Painting Outdoor furniture
Discussion in 'Fred's House of Pancakes' started by priusmaybe, May 18, 2007.
  1. priusmaybe
    priusmaybe New Member
    314
    Atlanta
    I have some cool outdoor art deco furniture, chairs, table. They are iron I believe. They have a great spring action rocking movement. They are so comfortable.
    Don't tell me to buy tacky rubbermaid, because I hate the design. My stuff goes perfect with my deco architecture.
    I have painted them before but they don't hold up.
    Now they have layers of paint and rust. I have been scraping them. I am already tired.
    How would sandblasting, and auto paint work on these babies? Would someone like Mako do it?
    There has to be an easier more efficient way. Or do I just keep working, and use rustoleum primer and paint?
  2. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    I've had some pretty good luck with rustoleum in the past.
    As for getting all of the rust and old paint off, you should try getting an electronic hand sander, or a dremel, or some other such tool that will do most of the work for you. Just stay up till 2 and watch the infomercials, you'll find something there pretty quickly :p
  3. priusmaybe
    314
    Atlanta
    Maybe I will go to Home Depot and get a sander or dremel. What kind should I get?
    I am a female, and not extremely handy. I don't mind a little work.
    This is one of those times when a husband would be handy dandy ;)
  4. tnthub
    tnthub Member
    519
    Brunswick, Maine
    What I know about iron is that it rusts extremely quickly when exposed to even regular humidity (no rain). The process is basically to remove all rust that you can find and then wipe down with a dry cloth to remove whatever dust has settled on it during the rust removal process. You then really need a couple of coats of a primer paint with complete drying cycles in between. The you are looking at using some sort of rustoleum type of paint over the primer, again with complete drying cycles in between coats. It is a slow and labor intensive process.
    Sandblasting is by far the quickest and easiest method to remove the rust but with some elbow grease and perseverence a dremmel, hand grinder, and steel wool will do the job. Just don't leave the bare metal exposed to the air for long as it begins the rusting process as soon as it is exposed. You may be able to find some tutorials on line through some selective google searches or take a trip to your local book store. Have fun. :)
  5. Darwood
    Darwood Senior Member
    5,259
    268
    I'm afraid the rust will keep returning.
    To stop it, you would need to completely remove ANY and ALL rust, prime and paint with multiple coats, possibly even a clearcoat.
    I would recommend you knock the easy rust off and keep spraying over it with rust oleum once a couple of times a year. It's far less work and far cheaper than trying to do a sandblast job or buying a dremel to grind it down for hours.
  6. formerVWdriver
    formerVWdriver New Member
    258
    It sounds like it's going to be a tremendous amount of work just to remove the rust. And if you don't get it all off, the rest of what you do is wasted....
    I had a similar problem with an iron bed I inherited that had a lot of intricate details. I called some antique shops and places that restored antiques and they all recommended that I take it to AAA Sign Shop -- the last place I would have called. The sign shop did a great job -- they sandblasted the whole thing and immediately coated it with rustoleum. Then I painted over that when I got it at home.
    It wasn't expensive, they were fast, and it is an absolutely perfect job. Unless you have a lot of time on your hads, don't do the rust removal and prep work yourself. (Plus -- what's in that old paint you're taking off and breathing? The professionals know how to handle that part, too.)
  7. hyo silver
    hyo silver Awaaaaay
    15,268
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    I like your decision to keep the old art deco stuff. I've had great results with Tremco Tremclad rust paint. It seems to bond with the rust and keeps it from getting any worse. I used a wire brush to scrape off the flaking bits, and painted right over the rest. No need to go right to bare metal all over, which would take forever without a commercial sandblaster. It's not perfectly smooth like you'd want a car's finish to be, but it does the trick. If you work on a tarp, you'll be able to catch most of the old paint and keep the overspray or drips off your patio. Goggles are a good idea, too. If you give up and decide to junk the stuff, let me know. It would go great with my 1939 house, too. :)
  8. priusmaybe
    314
    Atlanta
    <div class='quotetop'>QUOTE(hyo silver @ May 18 2007, 05:41 PM) [snapback]445239[/snapback]</div>
    I don't know if we have Tremco in USA.
