Prius Front license plate frame?
Discussion in 'Gen 2 Prius Main Forum' started by 13secPTCruiser, Feb 20, 2006.
  1. 13secPTCruiser
    13secPTCruiser New Member
    Lewes, DE
    can anyone tell me where to get one? i can install it myself with no problem, i just need the frame.
    Thanks in advance
    -Andy
  2. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    hi Andy! welcome to priuschat :)
    your prius should have come with a front plate holder hanging out in a plastic bag in the luggage compartment, under the hatch floor. if it's not there, go complain to your dealer and have them get you one. free, of course ;)
  3. 13secPTCruiser
    Lewes, DE
    yup, that works. thanks a lot.
    it's my moms car, but i really like it and think its an awesome car!
  4. mrbigh
    3,686
    699
    Long Island, NY
    Or you can buy one of this of Ebay. ;)
  5. 13secPTCruiser
    Lewes, DE
    for the front?
    and does anyone know what size screw? to put a plate on? its not a 12 nor a 14... i am gonna check tomorrow trial and error at lowes, but it sure is a PITA
  6. H2OSkier
    H2OSkier Member
    276
    Try M6 1.0 Pitch, can't remember the length. I put on a clear plate cover and had to get longer screws.
    Ken
  7. 13secPTCruiser
    Lewes, DE
    thanks, will try tomorrow.
  8. bnlfanmatt
    bnlfanmatt Member
    253
    Southwest suburbs of Chicago
    As far as screws to put the plate onto the holder, you can go in an auto shop and get screws that usually say "foreign" (as opposed to domestic) and they'll fit the bill. Get anti-theft ones, I always considered them worth the little bit more. If you're talking about holder to car, they should give them to you.
  9. notsure
    notsure New Member
    236
    PHOENIX AZ
    Arizona does not require front plates.........
  10. cgraham
    cgraham Member
    156
    33
    New Mexico
    Did the dealer pre-drill the holes for you? If not, the size screw is not critical. Get rustless.
    In my thread "prep clowns" I complained that the TX dealer drilled big holes in the front bumper in spite of my entreaties not to do so - UGLY, distorted bumper sightly; I was mad, NM requires no front plate. I think the holder is ugly too - big black plastic thing.
    I think the plate would look better (and be more aerodynamic) screwed directly to bumper, using shorter screws (I don't know what's back there, because of the new dams blocking access). You will save about a gallon of gas over the life of the car! Hey - ever little adds up. :)
    C
  11. 13secPTCruiser
    Lewes, DE
    i was talking about the screws to screw the plate onto the frame.
    the holes from the frame to the car were not drilled, only the indentions that i just screwed the screw in without drilling.
  12. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    Finally someone posted my first question with a Prius. I had to call the dealer to find out the holder was in my car the whole time. Boy did I feel smart :)
  13. galaxee
    9,810
    469
    MD
    neither does NC, the state where we bought the car. still got one though. which is good, considering it's registered in a state that technically requires front plates. and we will be needing it when we go back...
  14. R1200GS
    R1200GS Junior Member
    71
    chicago
    bought my prius used and need to put a front plate on. thinking i'll just screw plate directy onto bumper. So...... i can just screw it straight into the bumper where the dimples are with out drilling? thanks
  15. Bill Merchant
    Bill Merchant absit invidia
    4,096
    85
    <div class='quotetop'>QUOTE(R1200GS @ Apr 19 2007, 10:20 AM) [snapback]426126[/snapback]</div>
    One inch stainless metal screws should work. The bumper cover is plastic about 1/8" thick. The dimples are where the plate holder attaches, closer together than the holes in the license plate. You'd be screwing the plate directly to the plastic bumper cover, so be careful not to strip the holes. The plastic plate holder is held on with sheet metal screws, but has machine screw holders to hold the license plate to the holder. Safer if you have to change the plate for any reason.
  16. R1200GS
    71
    chicago
    thank you. :D
  17. hill
    8,732
    <div class='quotetop'>QUOTE(13secPTCruiser @ Feb 20 2006, 03:49 PM) [snapback]213191[/snapback]</div>
    Glad to see you found it Andy. If it wasn't there? I'd have given you mine. I don't like the "Flat" face on it! Makes me feel like I'm pushing a sail, sideways ... and it takes away from the contour of the aerodynamics (pickyou-nie, I agree :D ). Some state don't require a front plate, but Ours is registered in CA, so what I did, was to "form fit it". Got a rounded surface similar to the front bumper and bent it into the same curve as the bumper! hey! that might get me another 1/8 of 1% better mileage on a windy day!
  18. R1200GS
    71
    chicago
    can you post a Pic?
  19. adllewellyn
    adllewellyn New Member
    17
    Houston, Texas
    I bought plates in a state where front plates are NOT required, and live in a state where they are - so I should be able to call the dealer and have them send me the frame? (just trying to understand...)
  20. Jabber
    Jabber Chicagoland Prius Guy
    703
    215
    Chicago
    It comes with the car free if you live in a two-plate state. I would contact your local dealer and see if they can get you one. Might not be free, but at least you will have one.
