bluemotion first test drive - 64 mpg US
Discussion in 'Prius, Hybrid, EV and Alt-Fuel News' started by clett, Apr 6, 2007.
  1. clett
    clett New Member
    537
    Scotland
    What happens when you take a standard Polo, and do the following two ultra-high tech alterations to the vehicle design:
    1) Close up the radiator grille a little bit.
    2) Put in longer 4th and 5th gear ratios.
    (But keep the standard engine and don't bother with fancy weight saving materials)
    The result is a vehicle capable of 64 mpg in real-life driving, an increase of 24% over standard.
    http://www.autoexpress.co.uk/carreviews/fi...77/vw_polo.html
    Other specifications are:
    0-62 mph - 12.8 s
    Top speed - 110 mph
    CO2 - 103 g/km
    Range - 714 miles
    This kind of thing makes me angry! :angry:
    It's so easy to make these alterations (see Astra ECO4 too), why don't they do this as standard? It doesn't cost them a penny extra!
  2. narf
    narf Active Member
    611
    45
    Colorado
    Four Touring
    <div class='quotetop'>QUOTE(clett @ Apr 6 2007, 05:06 AM) [snapback]418717[/snapback]</div>
    Because it's still a minority of drivers who would buy this car. Most buyers still want faster more powerful cars. You have to build cars for the market.
  3. clett
    clett New Member
    537
    Scotland
    That's not my point, my problem is that to get an extra 15% fuel economy over today's designs is so CHEAP, and has no drawbacks, why don't they do it even on the fast and more thirsty models?
    They were able to cut air resistance by 10% with the ECO4 and Bluemotion with just two bits of plastic!
    It costs nothing extra to add these improvements in mpgs to any car - why do they hold back?
  4. formerVWdriver
    formerVWdriver New Member
    258
    Based on my recent very unhappy experiences with VW, you don't have to worry. The thing won't run long.
    2007 white Prius, six days old
    Before that:
    2002 Jetta TDI (died untimely death 3/07 -- transmission went out)
    1999 Passat GLS (died untimely death 12/06 -- blew a cylinder)
    1987 Jetta (drove 12 years and 215,000 miles, then sold to a family member who drove it to 300,000 miles; it is probably still running and not burning a drop of oil)
    1982? Diesel Rabbit (died after collision with highway patrolman travelling at a high rate of speed, no siren, around a blind curve; case went to state supreme court but we won. Best thing was no one was killed.)
    197? Rabbit (ran fine as long as you didn't run the A/C, which ate alternators; it finally escaped into the woods)
  5. Frank Hudon
    Frank Hudon Senior Member
    4,147
    is that 64 imperial if so it's only 53.2 mpg, US gallon
    opps sorry didn't see it was converted to US
  6. Tideland Prius
    16,540
    omg, now the Polo Bluemotion is gonna cost $5,000-$6,000 more!!! That's putting it in Golf/Jetta territory! :lol: :lol: :lol:
    "at 60mph, the unit revs at only 1,800rpm."
    wow, that's like the Prius!
  7. clett
    clett New Member
    537
    Scotland
    It's £540 more, not $5,000 (even though it's actually cheaper for VW to build it than the standard car!).
    Here the Polo Bluemotion is going on sale for £12,000. By way of comparison to our prices, the Prius goes for between £17,700 and £20,700, depending on specification.
  8. Godiva
    Godiva AmeriKan Citizen
    10,339
    <div class='quotetop'>QUOTE(formerVWdriver @ Apr 6 2007, 12:13 PM) [snapback]418856[/snapback]</div>
    So what happened to VW between 1987 and 1999 to turn their cars into cr@p?
  9. hampdenwireless
    hampdenwireless Active Member
    1,104
    86
    Baltimore MD
    Based on your experience I would say VW's quality is a average. You had a 2002 that lasted 5 years and a replacement trans is bad but not usually a total loss. Then a second car that lasted 7-8 years before a car killing failure. I have known Honda owners that had to put in major repairs after 5 years.
  10. Tideland Prius
    16,540
    <div class='quotetop'>QUOTE(clett @ Apr 6 2007, 03:27 PM) [snapback]419066[/snapback]</div>
    That was supposed to be a joke to Bob Lutz' comment.
    £12,000 is ~$24½k Canadian. That's the price of a fully loaded Corolla LE, Mazda3 Sport GT, Matrix XR, slightly cheaper than an Acura CSX, just under a base Camry LE, about the price of a midrange Sonata. etc etc.
    The Prius there costs ~$3kmore than our Canadian prices (converted UK prices = $35k to $41k)
  11. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Why is the Prius so bloody expensive in the UK and Canada? Particularly Canada. I don't understand the cause of the higher price in that case. In the case of the UK, the shipping costs would explain some of it, but not all.
  12. MPG > HP
    MPG > HP Junior Member
    58
    <div class='quotetop'>QUOTE(clett @ Apr 6 2007, 08:38 AM) [snapback]418781[/snapback]</div>
    Because higher gearing, especially on low horsepower applications, results in unacceptable acceleration, to the extent that freeway merging would be unsafe, due to lack of safety margins from being unable to sufficiently modulate speeds.
    Btw, anyone know the stock vs modified gear ratios used in this example? I'm looking at this mod for my RX-8 which my Prius has garaged for all but track days and long trips. I'm thinking that going from the stock 4.88 final drive to something like 4.11 or even 3.57 would yield both better mileage (like the 24mpg on my previous higher final drive RX-7s as opposed to my current 19 MPG), plus would give me access to 2nd gear at the track (e.g., turn 1 at Buttonwillow, CA, that is now a 3rd gear corner). TIA
  13. Tideland Prius
    16,540
    <div class='quotetop'>QUOTE(tripp @ Apr 7 2007, 12:11 AM) [snapback]419274[/snapback]</div>
    That's a very good question to which I have no answer.
    A loaded Prius is nearly Cdn$39k without HIDs or leather.
    Your loaded #7 (or is it 8 now?) cost Cdn$34k.
  14. hill
    8,784
    <div class='quotetop'>QUOTE(clett @ Apr 6 2007, 08:06 AM) [snapback]418717[/snapback]</div>
    The first thing that happens to me? Chop my legs off so I can get inside. At 6'-5" - 225 lbs big folks don't fit inside. Many manufacturers can make micro cars with high mileage. The trick is to make it high mileage AND roomy (and not a piece of cr@p).
  15. snowdog650
    snowdog650 Member
    171
    28
    Sacramento, CA
    <div class='quotetop'>QUOTE(hill @ Apr 7 2007, 05:55 AM) [snapback]419334[/snapback]</div>
    The Polo is a fine car, but Hill is relatively correct. Polos are teenie weenie ... not bad in the front, but the rear seats are useless, and there isn't much cargo room. Think Plymouth Champ (or Chump, depending on your take on the marvel of engineering).
    So, this Polo will give you the same performance (i.e., 0-60 times), the same mileage (i.e., around 52 MPG), and cost more than a Prius? That and it's a VW, so an oil change will be $70, a timing belt change will be $900.00, and need new rear brake pads and rotors every 23,000?
    I'll stick with the Prius, thanks ... and I LOVE my VW's.
  16. statultra
    statultra uber-Senior Member
    798
    31
    Edison,NJ
    2001 Prius
    im sure by changing my 4th gear on my scion xa i would be getting 40-50 mpg.
    look at the corvette for instance 28 mpg highway, well its becuase of how the gear ratios are and Computer Aided Gear Selection (CAGS)...
  17. Tideland Prius
    16,540
    <div class='quotetop'>QUOTE(snowdog650 @ Apr 7 2007, 10:16 AM) [snapback]419405[/snapback]</div>
    Err.. it costs less than the Prius.
  18. clett
    clett New Member
    537
    Scotland
    <div class='quotetop'>QUOTE(snowdog650 @ Apr 7 2007, 01:16 PM) [snapback]419405[/snapback]</div>
    The Polo gets 64 mpg US (76 mpg UK) on the combined cycle. The highway figure (we call it "extra urban) for the Polo is 89 mpg UK, which translates to 74 mpg (US).
    I agree that it's a small car, but the Astra ECO4 we had here a while ago got similar performance/economy figures using exactly the same tricks but it was a decent (ie Prius) size! Sadly it got pulled from the market despite good sales.
    Any guesses for who built and then stopped the ECO4? GM!!
  19. Tideland Prius
    16,540
    <div class='quotetop'>QUOTE(clett @ Apr 8 2007, 12:27 PM) [snapback]419873[/snapback]</div>
    I don't think extra urban is quite highway. The term is equivalent to our "suburban"
  20. vtie
    vtie New Member
    436
    Gent, Belgium
    <div class='quotetop'>QUOTE(clett @ Apr 6 2007, 02:06 PM) [snapback]418717[/snapback]</div>
    According to Volkswagen, there were a little more changes than that:
    - Lowered by 15mm
    - "Internal changes" to the engine (no details provided)
    - Special fuel-saving tires
    But nevertheless, it's frustrating indeed to see what can happen only if the industry is pushed a little bit. I traded a 2006 Volvo XC70 D5 for a 2007 model (my dealer made a mistake with the delivery). The new D5 diesel engine had a particle filter, with particle exhaust down by 95%, NOx exhaust down by 60%, performance up from 163hp to 185hp, all for exactly the same price!
