Stupid Conservation Ideas from conservation minded folks:
Discussion in 'Fred's House of Pancakes' started by Sufferin' Prius Envy, Apr 23, 2007.
  1. Sufferin' Prius Envy
    3,998
    [***Caution**** Morning coffee spewing hazard ***]
    I wonder if she was smoking her breakfast?
    Cheryl Crow pondering ideas to help with global warming:
    "I have spent the better part of this tour trying to come up with easy ways for us all to become a part of the solution to global warming. Although my ideas are in the earliest stages of development, they are, in my mind, worth investigating. One of my favorites is in the area of forest conservation which we heavily rely on for oxygen. I propose a limitation be put on how many squares of toilet paper can be used in any one sitting. Now, I don't want to rob any law-abiding American of his or her God-given rights, but I think we are an industrious enough people that we can make it work with only one square per restroom visit, except, of course, on those pesky occasions where 2 to 3 could be required."
    http://www.washingtonpost.com/wp-dyn/conte...2101385_pf.html
    EEEWWWWWW!!!!!! DON'T SHAKE CHERYL'S HAND!!!!!!!!
    I sure hope she is compensating by washing her hands at least three times. :blink:
    What dumb conservation ideas have you seen?
  2. SSimon
    SSimon Active Member
    1,426
    N/W of Chicago
    LOL! She looks clean! :D
    Her approach may be a little laughable, but she brings up an important point. I guess equally to how much toilet paper we should use, we could discuss other important qualities of toilet paper. Such as, is it made from recycled paper and is it bleached without the use of chlorine? Chlorine's byproducts are harmful toxins that are thought of as carcinogens.
  3. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    When she says one square, is she referring to one square of single ply you find in most public restrooms, or is this one square of the Charmin quilted 10x ply they're trying to get us to buy now a days?
  4. livelychick
    livelychick Missin' My Prius
    1,085
    Central Virginia
    It may be an odd request, but it's not dumb. It's another way of "reducing," and the underlying thought is probably a good one. I think this was said tongue-in-cheek about the number of "squares"; if you saw her and Laurie on the tour, they were having a blast! Through their discussions on the bus, I'm sure this is just one of the many things that they thought about, as she said in your quote--good for them. And yes, I would dare say that we use more toilet paper than necessary.
    I listened to a great sermon on Sunday about personal responsibility and the environment--how it's time to do the right thing because it's the right thing to do, not because your neighbor is doing it: "The Earth is calling, and she's pissed off."
    This conversation about toilet paper can lead to other conversations about the "disposability" of consumer goods. We use too many paper towels and plates; disposable diapers are ridiculous and have a perfectly good replacement; etc., etc. I've found lots of ways to reduce over the past few years, and while they seem perfectly common to me, they may not be to everyone.
  5. nerfer
    nerfer A young senior member
    2,507
    237
    28
    Chicagoland, IL, USA, Earth
    <div class='quotetop'>QUOTE(livelychick @ Apr 23 2007, 01:50 PM) [snapback]428511[/snapback]</div>
    Of all the places to start, this is not the one that will engender people to the eco-friendly cause! :huh:
    There are easier, and much cleaner, ways to encourage less use of forest products - having napkin dispensers on the tables in fast-food restaurants and cafeterias instead of by the cashiers would help. Some people grab big handfuls before they sit down, and only use half of them at best. But if they're at the table, then you only use what's needed (except for the occasional bored kid). Excessive packaging on products is useless. Or we could put a tax on paper, right now it's cheaper than the ink, which doesn't make sense. Some companies have done very well with electronic signatures and e-mail, but others still go thru reams of paper without thinking about it. Construction companies toss out large quantities of scrap lumber (anything that's no longer 8' long).
    I go along with the OP. I'm pretty environmentally-oriented (my son and I were out working in the forest preserve for several hours again Saturday), but this is either an April 1st statement by her (instead of Apr. 22), or she's really wacked out. About as effective as that duct-tape and plastic defense against terrorist attacks...
  6. galaxee
    galaxee mostly benevolent
    9,810
    471
    MD
    i agree the disposable culture has to stop.
    but passing up on a decent number of TP squares? nuh-uh. i think re-using rags rather than tossing out paper towels makes up for my normal use of TP... :blink:
  7. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Ummmm, Sheryl, let's not forget the bidet!
  8. Sufferin' Prius Envy
    3,998
    <div class='quotetop'>QUOTE(Pinto Girl @ Apr 23 2007, 01:04 PM) [snapback]428576[/snapback]</div>
    True!
    But I can't help but wonder if Cheryl would campaign for increased water conservation by changing the plumbing codes to call for mandatory low-flow bidet models?
    Models which only squirt one ounce per squatting.
    . . . maybe two or three ounces for THOSE days. :mellow: :lol:
  9. Pinto Girl
    3,093
    350
    <div class='quotetop'>QUOTE(Sufferin' Prius Envy @ Apr 23 2007, 03:24 PM) [snapback]428584[/snapback]</div>
    Wondering if gray water is legal for these purposes...?
    We could just retrofit an old water pik, maybe...
  10. Godiva
    Godiva AmeriKan Citizen
    10,339
    Well, during the WWII newspaper was used. It was my mother's job to cut them in squares just so. I asked her if they had problems with the newsprint as I remembered my brother's hands after he got done folding the newspapers for his route. She said....they never checked to see if their butts were black.
    Of course using it this way means you won't be recycling it.
    Maybe Sheryl should develop another sleeve for the other arm like her dining sleeve...only for the bathroom?
  11. ozyran
    ozyran New Member
    695
    Um....YUCK?!?
    I'd rather walk on my hands all the way to work and back before helping out that way!
  12. TonyPSchaefer
    14,816
    2,501
    66
    Far-North Chicagoland
    There was a woman on Oprah the other day who calculated the waste when people grab multiple paper napkins at fast-food places. She suggested that everyone use ONE LESS paper napkin when they go out. I assume that is unless you currently only use one.
    Though this is similar to Cheryl's suggestion, I think it's a little more, uh, palletable.
  13. Wildkow
    Wildkow New Member
    5,270
    37
    36
    <div class='quotetop'>QUOTE(Godiva @ Apr 23 2007, 04:46 PM) [snapback]428702[/snapback]</div>
    I bet it makes great mulch! :rolleyes:
    Wildkow
  14. daronspicher
    daronspicher Active Member
    1,208
    Not to muddy Cheryl's idea with the obvious.... Butt, I don't believe we are cutting forests to make toilet paper.
    Trees are cut for other reasons and all that extra tree junk that's not made into lumber ends up in paper products.
    So, we can let that stuff pile up somewhere and rot, or we can make toilet paper out of it.
    If we ever get our wood use down to where we need to be cutting old growth to make toilet paper out of whole trees then I agree, we should take a look at alternatives.
    Stop printing the top 10 newspapers in the nation tomorrow and go to 100% online. How hard is that?
  15. F8L
    19,011
    4,083
    Grass Valley, CA.
    <div class='quotetop'>QUOTE(daronspicher @ Apr 24 2007, 04:59 AM) [snapback]428920[/snapback]</div>
    The old growth is used to make pristine magazines and catelogs....
    I believe paper products are the largest consumer of forestry material.
  16. hycamguy07
    hycamguy07 New Member
    2,707
    Central Florida
    OMG! Yuck.... :unsure:
    Just do like the men in India do wipe with your left hand with or without paper..... :huh:
    LOL so cheryl how long have you been using the perfume? whats it called? "Essents of nice person". :lol: :lol:
  17. Mystery Squid
    Mystery Squid Junior Member
    I'd shoot right back at Cheryl:
    Hey, howabout women go back to using washable sponges and rags instead of tampons?
  18. roryjr
    roryjr Member
    227
    Warrenton, NC
    <div class='quotetop'>QUOTE(livelychick @ Apr 23 2007, 02:50 PM) [snapback]428511[/snapback]</div>
    I don't remember that verse from my Bible. Which one do you have and what book is it in?
  19. galaxee
    9,810
    471
    MD
    <div class='quotetop'>QUOTE(F8L @ Apr 24 2007, 09:55 AM) [snapback]428950[/snapback]</div>
    my dad works in a paper mill. they make catalog paper 24/7. warehouses just full the the stuff waiting to be sent out... train cars full of trees going in. we walked through the factory and i could not imagine where all that paper would go and who needed that much of it...
  20. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    I have worked on multiple EIRs and EISs where wetland ecosystems were eliminated for some sort of development. The "preferred" mitigation, just to get the development approved, was to create another wetland.
    This is absurd as the "created" wetland does not necessary conform to topography or have a natural and sustainable source of water.
