MFD bar blank .
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FishHawk, May 3, 2007.
  1. FishHawk
    FishHawk New Member
    176
    I just had one bar on my MFD totally blank. Is this a sign of trouble or is it normal . The bars after it showed the normal mileage ect. I will tell you that I was sitting in traffic for about 5 mins and prehaps that's why this happened. Maybe I answered my own question. FishHawk
  2. chinalfr2
    chinalfr2 Member
    234
    New England
    If I hit traffic (some nasty dead stop traffic), I have seen a blank bar on my MFD. I think the vehicle have to travel certain distance in an interval of 5 mins to get a correct calculation.
  3. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    <div class='quotetop'>QUOTE(FishHawk @ May 3 2007, 07:23 AM) [snapback]434622[/snapback]</div>
    You sure did.
    I wish I could answer my own questions that easily! :)
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    To elaborate slightly, the MFD computes liters per kilometer and converts it to MPG for us. So if the car does not move it is smart enough to realize it can't divide by zero and just doesn't display a bar for that 5 min period.
  5. aaf709
    3,862
    2022 Prius Prime
    The same thing happens if you cut the speed sensor wire for the BT and install a switch. If it's switched Off for 5 minutes, there'll be a blank bar for that period.
    Once I wanted to to finish listening to a radio program after I had parked, so I left it in Ready. By the time the program had ended, I had a blank bar too.
  6. Darken
    Darken Active Member
    553
    49
    PA Dutch Country
    <div class='quotetop'>QUOTE(tumbleweed @ May 3 2007, 10:43 AM) [snapback]434716[/snapback]</div>
    I had this blank bar happen at the car wash the other day. The question is does the 0 MPG factor into the overall tank or is it just a 5 minute perios without any data?
  7. tumbleweed
    4,067
    691
    Eastern Oregon
    <div class='quotetop'>QUOTE(Darken @ May 3 2007, 08:27 AM) [snapback]434749[/snapback]</div>
    Since MPG calculations do not include time The blank bar for 5 min should not effect your MPG reading. In other words the bars are MPG per unit of time and the MPG does not use time at all. So it will include the fuel used and the MPG calculation will still be accurate. Of course if you are using fuel without moving, or while moving slowly, it will decrease your MPG readings as you would expect.
  8. paulccullen
    paulccullen New Member
    276
    Seattle, WA
    If the ICE runs and consumes gas, it will factor into your tank's MPG.
    This past winter on a couple of very cold mornings I "pre-warmed" my car by leaving it running in driveway (yes, I locked the car with the little mechanical key in the fob to be safe). This *really* dragged down the MPG for that tank.
    Then I switched to a hair dryer on an extension chord, hanging from the rear vision mirror. It's a *much* more energy-efficient way to pre-warm your car interior. (I had previously used the hair dryer pre-warming trick on my EV, which had *no* heat of it's own)
