engine not displaying on monitor
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by toolbox, Oct 4, 2004.
  1. toolbox
    toolbox New Member
    72
    St. Louis
    I only have had my Prius a couple weeks and i am still learning the car. I have noticed that when the engine is cycling to warm the coolant while cold it doesnt always show up on the mfd. has anyone else noticed this and is this normal operation.
  2. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    Your observations are consistent with mine.
  3. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    really, I've never seen that...are you guys in '04s or '05s and late or early if '04s? Can you grab a photos for me to see?
  4. KMO
    KMO Senior Member
    1,807
    585
    Finland
    2023 Prius Prime
    What could it show? If it isn't charging the battery, and it isn't powering the wheels, then there shouldn't be any arrows. Makes sense.
    Now, if they had a simple "engine running" indication, maybe just animating the icon like they do the wheels...
  5. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(KMO\";p=\"43452)</div>
    One of us is misunderstanding. Is I read the post there is no ICE icon showing. You seem to be reading it as no arrows from the ICE icon. Certainly there are many times with no arrows from the ICE, but I've never seen the screen without the ICE icon.
    Could one of you first two posters please clarify this point?
  6. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(efusco\";p=\"43447)</div>
    Evan,
    You don't really expect me to take a picture of the MFD while driving, do you? One of your LA colleagues may end up with an extra patient in the ER if I were to do so.
    :lol:
    Seriously. I have managed, on a few occasions, to manipulate the gas pedal to the point that no arrows were showing at all, while at the same time I can still feel that the ICE is on. On other instances, I have been stopped at a red light for a minute or two. No arrows were showing to indicate that any activity is taking place and all of a sudden the car shudders slightly as the ICE turns itself off.
    Mind you, I have not even had the car for two weeks and am still getting the feel for it. Some of my impressions may not be accurate.
    My car is one of the very first 05s with barely 600 miles on the odometer.
  7. victor
    victor New Member
    414
    Gilching Bavaria Germany, &amp; Drapanos, Crete, G
    Remember the MFD updates every 3 seconds, so the ICE can still be shown as running (or not) when its not (or is).
    As I read the original post I understood there was no ICON showing. Now that would be strange.
    toolbox: Can you clarify?
  8. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    I believe I know what you are talking about. If correct, I've noticed the same thing and have been tempted to take pictures for posting here. Here's what I observe and you can confirm or correct:
    When I'm driving in the morning, I can be rolling down an incline. One would assume that the Current MPG reading would be 100. But it's not. It's sometimes around 80MPG and sometimes lower. I [info] over to the other screen and nothing is showing. It's as though the engine is not running, there's no drain on the battery, but it's not charging either. It's just showing no arrows. I [info] back to the consumption screen and it's still at 80MPG.
    I have just assumed that it's the engine running to heat itself, but would appreciate some acknowledgement to explain the hit on my mileage.
    Toolbox, is this the lack of display you are noticing?
  9. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(10132003\";p=\"43522)</div>
    Evan,
    :lol:
    My car is one of the very first 05s with barely 600 miles on the odometer.[/b][/quote]
    So you guys are saying you're seeing no 'arrows' from the ICE despite it running?? I got the impression you meant no ICE icon at all. Heck I 'no arrows' drive all the time. Frequently I'll 'hyperstealth' over 42mph and have no ice arrows but know that it has to be running.
    I thought toolbox was saying no icon which I've never seen.
  10. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(efusco\";p=\"43527)</div>
    Where is there an ICE icon? Are you referring to the engine symbol on the MFD "Energy" screen? If so, I am sure that at times it indicates that the ICE is off when I know for a fact that the engine is running.
  11. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(10132003\";p=\"43542)</div>
    Where is there an ICE icon? Are you referring to the engine symbol on the MFD "Energy" screen? If so, I am sure that at times it indicates that the ICE is off when I know for a fact that the engine is running.[/b][/quote]
    Ok, listen carefully...ICE = Engine (Internal Combustion Engine). There is an icon that is the ICE/Engine. The first post in this thread suggests that that icon itself becomes invisible when the ICE is warming up--running but doesn't show. YOU confirmed seeing the same thing.
    I am now getting the strong suggestion that that is NOT what either of you meant but that you don't see any ARROW ICONS despite the ICE running but that the ICE icon itself is always there....isn't that what you're saying?
  12. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    evan, i do believe your hypothesis is correct. they are refering to stealth mode and the warm up period.
    there will be several times when no arrows are present even when the car is warmed up and running at freeway speeds. we on this site refer to it as running in "stealth" mode.
    this does not mean the engine is not running. it simply means that the engine is not outputting enough power for any of its functions to register on the screen.
    this happens frequently and under several different conditions depending on what you are doing.
    it could be that you are on a long slight downgrade and has just enough gas pedal pressure to maintain speed without charging.
    be assured that the car is doing something and there needs to be a transistional area when the engine goes from powering the wheels to charging the battery (or both) to providing power to the EV.
    this is normal operation. certain types of flourescent light needs 80 volts to remain lit... but need 110+ volts to light up...
    this creates an area between the starting voltage (110+) and the "running" voltage or what is needed to keep light on (80) where sometimes the light is on and some times its off...
    when turning the light on from an off state. the "between" voltage will result in a light that is off... but if the light is on, then that voltage will result in a light that is on.
    so you have the same voltage values, but two different states of the light. that is what you are seeing on the screen when there are no arrows present. you will notice that you can run the gamut of arrow direction if you choose to do so by somewhat aggresive gas pedal action... you can go from the "3 arrows" (arrows to the wheels battery and EV) to the other extreme of arrows to just the battery from either the wheels or the ICE.
    but the very gentle (and recommended here for maximum efficiency) and correct pedal action can result in a longer time between the arrow transistions including times when no arrows are present.
  13. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(efusco\";p=\"43584)</div>
    Evan,
    I have watched my dashboard like a hawk, on the drive home from the office, for any sign of such an icon. Other than the arrows in the "Energy" screen, I have found nothing to indicate whether or not the ICE is running. Just where is that icon that you are referring to? Perhaps its absence is one of the differentiations between the 04 and the 05 models.
  14. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    its the picture of a little motor... with fan blade.
    it will be about top center on screen. it will not be on dash but the TFT screen. its the screen that shows energy flow in the system.
    http://priuschat.com/forums/album_thumbnai....php?pic_id=753
    see it bet the front wheel and SOC indicator? labeled "engine" (never realized that it was labeled till looking at this pic)
    the pic you see was when my car was warming up. i am coasting down a freeway overpass and as you can see, although i am regenerating i still have poor mpg reading of 13 mpg because my car was still in the warm up stage.
  15. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(10132003\";p=\"43622)</div>
    Evan,
    I have watched my dashboard like a hawk, on the drive home from the office, for any sign of such an icon. Other than the arrows in the "Energy" screen, I have found nothing to indicate whether or not the ICE is running. Just where is that icon that you are referring to? Perhaps its absence is one of the differentiations between the 04 and the 05 models.[/b][/quote]
    Neither the original poster, nor I, nor anyone else said that there is an icon that indicates that the ICE is running...that is your misinterpretation. My, apparent, misinterpretation was that the original poster said that there was no ICE icon at all showing despite the ICE running/warming up.
    Without an Engine Run Indicator or tachometer or miniscanner there is no indicator as to whether the ICE is running or not.
    I think the other issues have been adequately addressed above.
  16. jamarimutt
    jamarimutt New Member
    985
    This is fun!
  17. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(jamarimutt\";p=\"43693)</div>
    Shut up!! :cussing: :cussing: :cussing:
    I've pulled half my hair out trying to be clear and make sure we're all saying the same thing and we all just seem to confuse each other more. Oye!
  18. IsrAmeriPrius
    4,333
    Southern California
    <div class='quotetop'>QUOTE(DaveinOlyWA\";p=\"43624)</div>
    I am well familiar with that picture, except that it is a static image that does not change at all to indicate whether the ICE is running or not. The icon which I could not find, because it does not exist, monitors if the ICE is On or Off.
  19. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    oic what you are getting at. and you are right. the screen only shows power distribution when involved in motion of the car only.
