Interior Light
Discussion in 'Gen 2 Prius Main Forum' started by John6012, May 5, 2007.
  1. John6012
    John6012 Member
    134
    2018 Prius Prime
    Just got the 07 pkg 5 and can't for the life of me can't figure out what should be so simple even a caveman can do it...the interior light is supposed to come on when the door is opened and "fade" off after the door is closed. I move the overhead switch to the right and it stays on and won't go off; I move it to the left and the same thing happens. I think I have it figured out and look into my dark garage and the interior light is on. Am I doing something wrong?
  2. hschuck
    hschuck Member
    385
    bay city, ca
    On my car, the switch to the right turns the light on. Switch to the left will cause the light to turn on when the door is opened and turn it off (fade out) about 10 seconds after the door is closed or when the car is started.
  3. Tideland Prius
    16,549
    Don't say left or right because the front and rear dome lights operate in opposite directions lol.
    As long as the light switch is at "DOOR", that's what you want. If it stays on, you probably left the hatch ajar.
  4. John6012
    John6012 Member
    134
    2018 Prius Prime
    <div class='quotetop'>QUOTE(Tideland Prius @ May 5 2007, 02:46 PM) [snapback]436114[/snapback]</div>
    Thanks, I hated to ask such a stoopid question but I'm old. Now I gotta figure out how to tuen the radio to specific stations and the homelink deal and I have a rolling code on the garage door opener!
  5. darelldd
    6,059
    389
    Northern CA
    The owner's manual is your friend.
  6. Tideland Prius
    16,549
    <div class='quotetop'>QUOTE(John6012 @ May 5 2007, 01:32 PM) [snapback]436131[/snapback]</div>
    A stupid question is the one not asked!
    the TUNE knob (just like the radio used to be :lol: ) will help tune. However, you can also use SEEK to find the next radio station. To set the radio station, press and hold the number on the screen you wish that station to be. e.g. if you want Preset 1 to be 91.3FM, then press and hold Preset 1.
    The rolling code info is in the owner's manual. Might be under "Canadian users" or something like that.
  7. MrLightRail
    MrLightRail Junior Member
    26
    Oklahoma
    I have the same issue, but my hatch IS CLOSED, yet the interior lights don't go off when switch is in "door" position.
