Oh, this is Bizarre -- WTFO...
Discussion in 'Gen 2 Prius Technical Discussion' started by ekpolk, May 12, 2007.
  1. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    Well, just as I was beginning to believe my Prius was perfect, this happens on the way home from Target today. I turned left into an uphill side street, and got on the gas. As I did, I got the proverbial "Christmas tree" instrument panel: Hybrid system light (!), check engine light, brake system warning, and the VSC light.
    So I pulled over, figuring that now, CAN View really will earn its keep, as I select the DTC page. While several of the blocks did not have the usual "no codes" entry, they were simply blank, displaying nothing at all. Strange. I used CAN View RESET feature, and the codes went away. [EDIT: that should read that the "lights" not the non-existent codes, went away...]
    I also immediately checked the oil, as I had changed it earlier this afternoon. No problem there, still full. I had also just filled the gas, so I checked the cap, and it's tight.
    I drove off, and the lights came back. Same result, no codes showing in CAN View, but blanks on the Hybrid system block.
    I RESET them again, figuring that if it's a real problem, they'll come back. I got home, three miles later, and shut down. I let the car sit for about 20 min, checked everything under the hood (all good, brake fluid at MAX).
    I restarted, and drove off. No lights and no codes. Drives fine, no symptoms detectable at all. My confidence is a little shaken (not much, just a little). Anyone ever seen such behavior before? My car is an 04 that just rolled over to 40k miles, and it's under the 7/100 TCU wty.
    Any thoughts appreciated. :mellow:
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(ekpolk @ May 12 2007, 07:15 PM) [snapback]440751[/snapback]</div>
    Evil spirits. (Happens in the office all the time.) Good luck. I know that would bother me for for quite a while.
  3. hobbit
    hobbit Senior Member
    4,089
    468
    Bahstahn
    Or gamma rays from the planet Mongo. Seriously, though, perhaps it
    was an issue in a module that can-view can't dig DTCs out of. Can
    it, for example, pull codes from the brake controller? Anyone local
    to you have a sufficiently brainy scantool you could get a second
    opinion with?
    Code clearing is a "huge hammer" that affects way too many things
    at once sometimes... it would have been nice if the OBD2 spec had
    been defined to allow resetting ONE condition at a time.
    I'd say if it happens again and you still can't find it, start
    reseating connectors.
    _H*
  4. Old Marine
    Old Marine Junior Member
    Milton, Florida
    You have to be a military pilot. Was it at night? You got hit with a lurkie. :p
  5. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    <div class='quotetop'>QUOTE(hobbit @ May 12 2007, 09:48 PM) [snapback]440820[/snapback]</div>
    I have a Candygram for Mongo!
  6. ekpolk
    548
    176
    2018 Prius
    Two Eco
    <div class='quotetop'>QUOTE(Old Marine @ May 12 2007, 11:36 PM) [snapback]440899[/snapback]</div>
    Eight years EA-6Bs, VMAQ-2 (but they turned me into a Judge Advocate long ago). No, not at night, but almost as good. Those lights are awfully bright shining out from the normal darkness of the panel...
  7. ekpolk
    548
    176
    2018 Prius
    Two Eco
    Well, I feel a little better. I just got back from driving about 15 miles around town. Temp around 90F, stop and go city traffic. Tried to simulate acceleration that immediately preceded the first light show. Nothing. Panel lights all off and car behaving normally. Strange, but better than having the lights on (I think)... No signs of Mongo yet.
  8. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    While I know this sounds like a bit of a copout.... try charging the 12V aux battery. I have seen a lot of really weird results coming from a 12V that had simply gotten a little low on charge. Prii seem to have a tendency to not fully recharge the aux at times.
    and yes, I know the 12V is only for "booting up" the system, but it can't hurt to try.....
  9. ekpolk
    548
    176
    2018 Prius
    Two Eco
    They're back. Tonight, I headed out for my usual Sunday night drive from Pensacola to New Orleans (~200 miles), on I-10W. About 15 miles down the road, with no warning, all four lights came on at the same time (Hybrid System warning, CEL, brake system, VSC) and at the same time, the car's power sagged noticeably. I had been doing about 65 mph, and had to add substantial pedal to maintain speed. Fortunately, this happened a mile or two short of the last exit in FL (and the last for about 30 miles). I limped it home, and plan to take it to the dealer for diagnosis tomorrow morning.
    Anyone care to take a stab at calling this one (the four lights, lagging power) before it goes in?
    EDIT: I really don't know if the car had the power "sag" when this first happened yesterday, as it happened at "suburban speed" and if it did, I didn't notice it. At any rate, it certainly was noticeable even a low highway speed.
  10. hobbit
    4,089
    468
    Bahstahn
    Waitasec, you added "more pedal" and got some approximation of
    go-oomph back? Iiiinteresting. What was the SoC at the time?
    _H*
  11. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Ekpolk,
    Have you had the Reflash on this car for the stall-out software problem?
    Also, 12 V battery failing might be in line with this problem. A momentary short in a cell (from something rolling around in there) might overload the current limit in the DC-DC converter as it tries to regulate. Try putting an analog volt meter on the 12 V and go out and play. Its been reported that wierd stuff starts happening when the 12 V battery gets close to, but not quite dead.
    On the oil refill, its been reported on PC, if the oil level is high (1/4 inch above the top dipstick pip or more) that the engine will contaminate the mass flow sensor.
    You might also crawl under the front of the car and check the harness and starter hole cover plate issue Hobbit found.
  12. ekpolk
    548
    176
    2018 Prius
    Two Eco
    Hobbit:
    I wasn't looking at it right when this hit, but about a mile down the interstate, before I exited, I saw 57% (the CV display I was using has only numeric SoC readout). Before exiting, I shifted to the standard Toyota displays (a caution box had appeared on the MFD too), and as I pulled into a parking lot to sort things out, I had seven green bars, so it was charging.
    donee:
    I wasn't looking for it, but I did not see that cover. Had something looked amiss, I would like to think I'd have caught it. I have not put the multi-meter to the 12v battery, but it is showing proper voltage on the CAN View screens, but that of course is but one parameter and does not rule out a problem. Also, I run my oil a couple mm below the FULL mark on the stick for just the reason you mention, so unlikely that's an issue here. But hey, thanks very much to both of you for taking a stab at this!
    Well, off to the dealer after breakfast. I'll let you know what we come up with. . .
    Oh yeah, after I pulled off to check things out, I cycled the power on and off several times. On the third cycle, the Brake system and VSC lights did not come back on. About half-way through the limp home, they did re-illuminate again. The brakes felt and worked fine, and no, I wasn't in the mood to challenge the VSC at that point.
  13. ekpolk
    548
    176
    2018 Prius
    Two Eco
    Well, just back from the dealer -- in a Camry LE rental (dealer provided) as my car is still in their custody.
    First off, they pulled the codes, and seemed a little confused by the mixture they saw. Apparently, it needs an upgraded coolant pump, which they have on order now. The reset the codes and sent me on my way, assuring me that all would be OK until the part arrives. They also noted that the car DOES need several software upgrades. This really irritates me, as when I bought the car used last year, the assured me both verbally, and on the TCU paperwork, that the car had received all updates called for from Toyota. Apparently not. . . And what the Brake Warning and VSC lights have to do with a coolant pump, I don't know.
    Reluctantly, I left with the car, after they insisted it was "safe to drive" and that I did not need a replacement while the parts shipped. I got about three miles down the road, and all four lights came right back on, and the power sagged again. Back to the dealer. This time, seeing all four lights actually on (brake and VSC had gone out), and listening to my tone, they decided to put me in a replacement while they sort it out.
    I am at best suspicious of the "it just needs to upgrades and the pump is a routine matter" explanations. The car had been behaving just fine until it suddenly started throwing codes, illuminating multiple lights, and going limp with the power.
  14. donee
    donee New Member
    2,956
    197
    Chicagoland
    Hi Ekpolk,
    This seems like a general failure. Battery seems a common thread between those modules. Could be a cable fault too. I would go ahead and have the battery replaced. Its 3 years old. Not much of a waste to replace. It would only last a few more years at most. It would also not be the first time that a battery replacement solved a whole bunch of flashing warning lights on a Prius.
    A quick short and open in the battery might not be seen on a digital meter. That is why I suggested the analog meter. All it would look like is a slight jerk down in the needle.
    Ever see what happens to a gallon of milk stored in the back of the car during a few quick turns? Seems there is allot of G's back there in the rear of the car where the battery is.
  15. hobbit
    4,089
    468
    Bahstahn
    "Upgraded" coolant pump? That's a new one. Is your coolant pump
    failing, or not? Could a failing coolant pump have caused the
    inverter to overheat, and then go into a self-protective mode where
    it doesn't shuffle as much power around [thus the "sag"]? If it's
    not the battery, perhaps it's something else suddenly hitting a limit
    and backing off to protect itself.
    _H*
  16. ekpolk
    548
    176
    2018 Prius
    Two Eco
    Well, I guess there is something to the coolant pump thing. Apparently a number of the 04 MY cars got pumps that have some issue with them that eventually starts causing problems. They also noted that my car had not received any software upgrades, and required a complete reload. I found this somewhat irritating, as when I bought the car, the Toyota Certified Used documents showed a check-off indicating that the car had received all factory directed upgrades, recall work, etc. Hmmmmm. Last excuse from me today: I had a meeting to get to and rushed through the pickup, and left the invoice. I'll swing by tomorrow and get it so I can see what codes exactly I had, and why a coolant pump and old software would cause the brake system and VSC warning lights to trigger.
    That said, the car is running perfectly, no lights, and no hint otherwise of anything amiss. We'll see...
