Mode Button
Discussion in 'Gen 2 Prius Main Forum' started by bredekamp, Apr 30, 2007.
  1. bredekamp
    bredekamp Member
    569
    Somerset West, South Africa
    I'm getting my 2006 Prius this week. I want to test all functions at the dealer before I accept the car. I have one question; what does the "Mode" button on the steering wheel do? Do I use this button to toggle between the Energy and Consumption screens?
  2. cireecnop1
    cireecnop1 New Member
    338
    Pueblo, CO
    <div class='quotetop'>QUOTE(Albertus @ Apr 30 2007, 11:34 AM) [snapback]432612[/snapback]</div>
    The mode button selects between FM FM2 AM SAT CD and AUX.....the "info" button on the right hand side of the steering wheel is what allows you to toggle between Energy and Consumption screens.
    Have fun with your new car!!! dont forget to play with the Voice command button , it will let you select your audio, air conditioner setting among many other features.
  3. aaf709
    3,862
    2022 Prius Prime
    The MODE button will also turn the radio On (if off) and Off (hold the button for a second or so).
  4. bredekamp
    bredekamp Member
    569
  5. ibcs
    ibcs New Member
    351
    31
    Englewood , Ohio
    <div class='quotetop'>QUOTE(aaf709 @ Apr 30 2007, 01:41 PM) [snapback]432615[/snapback]</div>
    Thank you - I had no idea you could turn the radio off with the mode button.
  6. Tideland Prius
    16,501
    <div class='quotetop'>QUOTE(ibcs @ Apr 30 2007, 07:13 PM) [snapback]432967[/snapback]</div>
    Pressing and holding "up" or "down" changes the CD (if you have a CD Changer). Just pressing it once changes track/station.
  7. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(ibcs @ Apr 30 2007, 06:13 PM) [snapback]432967[/snapback]</div>
    Ditto. It helps to know you have to hold it down awhile.
    Dave M.
